| Not happy; final drive oil leak | |
+6Cosmic_Jumper jdeereanton MikeO DennisB masscoot bigbird 10 posters |
Number of posts : 2387 Location : Winnipeg Points : 7907 Registration date : 2010-05-03
| Subject: Not happy; final drive oil leak Tue May 18, 2010 7:18 pm | |
masscoot Silver Wing Rider
Number of posts : 438 Location : Central New England Points : 6182 Registration date : 2009-03-24
| Subject: Re: Not happy; final drive oil leak Tue May 18, 2010 8:37 pm | |
| That sounds like super service (so far) to me! Good luck |
| Subject: Re: Not happy; final drive oil leak Tue May 18, 2010 8:59 pm | |
| Hey bigbird, Refresh my memory. What year is your scooter? Is your scooter sill under warrenty? |
| Subject: Re: Not happy; final drive oil leak Tue May 18, 2010 9:08 pm | |
| It's a new '09 one, Dennis. |
| Subject: Re: Not happy; final drive oil leak Tue May 18, 2010 9:40 pm | |
jdeereanton Silver Wing Guru
| Subject: Re: Not happy; final drive oil leak Tue May 18, 2010 10:01 pm | |
| I thought dealers (stealers) are the enemy? Not from my perspective, some shops are not good, but that can happen in any service industry.
Happy to hear your dealer is taking care of you. |
| Subject: Re: Not happy; final drive oil leak Wed May 19, 2010 4:17 am | |
| It's good to hear you have a good dealer. I have a 2004 silverwing with 42,000 miles on it, and just two weeks ago i found the same problem yours has. I normally do all the work myself on my bike. I took it as far apart as i could, but found out i needed a special tool to get the rear clutch off. So i took it down to the dealer and they took it apart too, and got as far as they could. They found out they need the same part too but didn't have it in stock. They ordered the tool, so far its been almost two weeks and still now word from them. I'll let you know when they fix it. |
| Subject: Re: Not happy; final drive oil leak Wed May 19, 2010 12:47 pm | |
| Besides the RTV sealer that seals the 2 halves of the drive housing, there are two shaft seals. One on the input shaft (on the clutch side of the housing) and the final drive output shaft (on the wheel side). Here is an illustration of where the seals are located. |
| Subject: Re: Not happy; final drive oil leak Wed May 19, 2010 10:07 pm | |
| Subject: Re: Not happy; final drive oil leak Thu May 20, 2010 2:25 pm | |
| FWIW, you don't need the Special Tool to to reinstall the Clutch Bell (Clutch Outer). You do, however, need the Special clutch outer remover Tool (07ZMC-MCTA100) to get the Clutch Bell off.
You can use the original 22 mm (?) nut that holds on the Driven Pulley/Clutch assy, along with some PVC tubing and a couple of large washers to 'press' the Clutch Bell back onto the splined shaft. The Bell is really not on the shaft all that tight. It goes on easy enough, so I don't know why there is such a heavy and large tool required to remove it.
Here is a link from the Italian Silverwing site with a 'blueprint' for the Removal tool. If you've got access to a machinist go for it:
http://66.163.168.225/babelfish/translate_url_content?.intl=us&lp=it_en&trurl=http%3a%2f%2fwww.silverwing400.it%2findex.php%3foption%3dcom_content%26task%3dview%26id%3d86%26Itemid%3d44
Yeah, I know it's a mangled translation from Italian, but if there's a better idea to get the Clutch Bell off please let us know. HTH
| Subject: Re: Not happy; final drive oil leak Thu May 20, 2010 3:37 pm | |
crahar Super Scooter Rider
Number of posts : 283 Age : 76 Location : Beaumont, Texas Points : 5857 Registration date : 2009-08-31
| Subject: Re: Not happy; final drive oil leak Thu May 20, 2010 7:49 pm | |
| Looks like a tool I made for pulling a shaft on a CNC machine when I had too work for a living, A pipe with some ears welded into it, a chunk of square stock drilled and taped welded onto the end. We had to make quite a few of our own pullers due to having downtime or waiting on having them shipped. Some of the company's wanted you to use their men to do the repairs and wouldn't sell the tools needed so you had no choice but to make your own. Craig |
| Subject: Re: Not happy; final drive oil leak Thu May 20, 2010 8:24 pm | |
| Subject: Re: Not happy; final drive oil leak Sat May 22, 2010 3:46 pm | |
Number of posts : 2598 Age : 65 Location : Bay Area, Ca Points : 8669 Registration date : 2008-12-20
| Subject: Re: Not happy; final drive oil leak Sat May 22, 2010 5:56 pm | |
| bigbird, It seems you are dealing with a very good shop even though it is taking awhile to get the puller. I couldn't see a shop in my area giving me a loaner bike, or an offer to trade a bike, that they need to repair, for a new SWing. Regardless of what happens I would stay with this shop. But I hope you get what you want really soon since I'm sure you can't wait to get it back. Are they being so good to you because of certain laws up there in Canada? Maybe I've been out here in California too long, because I just can't see the shops here doing all of this. Maybe the BMW shops would but I can't see the shops that sell the bikes from Japan being so good to people. Good luck and keep us informed. |
| Subject: Re: Not happy; final drive oil leak Sat May 22, 2010 7:07 pm | |
Number of posts : 2658 Age : 81 Location : Medford, Oregon Points : 8398 Registration date : 2009-07-18
| Subject: Re: Not happy; final drive oil leak Sat May 22, 2010 10:28 pm | |
| Hey bigbird, stay off that GL1800 or you may be bitten by the bug. There just isn't any other touring bike that can come close. Too bad about the price tag. |
| Subject: Re: Not happy; final drive oil leak Sat May 22, 2010 11:20 pm | |
| Subject: Re: Not happy; final drive oil leak Tue May 25, 2010 10:01 pm | |
YammaPapa Scooter Rider
Number of posts : 29 Location : Winnipeg Canada Points : 5330 Registration date : 2010-05-25
| Subject: Re: Not happy; final drive oil leak Tue May 25, 2010 11:15 pm | |
| Hey bigbird.
If you want to ride a Swing, I'll lend you the wife's 'till yours is fixed!
Welcome to Swing club.
YammaPapa aka: Roadliner Rider |
| Subject: Re: Not happy; final drive oil leak Tue May 25, 2010 11:17 pm | |
| Subject: Re: Not happy; final drive oil leak Wed May 26, 2010 10:43 pm | |
| Subject: Re: Not happy; final drive oil leak Wed May 26, 2010 10:49 pm | |
| Great to hear you are both HAPPY! |
