tonylumps Maxi-Scooter Rider
Number of posts : 148 Age : 81 Location : Newtown Square Pa Points : 5512 Registration date : 2010-04-26
| Subject: Turn Signals Tue Jun 15, 2010 7:39 pm | |
| I am forgetting to cancel my turn signals about 50% of the time because my other bike has auto cancel . Has anyone tried Turn Signal Alert from R/V toys It seems like it would work Thanks Tony |
| Subject: Re: Turn Signals Tue Jun 15, 2010 9:24 pm | |
| Hi Tony, Tie a string around your left thum so don't forget. May work? |
Number of posts : 341 Location : Surprise, AZ. Points : 5788 Registration date : 2010-04-30
| Subject: Re: Turn Signals Tue Jun 15, 2010 10:17 pm | |
| If you are the tinkering type you can try one of these.......
http://www.rattlebars.com/mtz/buzzer.html |
masscoot Silver Wing Rider
Number of posts : 438 Location : Central New England Points : 6181 Registration date : 2009-03-24
| Subject: Re: Turn Signals Tue Jun 15, 2010 10:30 pm | |
| I found that link last week and saved it one of my projects files. Seems like a good solution. |
| Subject: Re: Turn Signals Wed Jun 16, 2010 4:55 am | |
| Thanks but that is a winter project For me anyway and Dennis I only have two thumbs and they are being used But i keep forgetting why. Tony |
jdeereanton Silver Wing Guru
| Subject: Re: Turn Signals Wed Jun 16, 2010 8:09 am | |
| Another option: https://www.kisantech.com/index.php?cat_id=4 Seems to be something of a magic solution providing 4-way flasher and running light options in addition to the signal cancellation. |
| Subject: Re: Turn Signals Wed Jun 16, 2010 9:22 am | |
| A very easy way of doing it is to buy a couple of 12V piezo buzzers from a shop that sells electrical and radio bits (Maplins and Tandys in the UK) and bridge the two wires on each turn-signal - one can even just trap the wires in the connectors on the back of the light-unit. Apparently, with the use of diodes, only one buzzer is needed but that's getting a bit technical for me! I thought of doing this when I take off the rear panel again. |
