Front turn signals do not work I_icon_minitimeby sonuvabug Today at 4:19 pm
Front turn signals do not work I_icon_minitimeby sonuvabug Today at 4:17 pm
Front turn signals do not work I_icon_minitimeby sonuvabug Today at 4:06 pm
Front turn signals do not work I_icon_minitimeby JohnyC Yesterday at 10:04 am
Front turn signals do not work I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Front turn signals do not work I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Front turn signals do not work I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Front turn signals do not work I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Front turn signals do not work I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Front turn signals do not work I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
3 posters
WingMan02
WingMan02
Number of posts : 287
Front turn signals do not work Empty
PostSubject: Front turn signals do not work   Front turn signals do not work I_icon_minitimeTue Nov 06, 2012 11:59 pm
Has this happened to anyone? Just got home from work and learned that both my front turn signals are not working. I have not made any recent changes. The rear turn signals and the signal indicator on the console flashes rapidly. When I press the starter switch with the signal on, the front signals flash alternately with the selected side brighter. Also when I press the starter switch, the flashing slows down back to the normal rate. My driving lights mounted on DennisB's light bar also stop working the same time. I use DennisB's front connector. Is there a fuse that controls just the front turn signals. BTW - the low and high beam works fine.
Number of posts : 2778
PostSubject: Re: Front turn signals do not work   Front turn signals do not work I_icon_minitimeWed Nov 07, 2012 3:17 pm
Hello,
I would try unhooking the Head light power connector (temporarily taking it out of the system) and plugging the two original Honda front connectors back together to see if that makes things right with your scooter.
If it turns out to be the Headlight power connector I will send you a new one at no cost.
WingMan02
WingMan02
PostSubject: Re: Front turn signals do not work   Front turn signals do not work I_icon_minitimeWed Nov 07, 2012 4:35 pm
Thanks Dennis,
I will try it tonight when I get home.
WingMan02
WingMan02
PostSubject: Re: Front turn signals do not work   Front turn signals do not work I_icon_minitimeThu Nov 08, 2012 3:12 am
Dennis,
It was the power tap. Sent you a PM.
PostSubject: Re: Front turn signals do not work   Front turn signals do not work I_icon_minitimeThu Nov 08, 2012 7:52 am
I'll send out a replacement unit in today's mail.sunny
Thank You for your purchase.
PostSubject: Re: Front turn signals do not work   Front turn signals do not work I_icon_minitimeThu Nov 08, 2012 12:16 pm
Hi Wayne,
Your replacement unit is in the mail. sunny
WingMan02
WingMan02
PostSubject: Re: Front turn signals do not work   Front turn signals do not work I_icon_minitimeThu Nov 08, 2012 12:43 pm
Aloha Dennis,
Thank you!
PostSubject: Re: Front turn signals do not work   Front turn signals do not work I_icon_minitimeThu Nov 08, 2012 6:32 pm
As we all here know, Dennis is a stand up guy, and backs up his products 100% --unlike many other vendors we've had dealings with from time-to-time.
But just out of curiosity, what could possibly go wrong with a power tap to cause such an odd malfunction with turn signals?
It's not as if a power tap is an actual circuit, with components that might fail.
WingMan02
WingMan02
PostSubject: Re: Front turn signals do not work   Front turn signals do not work I_icon_minitimeWed Nov 14, 2012 2:23 am
Dennis,
Aloha and thank you very much for sending me a replacement headlight power tap. I got it today, and installed it after getting home from work. Hurray!! I am back to using my running lights. I sent you a PM. Again thanks for the speedy response.
PostSubject: Re: Front turn signals do not work   Front turn signals do not work I_icon_minitimeWed Nov 14, 2012 9:23 am
Hi Wayne,
Your very welcome. I've try to make improvements to my products as time goes by. The feedback that you and all my friends here provide, is important to me and help make the products better.
Thank You!!!
» Good Morning! Subject: Trailer Hitches
» Turn Signals
» Led turn signals on mirrors
» Buzzer to Alert that Lights are ON and Engine is OFF
