| Right Storage Compartment Latch | |
ronjr009 Maxi-Scooter Rider
Number of posts : 180 Location : Greeneville, TN Points : 6039 Registration date : 2008-12-28
| Subject: Right Storage Compartment Latch Wed Jul 28, 2010 11:03 pm | |
| Today while riding at Deals Gap, my right storage compartment kept popping open and I could not get it to stay shut. I took a quick "looksie" during a fuel stop. I am not sure if the upper latch is worn out or if the bottom portion is not grabbing and possibly sticking. It was driving me crazy in either case and I'm going to look at it a little closer tomorrow. Has anyone else had this issue on their Swing? My compartments are the older style factory paint matching doors... Not the gray ones on the later models. |
Number of posts : 2778 Age : 74 Location : NE Oklahoma Points : 9094 Registration date : 2008-12-28
| Subject: Re: Right Storage Compartment Latch Wed Jul 28, 2010 11:22 pm | |
| Hi Ron, I think this has been a problem with the earlier Silverwings. A little creative and well thought out latch catch fileing would do the trick. |
dspevack Silver Wing Guru
Number of posts : 2008 Age : 59 Location : Miami, FL Points : 8207 Registration date : 2008-12-27
| Subject: Re: Right Storage Compartment Latch Wed Jul 28, 2010 11:24 pm | |
| It could be that you are putting your scooter thru more stress or vibration than usual, and the dash is perhaps flexing more than it should causing the latch to pop. Something like this happens when a screw or tab didn't line up properly the last time you or a mechanic put it together. Or it could be the latch itself. The part that recieves the latch is adjustable in height. You could probably raise it a little. By the way, several people, myself included, have upgraded the old dash to the new one, which also results in a completely different and more effective type of latch on both compartments. If you want the details on how to do that I'm sure I know where to find them for you. Dan |
| Subject: Re: Right Storage Compartment Latch Wed Jul 28, 2010 11:40 pm | |
| Dan & Dennis, Thanks for the tips. I'm going to try and see if I can repair/adjust it. If it continues to be a problem, I would be open to seeing what needs to be done to upgrade it to the later style dash. I'll report back tomorrow on what I discover. Thanks! |
som2002 Maxi-Scooter Rider
Number of posts : 120 Age : 52 Location : Janesville, WI Points : 5772 Registration date : 2009-06-19
| Subject: Re: Right Storage Compartment Latch Thu Jul 29, 2010 1:39 am | |
| I have the same problem with my 02. But then somedays it will work fine, then the next day won't latch right again...? Weather related maybe? Let me know what you get figured out. |
| Subject: Re: Right Storage Compartment Latch Thu Jul 29, 2010 11:52 am | |
| I looked at the latch pretty carefully. It appears that the upper portion mounted on the door is worn out from all the cycles of open/close. It will hold by itself without being attached to the door but not well. There is a little spring that the door is mounted to and their is enough strength to it to pop it open. I went ahead and removed the piece and am going to head down to the Honda shop in Greeneville this PM and see how much a new piece will set me back. I think this will remedy it without much expense. I will keep you posted. |
Hammy Touring Scooter Rider
Number of posts : 362 Age : 47 Location : Philadelphia, PA Points : 5683 Registration date : 2010-05-22
| Subject: Re: Right Storage Compartment Latch Thu Jul 29, 2010 12:48 pm | |
| Consider this place for OEM Honda parts: http://www.powersedge.com/pages/parts/viewbybrand/parts.aspx I got my drive belt for $107.99 plus shipping. |
| Subject: Re: Right Storage Compartment Latch Thu Jul 29, 2010 4:09 pm | |
| I have and 02 and I detest the old style latch on the right hand compartment.
What's the cost of upgrading to the new style and how difficult it is? |
Janewayfan Scooter Rider
Number of posts : 25 Location : Hunterdon Co., NJ Points : 5268 Registration date : 2010-07-18
| Subject: Re: Right Storage Compartment Latch Thu Jul 29, 2010 4:17 pm | |
| Mini-hijack to say that is an AWESOME pic of you on a twisty! Rock on! |
| Subject: Re: Right Storage Compartment Latch Thu Jul 29, 2010 6:58 pm | |
| - DuggleBogey wrote:
- I have and 02 and I detest the old style latch on the right hand compartment.
What's the cost of upgrading to the new style and how difficult it is? Certain countries, such as GB and Japan, have had the textured dash for years. Until 2007 the USA had painted dashes, with the color based upon the model year.
The diagram below is highlighted with what you need to change to a textured dash.
When done, your Silverwing dash will look like the textured style dash. It should work for all model years that had painted dashes. You will have to research parts prices for yourself. Parts may be ordered from your dealer, or anyplace handling stock Honda Parts. ------------------------------------------------------------------------------------------
Go to www."hondaworldonline.com" Go to "parts finder" Category: Scooters Manufacturer: Honda Select year: Select Model: FSC600a (Use drop down to select parts drawing)=inner box
Upgrade to Textured dash | Part Number | Honda Direct | Service Honda | Pocket, Right (Inner) | 64250-MCT-961 | 24.14 | 22.93 | Cover, Inner NH1 (Black) | 64305-MCT-772ZA | 59.23 | 56.41 | Lid, Right Pocket (Inner) | 64461-MCT-960 | 14.56 | 14.35 | Seal, Left Pocket Lid | 64463-MCT-000 | 2.88 | 2.82 | Seal, Right Pocket Lid | 64463-MCT-961 | 3.08 | 3.04 | Lid, Right Pocket (Outer) | 64468-MCT-960 | 14.56 | 14.35 | Lid, Left Pocket (Inner) | 64471-MCT-960 | 12.32 | 12.14 | Hook, Lock | 64472-MCT-000 | 2.50 | 1.99 | Spring, Pocket (2) | 64474-MCT-960 | 2.86 | 2.82 | Lid, Left Pocket (Outer) | 64478-MCT-960 | 14.56 | 14.35 | Knob, Right Pocket Lid Opener | 64480-MCT-960 | 4.20 | 4.14 | Hook, Right Pocket Lid Opener | 64480-MCT-960 | 2.77 | 2.73 | Spring, Return (2) | 64483-MCT-960 | 2.50 | 1.53 | Knob, Left Pocket Lid Opener | 64490-MCT-960 | 4.20 | 4.14 | Hook, Left Pocket Lid Opener | 64491-MCT-960 | 2.80 | 2.73 | Screw, Tapping (4x12)(17) | 93903-34310 | 2.50 | .33 | Screw, Tapping (4x16)(18) | 93903-34480 | 2.50 | .33 | Screw, Tapping (5x35) (2) | 93903-35310 | 2.50 | .33 | Upgrade dash - 1 bike 174.66-161.46 Screw prices shown are for 1 item (ea) Keep in mind the above price comparison was done a while ago and may have changed.Dan- Attachments
- 07SwingDash.pdf
- (132 Kb) Downloaded 63 times
Number of posts : 2598 Age : 65 Location : Bay Area, Ca Points : 8665 Registration date : 2008-12-19
| Subject: Re: Right Storage Compartment Latch Thu Jul 29, 2010 9:16 pm | |
| All, Look for Dan's post above this one for the .pdf file for the compartment. I was able to download it. Thanks. |
| Subject: Re: Right Storage Compartment Latch Sat Jul 31, 2010 9:33 pm | |
| Thanks guys for all the good advice. The new piece that screws into the top of the lid was just a few cents over 4 bucks. Not too bad and certainly won't break the bank. Should have it early next week. I will see if I can make any tweaks that might also improve it. If for some reason that this does not do the trick, I will take a look at a dash conversion as listed above. Janeway thanks for the compliment on the pics. The professional photographers that shoot at the gap do get great shots! I've tried to do this myself but without a good camera to take action shots, my friends have been unable to get a good photo so I went ahead and shelled out for the professional shots. I really love to ride the dragon. It is a great road for putting a bike through the paces, feeling rhythym and practicing your riding skills. I usually head down several times through the summer when I'm out of school. If anyone heads down their during the summer months, give me a call and I'm always up for a ride. |
