Squeaking/Squealing Noise I_icon_minitimeby zrx212 Yesterday at 4:40 pm
Squeaking/Squealing Noise I_icon_minitimeby Meldrew Yesterday at 4:37 pm
Squeaking/Squealing Noise I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Squeaking/Squealing Noise I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Squeaking/Squealing Noise I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Squeaking/Squealing Noise I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Squeaking/Squealing Noise I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
Squeaking/Squealing Noise I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
Squeaking/Squealing Noise I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
Squeaking/Squealing Noise I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
crahar
Gary M
Gary M
Number of posts : 3
Registration date : 2010-06-23
Squeaking/Squealing Noise Empty
PostSubject: Squeaking/Squealing Noise   Squeaking/Squealing Noise I_icon_minitimeTue Aug 24, 2010 6:43 pm
I have a start up squeak that I only hear when I start from a sead stop, it goes away almost as fast as it came.
It soulds like a bad wheel bearing only it comes from the drive belt area. If I start off real slow, I do not get it, but if I push it, it is quite noticeable. Bike only has 1600 mikes on it.
Any help.
Gary Myles
Number of posts : 3837
PostSubject: Re: Squeaking/Squealing Noise   Squeaking/Squealing Noise I_icon_minitimeTue Aug 24, 2010 6:50 pm
Mine does that if the weather is warm or I've been stop-starting a lot.
It's the belt on the pulleys.
PostSubject: Re: Squeaking/Squealing Noise   Squeaking/Squealing Noise I_icon_minitimeTue Aug 24, 2010 9:26 pm
You could try belt dressing. It worked on the belts in my cage.
crahar
crahar
Number of posts : 283
Registration date : 2009-08-31
PostSubject: Re: Squeaking/Squealing Noise   Squeaking/Squealing Noise I_icon_minitimeTue Aug 24, 2010 11:06 pm
Not sure I would try belt dressing on my drive belt, might cause problems with the moving parts of the clutch. Belt dressing can leave a gummy residue.
Craig
Number of posts : 2598
PostSubject: Re: Squeaking/Squealing Noise   Squeaking/Squealing Noise I_icon_minitimeTue Aug 24, 2010 11:19 pm
If that ever happens to mine I just hold in the front brake and then rev it up to 4,000 rpm's for about 5 seconds and it goes away. I think the clutch glazes over some when you do much stop and go driving. I haven't had to do that in quite a while but we can filter here. If I get it, it is just a very quite "chirp", but this takes care of it for a long time. I really can't remember the last time I did this though.
Number of posts : 2387
PostSubject: Re: Squeaking/Squealing Noise   Squeaking/Squealing Noise I_icon_minitimeWed Aug 25, 2010 12:27 am
x
KurtPerthWA
KurtPerthWA
Number of posts : 1711
PostSubject: Re: Squeaking/Squealing Noise   Squeaking/Squealing Noise I_icon_minitimeWed Aug 25, 2010 2:07 am
" It worked on the belts in my cage"
Man I am going to leave this one well alone!
PostSubject: Re: Squeaking/Squealing Noise   Squeaking/Squealing Noise I_icon_minitimeWed Aug 25, 2010 9:53 am
I have a noise in mine that I swear is a bearing . I have taken the variator apart and I see nothing wrong with it . I am changing the belt on my friends
bike soon .I think I will take it for a ride and see if it sounds like mine . If it does I guess ear plugs should fix it .
Number of posts : 2392
PostSubject: Re: Squeaking/Squealing Noise   Squeaking/Squealing Noise I_icon_minitimeWed Aug 25, 2010 11:17 am
I also get a squealing and such from the belt area of the Wing. I have to do a great deal of stop start low speed up hill riding at the moment. (Courtesy of the road works pre Olympics Evil or Very Mad ).
I did try the holding front brake and revving as previously mentioned and it works for a while, but the persistent stop start on hills makes the squeal return within a week.
The Wing was recently serviced and asked them to examine the belt etc and all appeared OK so I put the noise down to the road works.
(Roll on 2012)
» Squealing Noise?
» Need some information on issues with vacuum
» Squeaking & Dragging Noise
» Givi AF214 Squeaking Noise
» Common Silverwing Sounds and behaviors
