Stronger seat strut replacement I_icon_minitimeby JohnyC Today at 5:39 am
Stronger seat strut replacement I_icon_minitimeby JohnyC Yesterday at 10:04 am
Stronger seat strut replacement I_icon_minitimeby JohnyC Tue Nov 19, 2024 4:42 am
Stronger seat strut replacement I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Stronger seat strut replacement I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Stronger seat strut replacement I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Stronger seat strut replacement I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Stronger seat strut replacement I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Stronger seat strut replacement I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Stronger seat strut replacement I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
Stronger seat strut replacement Empty
PostSubject: Stronger seat strut replacement   Stronger seat strut replacement I_icon_minitimeSun Sep 12, 2010 12:29 am
Here is an reducible force strut that can handle up to 90 lbs.
http://www.mcmaster.com/
6465K12 Reducible-Force Gas Spring 3.94" Stroke, 90 lbs Max Force, M5 Male Thread Sz
1 x $31.36 = $31.36
6465K25 Nylon Eyelet End Fitting for .59" Cylinder Dia Reducible-Force Gas Spring
2 x $1.20 Each = $2.40
These do not appear in the their catalog, but they do sell it.
The two original bushings won't fit inside the new eyelets so use two 1/4" flat washers instead.
The new strut comes overcharged so you have to let some of the nitrogen out to adjust the force by backing out a tiny hex screw. You have to be careful or you can release too much pressure ... the strut is worthless.
Just in case these are not available here are some measurements of the original strut with digital calipers
Strut
A = ( B + C ) = ( 5.708 + 4.224 ) == 9.932 inches
Total length of strut (base of eyelet to base of eyelet)
B = 5.708 inches
Length of gas strut (base of eyelet to end of gas cylinder)
C = 4.224 inches
Length of shaft (base of eyelet to base of gas cylinder)
D = 0.239 inches
Width of shaft
E = 0.600 inches
Width of gas cylinder
Eyelet
F = 0.430 inches
Length of eyelet from top of eyelet to center of eyelet (approximation of center)
G = 0.610 inches
Length of eyelet from base of eyelet to center of eyelet (approximation of center)
H = 0.326 inches
Width of eyelet
» Stronger seat lift piston thingy.
» Strut too strong?
» Seat strut help please
» Seat Modification: Car seat substitution
» Seat piston thingy
