| MRP Roller Weights | |
+3honda_silver Sweendog DennisB 7 posters |
| Subject: MRP Roller Weights Fri Oct 08, 2010 7:41 pm | |
| Has any one givin these a try? The price is right, $29.99 free shipping.
http://www.scooterdynasty.com/slidingweightsdrpulley28mmx20mm400cc-600cc-1.aspx
Just found the name: MARTIN RACING PERFORMANCE |
Sweendog Maxi-Scooter Rider
Number of posts : 154 Location : South New Jersey Points : 5779 Registration date : 2009-07-12
| Subject: Re: MRP Roller Weights Fri Oct 08, 2010 11:47 pm | |
| Haven't heard of anyone trying those yet. I'll probably just get stock weights from Ron Ayers, for $20.63 + shipping (prob. around $5). |
| Subject: Re: MRP Roller Weights Sat Oct 09, 2010 2:55 am | |
edbancro Maxi-Scooter Rider
Number of posts : 160 Location : Western Pennsylvania Points : 5684 Registration date : 2009-10-30
| Subject: Re: MRP Roller Weights Sat Oct 09, 2010 11:04 am | |
| - Sweendog wrote:
- Haven't heard of anyone trying those yet. I'll probably just get stock weights from Ron Ayers, for $20.63 + shipping (prob. around $5).
I've been thinking about buying lighter rollers/sliders, but given that the stock weights are cheaper than anything else out there, now I think I'll just try to bore out a set of stock rollers to lower the weight. I've never actually looked a the stock weights, but based on the pictures it looks like there's enough material that one could remove a couple of grams by enlarging that center hole and not cause any structural integrity issues. And since people have mixed 21g and 28g weights without any apparent issues, it wouldn't have to be super precise - within 1g or so of each other should be fine. Anyway, it's a idea... |
| Subject: Re: MRP Roller Weights Sat Oct 09, 2010 11:47 am | |
Anyway, it's a idea... I thought about that also but for $29.99 you save time, headaches and ware and tear on my lathe cutting bits, on harden metal and hoping I get the weight correct. |
| Subject: Re: MRP Roller Weights Sat Oct 09, 2010 1:09 pm | |
| - DennisB wrote:
- I thought about that also but for $29.99 you save time, headaches and ware and tear on my lathe cutting bits, on harden metal and hoping I get the weight correct.
I definitely agree on the time and headache aspects, but Dr. Pulley's put down of the MRP products in the post Bill referenced does make me wonder what the long term effects of using some of these aftermarket rollers - maybe Dr. Pulley's aren't so great either for all we know. Obviously the only way we'll really know about any of these brands is if someone is willing to try them and see what happens long term (like the oddities that can show up when the J Costa pins wear down), but for those who aren't willing to risk other components, modifying the stock rollers would give more assurance that at least they won't wear any faster... As far as the tools to use and getting the weight correct, I was thinking about just taking my time with some coarse sandpaper or a brake cylinder hone, and my wife has a kitchen scale that claims 1g precision. Anyway, I'm mostly just 'thinking out loud' here. If I have time over my winter break I may try it and see how it turns out. |
| Subject: Re: MRP Roller Weights Sat Oct 09, 2010 1:16 pm | |
| I would suggest contacting Paul Wu ( unionltd@ms14.hinet.net ) from Dr Pulley.
They have provided Dr Pulley Slider weights of 21 gram 26 gram 28 gram 31 gram
It looks like they customize the weights by changing the metal that is inserted inside the Slider weights. So I would be surprised to find they may have a solution for you. |
| Subject: Re: MRP Roller Weights Sat Oct 09, 2010 1:53 pm | |
Anyway, I'm mostly just 'thinking out loud' here. If I have time over my winter break I may try it and see how it turns out. Going to give them a try. I ordered a set of MRP Rollers, yesterday, in 21gr. If any one wants the other 4 new MRP 21gr. un-used rollers from this set, please PM me $16.00 |
MaxB Touring Scooter Rider
Number of posts : 302 Age : 73 Location : Indiana Points : 5885 Registration date : 2009-10-06
| Subject: Re: MRP Roller Weights Sat Oct 09, 2010 4:41 pm | |
| as far as trying to turn weights on a lathe, having weights from Reflex, S'wing, and Chinese brand. sitting in the garage. I thought about that for lower weights. I could not figure out how to hold them, The brass is encapulated by some synthetic plastic. The brass spins inside of the plastic. I guess you could hold the inner and turn around after cut. But looks too hard to do. easier to just buy new ones in the weight you want.
Note: Dr Pulley sliders are a harder plastic. I havent seen any wear in reflex after 10K miles. Also the plate guides are the same material and used OEM since two broke. they were too brittle for that app , as far as I am concerned.
MaxB (who took the easy way and bought new) |
| Subject: Re: MRP Roller Weights Thu Oct 14, 2010 3:03 pm | |
| OK...Just installed 4 MRP 21gr rollers with 4 28gr Dr. Pulley sliders.....WOW, what a difference and smoother...alot smoother!
There was a... what seemed like, a flat spot in the amount of power at between 50 to 70 MPH. Now that's gone.
Big gain in performance with a increase of only a small RPM of .2K at 70 MPH indicated.
I'm going to stick with this combination for awhile. I like it
Just thought you might be interested. |
masscoot Silver Wing Rider
Number of posts : 438 Location : Central New England Points : 6181 Registration date : 2009-03-24
| Subject: Re: MRP Roller Weights Fri Oct 15, 2010 8:37 am | |
| I have enjoyed the added performance, and I don't miss that flat spot around 40! I would like to try all 21g sliders, some say the ride was scarry. The price makes this a good value for the return in responsiveness. I have been saving the second set of 21gx28g to use when this set wears out. Some have reported the JCosta pins wearing at around 10K, we will have to see how much longer the Dr. Pulley sliders last before replacement is needed. Using the dry lube also adds some smoothness to the system. |
| Subject: Re: MRP Roller Weights Fri Oct 15, 2010 8:49 am | |
| I put dr. Pulley slider in one of my reflexes and they look like new at 10k miles
maxB |
| Subject: Re: MRP Roller Weights Fri Oct 15, 2010 9:29 am | |
| Installed a combination of 4 rollers and 4 slider. Just thought I'd give it a try, I like it. Sure made a big difference.
With this set of MRP rollers for $29.99, you only get 6 rollers but that's OK with me...I only needed 4. |
| Subject: Re: MRP Roller Weights Fri Oct 15, 2010 10:26 am | |
| - MaxB wrote:
- I put dr. Pulley slider in one of my reflexes and they look like new at 10k miles
maxB I fugured the wear would be less, thanks for the info Max. I have less than 5K on mine now and the still look new. |
| Subject: Re: MRP Roller Weights Sun Oct 17, 2010 10:13 pm | |
| - Quote :
- With this set of MRP rollers for $29.99, you only get 6 rollers but that's OK with me...I only needed 4.
Isn't MRP the same folks who were passing off counterfeit Dr Pulley Sliders as the real deal last year? And now they're marketing their own branded Rollers for the Silverwing but only sending 6 of the 8 rollers needed for the Silverwing variator. Unless they are selling the rollers piece by piece it sure doesn't sound as if they're a reputable source to me. Caveat Emptor Tim |
