First topic message reminder :The Perfect Connector – The safe way to connect extra rear scooter lights.
A great little pig tail connector that allows a person to install trailer lights or Top Box lights without cutting into your very expensive Honda wiring cable. Just un-plug your Honda rear lights connector and then plug in the Perfect Connector and you have all your wires to connect to. Brake, Running, Left and Right, and Ground wires.
Comes with 12” wire leads and instruction sheet to help you with hook-up.
$32.00 USD w/free shipping to the lower 48, $3.50 USD International (First Class)
OR If you need a different configuration for the installation of a Brake Light Flasher Unit (comes with crimp type wire splices for easy hook-up) on Red, Black, and White lead wires.
Red = Brake signal in (from bike).
Black = Flashed Brake signal out (to lights).
White = Ground wire.
