relay converter I_icon_minitimeby balconio Today at 7:24 pm
relay converter I_icon_minitimeby zrx212 Yesterday at 4:40 pm
relay converter I_icon_minitimeby Meldrew Yesterday at 4:37 pm
relay converter I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
relay converter I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
relay converter I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
relay converter I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
relay converter I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
relay converter I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
relay converter I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
 relay converter
4 posters
grizzly
grizzly
Number of posts : 19
Registration date : 2010-05-29
relay converter Empty
PostSubject: relay converter   relay converter I_icon_minitimeWed Mar 16, 2011 7:41 pm
Hi! to All
I was just wondering if I need a relay light converter on the perfect connecter to connect a motorcyle trailer with a 4 pin light connecter.
thanks.
Number of posts : 2778
PostSubject: Re: relay converter   relay converter I_icon_minitimeWed Mar 16, 2011 7:50 pm
Hi Grizzly,
What's are the 4 wires? The Perfect connector has 5 wires that are deticated and match the lights that are used on the Silverwing. Sounds like your trailer is set up for a truck or car plug. You can get a 5 pin plug at the auto parts store.
grizzly
grizzly
PostSubject: Re: relay converter   relay converter I_icon_minitimeWed Mar 16, 2011 8:02 pm
OK! thanks. DennisB
But I might use the trailer on my truck wich he has a 4 pin connecter to. So if the wing has a 5pin connecter that means it runs all the wire lights individually.l then I will need a relay concerter. Right or Wrong.
PostSubject: Re: relay converter   relay converter I_icon_minitimeWed Mar 16, 2011 8:42 pm
Sounds like the relay light converter would be the winning ticket. What unit are you thinking about getting for the SWing?
Here's one that looks good. Off Ebay and is $17.99:
http://cgi.ebay.com/5-Pole-4-Pole-Trailer-Converter-NEW-/400198616026?pt=LH_DefaultDomain_0&hash=item5d2db243da
Number of posts : 341
PostSubject: Re: relay converter   relay converter I_icon_minitimeThu Mar 17, 2011 11:03 am
One other possible problem to consider is the load on the Silverwing wiring. An isolation harness protects the bike's wiring from load issues and problems in the trailer wiring, shorts, grounds, etc. Without the isolator, the bike's wiring is at risk from different problems.
There are a few units to choose from, my other bike has the unit from Lewis Preston, Son of the founder of Bustec trailers and all around good guy.
http://www.electricalconnection.com/wire-harnesses/hrns-trailer.htm
PostSubject: Re: relay converter   relay converter I_icon_minitimeThu Mar 17, 2011 7:25 pm
This is the wiring that I have ... which ws before DennisB made his wiring.
grizzly
grizzly
PostSubject: Re: relay converter   relay converter I_icon_minitimeThu Mar 17, 2011 7:44 pm
Hi! Again.
Thanks for the reply. So honda_silver you are saying that DennisB perfect connecter will be ok with the trailer converter that he mention in is post from ebay.
Thanks.
PostSubject: Re: relay converter   relay converter I_icon_minitimeThu Mar 17, 2011 9:14 pm
Either way you will want to fuse each wire separately (except ground) to isolate the original OEM wiring.
Here is the trailer 4 pin detail
1) right turn signal / stop light (green)
2) left turn signal / stop light (yellow)
3) taillight / license / side marker (brown)
4) ground (white).
Here the OEM detail
a) Lb (Light Blue) - Right Rear Turn Signal
b) Orange (Orange) - Left Rear Turn Signal
c) Bl/Br (Black/Brown) - Running Lights
d) G (Green) - Frame Ground
e) G/Y (Green/Yellow) - Brake lights
You will need a relays to combine the a/e wires for the right turn/brake AND b/e for the left turn/brake in order have both turn signal and brake lights. You would also want to make sure that the turn signal has preference over the brake light to ensure you still have turn signals while hitting the brake.
I would think this would be very easy for DennisB to do. Or http://www.electricalconnection.com/wire-harnesses/hrns-trailer.htm ( p/n 07664 ).
Here is my wiring detail ( https://www.silverwing600.com/t1417-parallel-wiring?highlight=parallel+wiring#11592 ).
PostSubject: Re: relay converter   relay converter I_icon_minitimeThu Mar 17, 2011 11:00 pm
Hey grizzly,
Do you feel that your question was answered properly?
OR
Do feel that you received enough help to get the job done correctly?
OR
Do you now have more questions and that little voice inside your head saying: WHAT HELL WAS ALL THAT CRAP?
grizzly
grizzly
PostSubject: Re: relay converter   relay converter I_icon_minitimeFri Mar 18, 2011 6:46 pm
I do not know anymore.Little bit confuse but thats is ok!I think I will stay with your idea the trailer converter.I think is simple and less confusing.I think I will go whit that one. http://www.reese-hitches.com/products/Taillight_Converter,119130
Thanks.
relay converter
» Driving light relay hot
» Starter lights cut off relay
» Where is the Fan Motor relay located?
» Location of fuel pump relay
» turn signal flasher relay location
