AAAA Silver Wing Rider
Number of posts : 442 Points : 5615 Registration date : 2010-11-14
| Subject: LH cubby acc. socket Sun Apr 03, 2011 1:02 pm | |
| Is there anywhere close i can tap power for the acc. socket? |
Number of posts : 2600 Age : 65 Location : Bay Area, Ca Points : 8640 Registration date : 2008-12-19
| Subject: Re: LH cubby acc. socket Sun Apr 03, 2011 1:09 pm | |
| DennisB has fabricated a connector that will fit right in with the headlight wiring. Please correct me if I'm wrong Dennis. It is good for about 4 amps of power I believe so if you need more than that, for heated clothing or something, then you need to run a wire from the battery. Is this just for a gps or something that only needs a small amount of amps? |
Number of posts : 2778 Age : 74 Location : NE Oklahoma Points : 9063 Registration date : 2008-12-28
| Subject: Re: LH cubby acc. socket Sun Apr 03, 2011 1:57 pm | |
| Hi Guys, Yes, The Quick Headlight Power Connector (pigtail) is for connecting low amp draw accessories 4-5 amps Max. I have 2 power outlets installed on my scooter. One in the left glove box and one in the center of my dash, just about 6" below my on/off key position. Both are wired to the battery and are combine into a 15 amp fuse and on a single relay under the left rear cover. The center outlet is meant for heated apparel. Just under the center glove box. |
| Subject: Re: LH cubby acc. socket Sun Apr 03, 2011 4:57 pm | |
| Yea, its just for charging my new garmin nuvi 1100. $68 bucks at wal mart today, if anyone interested. Can i get a wire color and location ref? Being an r/c electronics guy, i can tap and solder with the best of them! |
Number of posts : 2387 Location : Winnipeg Points : 7872 Registration date : 2010-05-02
| Subject: Re: LH cubby acc. socket Sun Apr 03, 2011 6:52 pm | |
| Tagg: If you want to tap into your low beam headlight power, remove the windshield garnish, and pull the connector from the upper bulb. Use the white wire for power and any ground wire that's close. |
