| TORX socket | |
+6jmaslak bigbird model28a Old Limey Mudnman john grinsel 10 posters |
Number of posts : 3313 Age : 85 Points : 9461 Registration date : 2009-08-18
| Subject: TORX socket Sun Jan 26, 2014 7:29 pm | |
| In prepping new tool kit for my new SilverWing----discover front axle pinch bolts are now TORX T 5..... on my previous SilverWing I think they were allen head?? Going thru the bike, I found many bolts overtightened-----non-JIS/Japanese screwdriver used on battery box cover----screw already screwed up---replaced with regular head bolt----anyway angle to get at it better with box wrench or socket.
Looks like somebody used impact wrench on some nuts and bolts.
Rear axle nut---so tight 1/2 drive socket and breaker bar, standing on it will not come off----taking it back to dealer in the AM---let them figure out
Enjoy the new bike-----but Burgman had easier to use and bigger under seat storage/outside temp gauge/MPG display. SilverWing handles better and buffeting with stock windshield better than Suzuki with stock shield
My GIVI scooter "Tank bag" fits well----I do not use straps but industrial Velcro to hold it on=works.
End: Glad I do not have to depend on dealer to get things right! |
Mudnman Super Scooter Rider
Number of posts : 218 Location : Florida Points : 4202 Registration date : 2014-01-15
| Subject: Re: TORX socket Sun Jan 26, 2014 8:32 pm | |
| Yah, impact= on =fast in-out work That tight nut standing on breaker bar needed a bounce on the bar.Sounds like 200 ft.lbs Your smart for checking things out at home .Hello AAA I need an impact.lol |
Old Limey Silver Wing Expert
Number of posts : 921 Age : 80 Location : BOLTON LANCASHIRE ENGLAND Points : 6292 Registration date : 2010-06-09
| Subject: Re: TORX socket Tue Jan 28, 2014 12:36 pm | |
| I have not trusted a dealer to do anything right for at least 20yrs. I once bought a new Honda Superdream 250. On the first "Free " service i was charged £25, i asked what for and they said oil was £20 ( you could buy 10/40w semi- syn for £15- 5 litres or 1gallon as it was then) the bike used 2litre max. What was the other £5 for? ancillaries, explain i said, well oiling the cables and topping up the brake fluid. I have never had a bike serviced by a dealer since. If i do it, I know it's done, and my life may depend on something "they "forgot to do. I had to get a torx set of male sockets. the suspension arm at the engine side has two torx bolts. |
Number of posts : 2085 Age : 71 Location : St.Pete.FL. Points : 7554 Registration date : 2010-02-03
| Subject: Re: TORX socket Tue Jan 28, 2014 4:46 pm | |
| I had dealer fix scooter after a hit and run put me down. I was in hospital and insurance paid so I thought I might as well have it ready when I healed. When I got it back it had no front reflectors. They said there weren't any on when it came in. I told them I purchased the scooter from them and I hadn't taken them off and asked them if would sell a scooter or bike without something required by law. They reluctantly ordered them and put them on when they came in, never found out what happened to the old ones. Next and last time I took it to them was when they had a sale if you bought a set of tires they would mount them for free. When I got my scooter back they had taken the Honda weights off and put stick on weights on. I did not get my old weights back and I didn't notice right away so I didn't bother to go back to ask for them. (if you look them up they are not cheap) Now the next time I change tires I will have to buy new weights. I will have to buy an assortment ahead of time so I don't have to wait for them to come in. |
Number of posts : 2387 Location : Winnipeg Points : 7903 Registration date : 2010-05-02
| Subject: Re: TORX socket Tue Jan 28, 2014 5:46 pm | |
| - model28a wrote:
- When I got my scooter back they had taken the Honda weights off and put stick on weights on. I did not get my old weights back and I didn't notice right away so I didn't bother to go back to ask for them. (if you look them up they are not cheap) Now the next time I change tires I will have to buy new weights. I will have to buy an assortment ahead of time so I don't have to wait for them to come in.
Hey Roger. Be glad they used stick on weights. Aluminum wheels, whether car, motorcycle, or scooter, should never use squeeze on weights on the visible side of the wheel. They'll leave an ugly scar on the cast wheels. |
| Subject: Re: TORX socket Wed Jan 29, 2014 2:57 am | |
| bigbird I'm sure you are right and if I ever wash my rims I'll probably see the damage. I did like how they distributed the weight equity on both sides of the rims. I guess what made me mad was they didn't give my weights back and I paid a good bit for them. |
| Subject: Re: TORX socket Wed Jan 29, 2014 8:10 am | |
| On wheel weights----Use "Ride On" @ about $15 per wheel each time tire is changed----not only balances wheel and tire WELL but can act as sealant as well. Not too messy when tire is removed from rim---So Ride ON=NO wheel weights.
Most shops do not do real good job of balancing scooter wheels/tires, anyway, especially 13" rear. I recently got over 30,000 miles from front Bridegstone Hoop that was balanced with Ride On.
Weights are considered throw away in shop.
Do own tire work=done right and good exercise.
| Subject: Re: TORX socket Wed Jan 29, 2014 12:36 pm | |
| Each time i have a new tyre fitted, i take the wheel with tyre to the tyre people and watch them remove the old tyre, clean the rim, fit new tyre and valve and balance the wheel. They always use the stick on weights and i have never had a problem. |
jmaslak Super Scooter Rider
Number of posts : 252 Location : Golden, CO, USA Points : 4806 Registration date : 2012-06-15
| Subject: Re: TORX socket Wed Jan 29, 2014 9:06 pm | |
| I'm not a fan of the tire sealants - I think they work simply by increasing the weight of the wheel fairly uniformly, making imperfections smaller in relation to the total weight of the tire. I don't think they distribute the goop where the weight is light. Besides, whenever I think of what an out-of-balance wheel would do, I think the goop would collect where the wheel is already heaviest (like a drum in a washing machine that is out of balance collects more, not less, stuff as in the heavy spot as it spins). But from experience, I know it seems to help people (experience with balance beads, not goop, but I think the principle is the same), I think because of this making the whole wheel heavier thing, but it doesn't help as much as actually balancing the wheel. If you've ridden both, you won't go back to goop and beads. I also find it interesting that I've never found a two wheel or four wheel OEM that delivers a vehicle with goop or beads in the wheels. I'm sure it's a conspiracy, but... |
Colin B Silver Wing Expert
Number of posts : 586 Age : 72 Location : Windsor, UK Points : 4908 Registration date : 2013-03-20
| Subject: Re: TORX socket Thu Jan 30, 2014 2:25 am | |
| Tyre sealant is NOT a substitute for wheel balancing. It's for sealing small punctures!
Number of posts : 2940 Age : 75 Location : Winnsboro, Texas, U.S.A. Points : 8554 Registration date : 2010-02-17
| Subject: Re: TORX socket Thu Jan 30, 2014 3:24 am | |
| And another thread becomes unbalanced and spins out of control!!! |
Number of posts : 4218 Location : York, North Yorkshire, England UK Points : 9442 Registration date : 2010-11-16
| Subject: Re: TORX socket Thu Jan 30, 2014 4:11 am | |
| What about Dyna Beads, more junk you stuff into your tyres that claims to 'balance' the wheels. |
Dimond Silver Wing Expert
Number of posts : 540 Age : 79 Location : San Francisco Bay Area Points : 5529 Registration date : 2011-08-07
| Subject: Re: TORX socket Thu Jan 30, 2014 1:26 pm | |
End: Glad I do not have to depend on dealer to get things right! I have (so far) purchased two used SWings - a 2003 and a 2008. BOTH had bolts that were WAY over-torqued - especially the oil drain plug on the bottom of engine case and the rear axle bolt - so tight that I was worried that some damage may have been done to threads - hard to tell. I do my own maintenance and all bolts come off easily as they are being torqued properly. Suggest that any any of you not using torque wrenches consider doing so. Like the idea of the GIVI tank bag with Velcro! Any pictures? Do you take it off much or do you typically just leave it on? Thanks for your feedback John - good luck with your new SWing! |
| Subject: Re: TORX socket Thu Jan 30, 2014 2:27 pm | |
| GIVI Bag=I only use it when I need extra carrying space---it ruins the step thru feature of scooter and must come off at each fuel stop. SilverWing is well balanced and good handling....my Burgman 400 poorly balanced front to rear so bag moved weight forward on long trips==I am cheap and carry WalMart water along and in the bag it went |
| Subject: Re: TORX socket Thu Jan 30, 2014 10:11 pm | |
| Hah I had to use a breaker bar to get oil drain cap off the 08 I just bought.The varo was over 100 ft lbs.It has new tires on it so bet that's tighter than called for too. |
| TORX socket | |
