Swingarm Torx Bolt Sixe I_icon_minitimeby balconio Today at 7:24 pm
Swingarm Torx Bolt Sixe I_icon_minitimeby zrx212 Yesterday at 4:40 pm
Swingarm Torx Bolt Sixe I_icon_minitimeby Meldrew Yesterday at 4:37 pm
Swingarm Torx Bolt Sixe I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Swingarm Torx Bolt Sixe I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Swingarm Torx Bolt Sixe I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Swingarm Torx Bolt Sixe I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Swingarm Torx Bolt Sixe I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
Swingarm Torx Bolt Sixe I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
Swingarm Torx Bolt Sixe I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
4 posters
thecruiser
Number of posts : 57
Registration date : 2021-03-16
Swingarm Torx Bolt Sixe Empty
PostSubject: Swingarm Torx Bolt Sixe   Swingarm Torx Bolt Sixe I_icon_minitimeWed Jun 09, 2021 9:00 pm
I'm in the process of putting a new rear tire on my Scoot. I've scoured the Service Manual and cannot find the size of the Torx bolts. I know using the wrong size can screw them up so I'm leaning again on the experience of others.
If you've removed the rear wheel on your SWING, what size Torx did you use?
Larry K. (thecruiser)
Number of posts : 1384
PostSubject: Re: Swingarm Torx Bolt Sixe   Swingarm Torx Bolt Sixe I_icon_minitimeWed Jun 09, 2021 9:44 pm
I'm not sure of the size T40-45 but you don't need remove them to get right side of swing arm off to remove wheel. Under that plastic cover are 2 14MM bolts that's all you need to remove and there's just enough room to free it up. Holder Bolts. Splitting that right swing arm that pivots from engine case can be difficult 3 bolts from left side and dowel pins like to stick.
thecruiser
PostSubject: Re: Swingarm Torx Bolt Sixe   Swingarm Torx Bolt Sixe I_icon_minitimeThu Jun 10, 2021 5:44 am
Thanks SWG. I'll try that. I realize there are 'short-cuts' that can be made from instructions given in Service Manuals sometimes. This apparently is one of them. The way the Manual reads, I thought the forward part of the Right Swingarm needed to be removed too.
Yesterday I replaced the belt and the variator rollers with Dr Pulley sliders. (24gm) While there, I also removed the driven pulley and cleaned up the glaze from the clutch shoes. So far I've been pretty impressed with the condition of the bearings and slide areas. For a scoot with 41,000 miles, things haven't been too bad. A good cleaning mostly was all that was needed.
As I was finishing a rain-storm hit so I didn't get a chance to 'test-drive' the repairs. Will do that today. My rear tire isn't due to arrive until Friday. Weather permitting, maybe I'll get it off and the new tire installed. Having been a long-time Darksider with my GoldWing, the rear tire ordered was a 155/70R13 CT.
1Wingman1
Number of posts : 126
Registration date : 2013-01-19
PostSubject: Re: Swingarm Torx Bolt Sixe   Swingarm Torx Bolt Sixe I_icon_minitimeThu Jun 10, 2021 4:31 pm
For future reference the torx heads are size T-50.
thecruiser
PostSubject: Re: Swingarm Torx Bolt Sixe   Swingarm Torx Bolt Sixe I_icon_minitimeThu Jun 10, 2021 4:53 pm
Thanks Wingman. I'll make note for future reference.
PostSubject: Re: Swingarm Torx Bolt Sixe   Swingarm Torx Bolt Sixe I_icon_minitimeThu Jun 10, 2021 5:57 pm
Darksider tire. They do last much longer than cycle tires though.
Important thing is the alignment of parts get the wheel back on axle bolt snugged a bit and shock bolted up then torque the holder bolts. Last thing I torque is the axle nut.
thecruiser
PostSubject: Re: Swingarm Torx Bolt Sixe   Swingarm Torx Bolt Sixe I_icon_minitimeThu Jun 10, 2021 6:36 pm
Makes sense to me.
Number of posts : 3313
PostSubject: Re: Swingarm Torx Bolt Sixe   Swingarm Torx Bolt Sixe I_icon_minitimeFri Jun 11, 2021 10:14 am
Guess with car tires, you do not go around corners.
» TORX socket
» RH SWINGARM FRONT PIVOT BEARING
» removable swingarm won't come off
» Swingarm torque question
» Swingarm seal removal
