Anyone tried using this on your 12v socket? (water boiler!) I_icon_minitimeby balconio Yesterday at 7:24 pm
Anyone tried using this on your 12v socket? (water boiler!) I_icon_minitimeby zrx212 Sat Nov 16, 2024 4:40 pm
Anyone tried using this on your 12v socket? (water boiler!) I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Anyone tried using this on your 12v socket? (water boiler!) I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Anyone tried using this on your 12v socket? (water boiler!) I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Anyone tried using this on your 12v socket? (water boiler!) I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Anyone tried using this on your 12v socket? (water boiler!) I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Anyone tried using this on your 12v socket? (water boiler!) I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
Anyone tried using this on your 12v socket? (water boiler!) I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
Anyone tried using this on your 12v socket? (water boiler!) I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
pjas1969
eddy
Swinger_FJS400
Swinger_FJS400
Swinger_FJS400
Number of posts : 19
Registration date : 2013-03-07
Anyone tried using this on your 12v socket? (water boiler!) Empty
PostSubject: Anyone tried using this on your 12v socket? (water boiler!)   Anyone tried using this on your 12v socket? (water boiler!) I_icon_minitimeTue Mar 26, 2013 11:02 pm
Question Am curious if any of these can be used on our bikes 12v socket ?
Anyone tried using this on your 12v socket? (water boiler!) Travel-water-heating-element
I bought one from a local DIY store but it did not state any spec or Watt requirement.
eddy
Number of posts : 187
PostSubject: Re: Anyone tried using this on your 12v socket? (water boiler!)   Anyone tried using this on your 12v socket? (water boiler!) I_icon_minitimeWed Mar 27, 2013 1:32 am
I doubt...
1- Measure the resistance value of the tool.( Ohm )
You can (let) do it with any cheap digital measurement instrument.
Then we have a idea what load (Ampere) the tool will pull out of the 12V socket.
2- Find out the fuse value that protect your 12V socket.
I will vote for a camp cook burner on gasoline.
Eddy
http://edho@operamail.com
pjas1969
Number of posts : 31
Registration date : 2013-03-12
PostSubject: Re: Anyone tried using this on your 12v socket? (water boiler!)   Anyone tried using this on your 12v socket? (water boiler!) I_icon_minitimeWed Mar 27, 2013 4:30 am
I'd say not - the amount of energy required to boil even a cup of water would blow a fuse.
Power sockets in cars & trucks are intended to run 2-3 gadgets simultaneously, whereas for the bike, it'll be sat-nav or phone (much lower current draw).
Paul
http://www.carwizard.ltd.uk
tarmacburner2
tarmacburner2
Number of posts : 1099
PostSubject: Re: Anyone tried using this on your 12v socket? (water boiler!)   Anyone tried using this on your 12v socket? (water boiler!) I_icon_minitimeWed Mar 27, 2013 6:15 am
I tried one of these in a car once, it would have been quicker stirring the water with a stick to get the water hot enough for a cup of coffee.
A lot of power and could actually drain the battery unless you have the engine running whilst using it.
Try something like this...
http://www.thebushcraftstore.co.uk/swiss-gel-fuel-stove-112-p.asp
Small kettle or metal mug is all you need.
Cheers,
Swinger_FJS400
Swinger_FJS400
PostSubject: Re: Anyone tried using this on your 12v socket? (water boiler!)   Anyone tried using this on your 12v socket? (water boiler!) I_icon_minitimeFri Mar 29, 2013 12:23 am
Thanks for the input folks!
Ive since perish the idea of trying it on my scoot
@ Paul : I guess that make sense. Ive found my stand alone bike battery and in the process of charging it up to see if the boiler indeed work or how much it draws.
@eddy : Ive dismantle the boiler, there are no fuse in the connecting socket lol
@ tarmacburner2 : Did it actually boil the water when u stir it? I read some are just warmer. Ive got that solid fuel burner, was tickering with this due to the small space it takes up.
KurtPerthWA
KurtPerthWA
Number of posts : 1711
PostSubject: Re: Anyone tried using this on your 12v socket? (water boiler!)   Anyone tried using this on your 12v socket? (water boiler!) I_icon_minitimeFri Mar 29, 2013 12:37 am
I've used a similar gadget but in a kettle shape in a car. It took more than 20 minutes to be able to get it hot enough to dissolve instant coffee. They run less than 10 amps (fused) and probably around 5 or 6 amps. The socket in the glovebox is rated to 1 amp max.
Tarmac's idea is good, but I would get a coffee from a reputeable vendor.
tarmacburner2
tarmacburner2
PostSubject: Re: Anyone tried using this on your 12v socket? (water boiler!)   Anyone tried using this on your 12v socket? (water boiler!) I_icon_minitimeFri Mar 29, 2013 5:49 am
No just my sense of humour!
Cheers,
KurtPerthWA
KurtPerthWA
PostSubject: Re: Anyone tried using this on your 12v socket? (water boiler!)   Anyone tried using this on your 12v socket? (water boiler!) I_icon_minitimeFri Mar 29, 2013 9:16 am
"No just my sense of humour!"
Thanks Tarmie you just made my day.
Swinger_FJS400
Swinger_FJS400
PostSubject: Re: Anyone tried using this on your 12v socket? (water boiler!)   Anyone tried using this on your 12v socket? (water boiler!) I_icon_minitimeFri Mar 29, 2013 11:39 pm
hahaha I got caught by tarmacburner2 Embarassed ..nice one!
I went ahead and connect the boiler to my other bike without cranking ...it gets the water quite hot until the led light on the 12v socket went off and the battery went down. Jump started the bike ....
Going to try again with engine running...
KurtPerthWA
KurtPerthWA
PostSubject: Re: Anyone tried using this on your 12v socket? (water boiler!)   Anyone tried using this on your 12v socket? (water boiler!) I_icon_minitimeFri Mar 29, 2013 11:54 pm
Dont forget the power plug is only good for 1 amp. Read your owners manual..it suggests damage to other components if you exceed this. It is better to jump it straight off the battery by installing a 10 amp cig socket in the tupperware. correctly set up with an isolator switch you can also charge the battery via this socket and run other 12 volt goodies like a tyre compressor, trouble lamp etc.
Swinger_FJS400
Swinger_FJS400
PostSubject: Re: Anyone tried using this on your 12v socket? (water boiler!)   Anyone tried using this on your 12v socket? (water boiler!) I_icon_minitimeSat Mar 30, 2013 12:03 am
Thanks Kurt.
I read the manual on my cb250 and it says the total power generated is 190w when running but Im nuts with calculating how much goes to the head light (35w bulbs) and tailight and stuff..
The old bike cig socket has a 10a fuse and connect directly to the battery with a on off switch. Im going to connect a multimeter to monitor it when I next try. Smile
Number of posts : 2392
PostSubject: Re: Anyone tried using this on your 12v socket? (water boiler!)   Anyone tried using this on your 12v socket? (water boiler!) I_icon_minitimeSun Mar 31, 2013 8:10 am
Have to ask; why would you need one? silent
Take a thermos!!!! cheers
Number of posts : 4218
PostSubject: Re: Anyone tried using this on your 12v socket? (water boiler!)   Anyone tried using this on your 12v socket? (water boiler!) I_icon_minitimeSun Mar 31, 2013 10:17 am
I first came across those water heaters fitted with a 2-prong Continental plug 40 years ago. In Germany a lot of squaddies had them in their barrack- rooms to make a quick brew in a mug. I've got one I occasionally carry in my touring kit as a lot of German hotels and pensions don't have a hospitality tray with a kettle and stuff for making a hot drink.
» Water Pump
» Water pump gasket
» ARRGH!! What!!
» Installing DC socket
» TORX socket
