Water Pump I_icon_minitimeby Meldrew Today at 8:01 am
» Rear wheel valve stem
Water Pump I_icon_minitimeby GHM-PM Today at 6:43 am
Water Pump I_icon_minitimeby COMick Fri Nov 22, 2024 6:13 pm
Water Pump I_icon_minitimeby xwelder Fri Nov 22, 2024 12:31 pm
Water Pump I_icon_minitimeby sonuvabug Thu Nov 21, 2024 4:17 pm
Water Pump I_icon_minitimeby JohnyC Wed Nov 20, 2024 10:04 am
Water Pump I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Water Pump I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Water Pump I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Water Pump I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
 Water Pump
Gerritwillemnz
Gerritwillemnz
Number of posts : 14
Registration date : 2020-04-04
Water Pump Empty
PostSubject: Water Pump   Water Pump I_icon_minitimeSun Apr 05, 2020 5:33 pm
Hi From New Zealand Silverwing fans.
I have just bought a 2001 400 cc sight unseen via auction.
It runs well great fun to ride.
I just found the water reservoir for the radiator. It was empty, zero fluid.
I filled it with water (I’ll replace with coolant later) no leaks. I ran it for 5 or 6 min and it didn’t over heat. The radiator didn’t warm up ?
Does the radiator get hot?
How do you test the water pump?
Should I. Be concerned?
Cheers
Gary
Water Pump Empty
PostSubject: Re: Water Pump   Water Pump I_icon_minitimeSun Apr 05, 2020 5:56 pm
Hello Gary
Have you filled the radiator? The radiator cap is located by removing the right cubby pocket and looking underneath there and toward the center of the bike.
You look down in that cubby space to locate the coolant reservoir. But you already know that by now.
Gerritwillemnz
Water Pump Empty
PostSubject: Re: Water Pump   Water Pump I_icon_minitimeSun Apr 05, 2020 6:03 pm
I’ll check that
Thanks
Number of posts : 1384
Water Pump Empty
PostSubject: Re: Water Pump   Water Pump I_icon_minitimeSun Apr 05, 2020 8:21 pm
Water Pump Img_2037
Radiator cap. right pocket. Welcome . Enjoy new ride.
Gerritwillemnz
Water Pump Empty
PostSubject: Re: Water Pump   Water Pump I_icon_minitimeSun Apr 05, 2020 8:26 pm
Ok, I filled the radiator with water, it took a litre or so. The fluid is green so there was some coolant left. I let run for 20 min and the water warmed up. I’ll get some new coolant and drain the radiator.
Cheers
Water Pump Empty
PostSubject: Re: Water Pump   Water Pump I_icon_minitimeSun Apr 05, 2020 9:01 pm
Easy way of draining the coolant is to remove hose down at oil cooler no need to remove lower panel to access water pump bolt. Don't over tighten clamp.  System can get air bound . Run it and watch temp. gauge should never get above 3 Bars. halfway if it does shut it off WAIT a bit . Recheck at cap.
Number of posts : 1935
Water Pump Empty
PostSubject: Re: Water Pump   Water Pump I_icon_minitimeMon Apr 06, 2020 7:16 am
Cheers
It's a good warm up when the fan comes on, did it come on when you ran it last?
Gerritwillemnz
Water Pump Empty
PostSubject: Re: Water Pump   Water Pump I_icon_minitimeMon Apr 06, 2020 4:52 pm
No the fan did not come on. The temperature gauge went up to 3 bars
Number of posts : 403
Water Pump Empty
PostSubject: Re: Water Pump   Water Pump I_icon_minitimeMon Apr 06, 2020 5:52 pm
If the reservoir and the radiator were low in fluid then you may either have a leak (probably at a hose clamp) or possibly the radiator cap can't hold pressure and needs to be replaced. If the cooling system can't pressurise it can create steam which blows coolant out of the radiator circuit and can also push coolant out of the reservoir overflow. Another possibility is the small hose connecting to the reservoir, if that gets a hole it prevents coolant being drawn back when the radiator cools off so you get a lower level in the radiator.
Water Pump Empty
PostSubject: Re: Water Pump   Water Pump I_icon_minitimeMon Apr 06, 2020 6:16 pm
Terry you might want to turn your avatar over. Here in the Northern Hemisphere it appears upside down.
Perhaps you could split it so that one side would be upright in either hemisphere.
Intended as humor
Water Pump Empty
PostSubject: Re: Water Pump   Water Pump I_icon_minitimeMon Apr 06, 2020 8:14 pm
3 bars is normal 4 is not.  Check level and refill if needed.  Let it run may take 10 minutes or more just at idle before fan comes on.   Fan will come on after it hits 3 bars may take a little longer after that. edit.
Water Pump Empty
PostSubject: Re: Water Pump   Water Pump I_icon_minitimeMon Apr 06, 2020 8:22 pm
Intended as humor
Well, dang!
It looks alright to me, but I did notice all the text from everywhere else was upside down.
Water Pump Empty
PostSubject: Re: Water Pump   Water Pump I_icon_minitimeMon Apr 06, 2020 8:36 pm
If my avatar is upside down then the sky is falling. Smile Ride ON.
Number of posts : 1999
Water Pump Empty
PostSubject: Re: Water Pump   Water Pump I_icon_minitimeTue Apr 07, 2020 8:08 am
It stands to reason Terry Smith that it would look upside down to those of us in the Northern Hemisphere.
Water Pump
» Water pump gasket
» replacing seals for water pump
» Oil leaking from water pump seal
» ARRGH!! What!!
» Stuff Happens: Water in fuel
