replacing seals for water pump I_icon_minitimeby sonuvabug Today at 4:19 pm
replacing seals for water pump I_icon_minitimeby sonuvabug Today at 4:17 pm
replacing seals for water pump I_icon_minitimeby sonuvabug Today at 4:06 pm
replacing seals for water pump I_icon_minitimeby JohnyC Yesterday at 10:04 am
replacing seals for water pump I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
replacing seals for water pump I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
replacing seals for water pump I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
replacing seals for water pump I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
replacing seals for water pump I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
replacing seals for water pump I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
3 posters
ron1999
ron1999
Number of posts : 36
Registration date : 2011-02-12
replacing seals for water pump Empty
PostSubject: replacing seals for water pump   replacing seals for water pump I_icon_minitimeFri May 06, 2011 5:36 am
Hi guys,
i have this constant, slow dripping of oil from my SW.
i had it inspect and was told that the drips my come from the water pump seals - making it drip both oil and coolant.
can any one advise about the procedure of taking it apart, replacing the seals and rebuilding it?
i intend to make it a picturial, when i do the job, but i just want to be sure before i do anything wrong Smile
thanks
Ron.
Number of posts : 2778
PostSubject: Re: replacing seals for water pump   replacing seals for water pump I_icon_minitimeFri May 06, 2011 8:11 am
Hi Ron, When you let your scooter sets for a while, where does this leak show up under the bike?
Just sent you a PM with information attached.
ron1999
ron1999
PostSubject: Re: replacing seals for water pump   replacing seals for water pump I_icon_minitimeFri May 06, 2011 12:47 pm
Hi Dennis,
thanks for the info and the PM.
i did not look thoroughly enough underneath the scooter to locate the leak, i relied on the information provided to me by the mechanic that tested my scooter for me before i purchased it.
yet, when i took the water pump apart - i could see that there was a leak from the oil seal.
i replaced both seals (inner one and the oil seal)
now, after everything is done - i could look beneath the scooter to locate another leak of oil -
now it looks like it is coming from the center of the engine - there's this metal protector underneath the engine, and it looks like the leak is coming right from the bolt in the center of that protector.
i will upload the pictures of the process and i can demonstrate when it is coming from.
Ron.
WingMan02
WingMan02
Number of posts : 287
PostSubject: Re: replacing seals for water pump   replacing seals for water pump I_icon_minitimeFri Dec 28, 2012 7:08 pm
Ron,
The oil seal you are referring to, is it the water pump housing to engine seal, or the water pump shaft seal? Also what were the two seals you replaced? I was told by my local Honda parts guy that the shaft oil seal cannot be purchased separately and that I need to purchase the complete water pump,
» Water Pump
» Water pump gasket
» Oil leaking from water pump seal
» Anyone tried using this on your 12v socket? (water boiler!)
» Shocks rebuilding, seals ??
