| Stock Air Box | |
+5eddy Opalsboy bigbird john grinsel ThePPH 9 posters |
ThePPH Scooter Rider
Number of posts : 67 Location : Fountain Hills, Arizona Points : 5047 Registration date : 2011-04-27
| Subject: Stock Air Box Mon Jun 27, 2011 4:59 pm | |
| I'm looking at the pictorial for changing out the air filter on our Silverwing and I cannot help but notice the strangeness of the location for this air intake in the first place. From the appearances it is hard to tell where the air is being pulled from. It also appears that the box is very restrictive no matter which filter element you should choose. I should have the new K&N filter by tomorrow when I get off of work and I plan to swap out the stock filter immediately. My bike has just hit 26,000 miles and it is a 2004 so it will be interesting to see if the filter is stock or has been changed out previously. The most important thing I would like to do is make certain that I provide a better source of air to the inlet from a source that is not affected by engine heat in any way. I put cold air intake systems on every vehicle that I own due to the fact that I live in Arizona. I have always noticed that Hondas are very touchy when it comes to high intake air temperature so anything that can be done to reduce the air temperature. I have read where folks have drilled some extra holes to improve air flow but I am wondering ahead of this job if there might be a way to plumb or modify an outside air source to direct ambient air into the intake assembly a little better. Ideally the creation of a lengthened intake tube with conical shaped filter in a strategically placed located would be best but this seems nearly impossible given the stock location of the existing filter box and intake tube.
Has there been anyone out there to develop anything to improve upon Honda's design or is this even possible given the way this scooter is pieced together?
I'm going into this particular modification with an appetite for improvement so if I can see anything before I get any comments back I will look at working out an improvement on my own or with the help of some local fabrication shops here in the Phoenix/North Scottsdale area.
Thank you, Scott |
| Subject: Re: Stock Air Box Mon Jun 27, 2011 5:06 pm | |
| My take...pretty hard to outthink Honda. Filter is hard to get at. But it works.
K & N Filter ok as it is re-useable, when properly cleaned and not over oiled. I would first check on price stock vs K&N.
John Grinsel |
| Subject: Re: Stock Air Box Mon Jun 27, 2011 7:30 pm | |
Opalsboy Silver Wing Guru
Number of posts : 1288 Age : 80 Location : Rison, Arkansas Points : 7266 Registration date : 2009-01-10
| Subject: Re: Stock Air Box Tue Jun 28, 2011 12:01 am | |
| Just a little note to note... I believe there is an extra bolt/screw that will be left over if you go to the K&N. Not sure why. But that is the best recollection I have. |
eddy Maxi-Scooter Rider
Number of posts : 187 Age : 73 Location : Europe Flanders. Points : 5674 Registration date : 2009-11-27
| Subject: Re: Stock Air Box Tue Jun 28, 2011 1:27 am | |
| Be careful with a self made conical inlet.
When pointing to the front , there can be a overpressure. When to the rear maybe a vacuum.
I can't tell , the fuel regulator system can deal with that.
Eddy |
Mudnman Super Scooter Rider
Number of posts : 218 Location : Florida Points : 4201 Registration date : 2014-01-15
| Subject: Re: Stock Air Box Thu Jan 16, 2014 10:08 pm | |
| - Opalsboy wrote:
- Just a little note to note... I believe there is an extra bolt/screw that will be left over if you go to the K&N. Not sure why. But that is the best recollection I have.
Just bought an 08 that has a k&n sticker under the seat.I found a bolt the size of a big cigarette butt by the fuse box under seat.Making me wonder if this is the bolt your talking about. |
| Subject: Re: Stock Air Box Thu Jan 16, 2014 10:26 pm | |
| I would take that K & N filter and replace it with a stock Honda paper element air cleaner. I ran a K & N for 2 seasons in my Swing, and have concluded that K & N is mostly advertising hype accompanied by very little filtering. Sure, they're cheap to maintain once you buy it along with the cleaner and re-oiler kit, but they really aren't very effective in keeping the smallest particulate matter out of the engine. And yes, a K & N doesn't allow the centre bolt from the stock air filter to be reinstalled when you add a K & N. |
| Subject: Re: Stock Air Box Fri Jan 17, 2014 8:34 am | |
| Air filters is a subjective item like oil or oil filters. People get VERY passionate about these things. I installed a K&N in my SW not for more MPG, not for more HP but simply because mother Honda makes the filter such a PAIN to get at that I wanted extended clean intervals. My Gold Wing will get one also because it is EVEN worse to get to LOL.
That said I have used K&N filters for years and have never had a problem; and on my cars and trucks I usually clean them at about 30-35K intervals.
So use what YOU want and be happy! |
tankyuong Silver Wing Rider
| Subject: Re: Stock Air Box Fri Jan 17, 2014 11:56 am | |
| I drilled the box and now regret it due to noise and mpg loss.so holes are taped up |
Number of posts : 341 Location : Surprise, AZ. Points : 5784 Registration date : 2010-04-30
| Subject: Re: Stock Air Box Fri Jan 17, 2014 1:20 pm | |
| Stock Air Box | |
