| Who has ever had to have valve shims changed? | |
+7Erdoc48 Terry Smith Loosemarbles Jinglebob jdeereanton bigbird buddy19520 11 posters |
Have you ever needed to have the valve shims of your Silver Wing changed? | Yes | | 11% | [ 2 ] | No | | 89% | [ 16 ] |
| Total Votes : 18 | | Poll closed |
Number of posts : 378 Location : Cornelius NC Points : 5791 Registration date : 2010-02-28
| Subject: Who has ever had to have valve shims changed? Sat Jul 02, 2011 12:07 pm | |
| I know that we all read that we should have the valves checked at 16,000 miles, but I am wondering who has actually had to have the shims replaced to bring the specs back to stock?
Having read most of the posts on this and the other Silverwing site, I think very few folks ever really needed the valves adjusted.
My bike just turned over 16,000 miles and runs like a champ. Starts instantly and never misses a beat. I have no intention of getting the valves checked - I am concerned that a mechanic might goof something up putting it back together, and can't see any possible improvement.
Please let us know your experience.
Thanks, Philip
| Subject: Re: Who has ever had to have valve shims changed? Sat Jul 02, 2011 4:53 pm | |
jdeereanton Silver Wing Guru
| Subject: Re: Who has ever had to have valve shims changed? Sat Jul 02, 2011 5:53 pm | |
| Subject: Re: Who has ever had to have valve shims changed? Sat Jul 02, 2011 6:05 pm | |
| Sorry Dale. If you want to move or delete my post, be my guest. |
| Subject: Re: Who has ever had to have valve shims changed? Sat Jul 02, 2011 6:31 pm | |
| No need, just seemed odd to call something a poll when there was no poll attached.
What you added was good info. |
Jinglebob Super Scooter Rider
Number of posts : 297 Location : Sacramento Points : 6020 Registration date : 2009-07-18
| Subject: Re: Who has ever had to have valve shims changed? Sun Jul 03, 2011 12:11 pm | |
| I have the mechanical aptitude of a chimp. Actually, that's an insult to chimps. I like having the factory manual, because it makes it very apparent to me which items of preventative maintenance I am capable of carrying out and those which are better left to people with actual skills.
Valves are something I wouldn't personally try, but again, the manual is of value because at the least, it shows me what the mechanic is going to do. Bigbird's description of the process is excellent... |
Number of posts : 1607 Age : 63 Location : South East England Points : 4756 Registration date : 2016-10-01
| Subject: Re: Who has ever had to have valve shims changed? Mon May 15, 2023 2:59 pm | |
| I know this thread is 12 years old but I wonder if anyone has does this procedure; checked valve clearances and replaced shims? My SW has made a 'tapping' noise, usually during steady, long-run conditions, like motorways.. It's never got any worse over 9 years and 18000 miles. I realize that it could be a number of things but I think I've covered all the usual suspects. This is an easy job, right?...coz if it ain't, I wont bother |
Terry Smith Silver Wing Rider
Number of posts : 403 Age : 60 Location : Auckland, New Zealand Points : 2143 Registration date : 2020-03-11
| Subject: Re: Who has ever had to have valve shims changed? Mon May 15, 2023 5:05 pm | |
| There's three parts to this exercise: 1. Remove lots of bodywork 2. Use feeler gauges to check the clearance 3. If needed, remove the cam(s) to access the buckets/shims
I did check my Swing at 70,000km and they were all in spec, which was a relief, as I don't enjoy wrestling with camchain tensioners and chains. I have slightly cheated (on my VTR1000F which has a similar cam drive layout) and cable tied the chain to the sprockets, and unbolted the sprockets from the cams so that the cam/crank timing never gets affected. Probably just paranoia on my part.
I have swapped out shims on my VFR800 and ST1300 as well. One just needs patience, and a set of Hotcams shims.
Due to the design (direct actuation of buckets on the valve stem) the valve clearances normally decrease with wear as the valve wears into the head, so valve noise is unlikely to get worse with wear. |
Erdoc48 Touring Scooter Rider
Number of posts : 382 Age : 60 Location : Myrtle Beach, SC Points : 1301 Registration date : 2022-05-31
| Subject: Re: Who has ever had to have valve shims changed? Mon May 15, 2023 9:14 pm | |
| OK, my $0.02…and applies to another Honda product, the ST1100 (which has the same design shim under bucket). After several valve checks and near 50K miles on each of the 2 bikes, they are in the middle of spec, so most people on the ST-Owners.com forum basically leave them alone- I guess if you’re north of 70-80K miles, might be worth a check, but overall, these Hondas keep their valves in spec even though the service manual indicates need for checking them, and on the SWing, it does look like a pain to check (on the STs they’re pretty easily accessible to check the valves) |
| Subject: Re: Who has ever had to have valve shims changed? Mon May 15, 2023 11:52 pm | |
| Subject: Re: Who has ever had to have valve shims changed? Tue May 16, 2023 8:41 am | |
| Two purchased new SilverWings, each ridden rather quickly to 50,000 miles...at the point I trade or sell. Never touched shims, never valve noise or problems, WalMart 10-40 house brand oil changed regularly. But know could be expensive to have valves checked. |
steve_h80 Silver Wing Guru
Number of posts : 1037 Location : Teesdale, UK Points : 4230 Registration date : 2016-05-15
| Subject: Re: Who has ever had to have valve shims changed? Tue May 16, 2023 1:05 pm | |
| I do keep having guilt trips about this. The engine is nice and quite still at 35k, but valves don't get noisy do they, they tighten up and eventually go pop (or pfft). Perhaps this winter I'll pop the head off and wave a feeler gauge that way, I might even fix the stator wire oil seep at the same time. Or I might continue to be a lazy sod and leave it all alone. |
| Subject: Re: Who has ever had to have valve shims changed? Tue May 16, 2023 2:58 pm | |
| Thanks for all the input and the pics. I guess I will leave well alone for now. I might get around to the stator leak myself one day too! |
| Subject: Re: Who has ever had to have valve shims changed? Thu May 18, 2023 8:50 am | |
| - Loosemarbles wrote:
- Thanks for all the input and the pics. I guess I will leave well alone for now. I might get around to the stator leak myself one day too!
I bought my Silver Wing brand new and it is nearing 30K. I have never checked or adjusted the valves on it. To date it has never given me reason to mess with the valves. As the job appears to be a big PAIN I guess I will continue on my merry way! LOL Good luck with yours. |
| Subject: Re: Who has ever had to have valve shims changed? Thu May 18, 2023 1:22 pm | |
| So it's going to be down to me and Loosemarbles to see who cracks first and has a look-see... |
| Subject: Re: Who has ever had to have valve shims changed? Thu May 18, 2023 2:05 pm | |
| Is this not more tinkering just for the sake of it. It's mid May,the weather is improving, isn't this the time to be doing some riding. The only maxi riders I see on a regular basis are those Deliveroo blokes on L plates, and an annoying prick also on L plates with with a furry Bugs Bunny helmet cover. |
| Subject: Re: Who has ever had to have valve shims changed? Thu May 18, 2023 8:13 pm | |
| - Meldrew wrote:
- The only maxi riders I see on a regular basis are those Deliveroo blokes on L plates, and an annoying prick also on L plates with with a furry Bugs Bunny helmet cover.
I think it is perfectly acceptable to kick the annoying prick off his scooter for wearing the Bugs Bunny cover. You know you want to. |
| Subject: Re: Who has ever had to have valve shims changed? Fri May 19, 2023 3:20 pm | |
| Back in my day, some hooligans used to put a long-hair wig over their helmet to make it look like they weren't actually wearing a helmet. It made for some confusion in the Police department.
Anyway, back to the topic of shims, I won't be going in there any time soon. When I do, I'll record it all. It might be useful for those who keep their SWs into the grand old age of my 'second oldest SW known to man'!
| Subject: Re: Who has ever had to have valve shims changed? Sat May 20, 2023 1:40 am | |
Really? I find that hard to believe that you'd be able to easily buy any long haired wig large enough to fit over the shell of a motorcycle helmet. It would need to be the same size as one of the helmet bags I have, and a wig that size would be far too large for a human head. But I digress, tinkering is obviously more important than riding. |
| Subject: Re: Who has ever had to have valve shims changed? Sun May 21, 2023 3:19 am | |
| Tinkering is a winter activity at keeps some of us sane Mildred Tinker in the winter, ride in the summer. |
| Subject: Re: Who has ever had to have valve shims changed? Sun May 21, 2023 4:58 am | |
| Who's this f****** Mildred for a start?
So you don't ride during the winter months, that says all I need to know about you. All summer rides and coffee and cake. |
| Subject: Re: Who has ever had to have valve shims changed? Sun May 21, 2023 12:11 pm | |
| Predictive text ay? It can get you in all kinds of trouble.
Surely we all agree that owning a motorcycle is a purely personal experience; isn't that the whole point? This forum is an opportunity for us to share our commonality and to learn and enjoy.
Let's keep this topic on track. |
| Subject: Re: Who has ever had to have valve shims changed? Wed May 24, 2023 3:06 am | |
| Temper, temper. It was just autocorrect doing it's usual thing. I never realised you where such a sensitive soul. |
| Subject: Re: Who has ever had to have valve shims changed? Wed May 24, 2023 3:27 am | |
| - steve_h80 wrote:
- Temper, temper. It was just autocorrect doing it's usual thing.
I never realised you where such a sensitive soul. I'm not in the least sensitive, and neither am I gullible enough to believe it was autocorrect. I've had Mildred, Mildew etc on here and on other forums. It's easy enough to correct genuine spelling mistakes you've made online. Just as it is to read through a preview or draft before posting. Alternatively you can very easily edit any mistakes you've made after it's posted. As I'm typing this any spelling errors are highlighted on my keyboard. In fact I've edited this post twice. Apart from that, have a nice day. |
