Plastic Brake Pad Shims I_icon_minitimeby john grinsel Yesterday at 4:14 pm
» Rear wheel valve stem
Plastic Brake Pad Shims I_icon_minitimeby JohnyC Yesterday at 11:53 am
Plastic Brake Pad Shims I_icon_minitimeby COMick Fri Nov 22, 2024 6:13 pm
Plastic Brake Pad Shims I_icon_minitimeby xwelder Fri Nov 22, 2024 12:31 pm
Plastic Brake Pad Shims I_icon_minitimeby sonuvabug Thu Nov 21, 2024 4:17 pm
Plastic Brake Pad Shims I_icon_minitimeby JohnyC Wed Nov 20, 2024 10:04 am
Plastic Brake Pad Shims I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Plastic Brake Pad Shims I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Plastic Brake Pad Shims I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Plastic Brake Pad Shims I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
3 posters
Number of posts : 1607
Plastic Brake Pad Shims Empty
PostSubject: Plastic Brake Pad Shims   Plastic Brake Pad Shims I_icon_minitimeThu Apr 29, 2021 9:40 am
This is a follow-on from the topic 'Clicking Noise from Front Brake':
My new OEM pads arrived today and once again I am puzzled by the inclusion of the plastic shims which come with the kit.
The front pads have one plastic shim:
Plastic Brake Pad Shims Oem_fr10
The rear pads have two plastic shims:
Plastic Brake Pad Shims Oem_re10
What on earth are they for? Should I insert them when fitting the pads?
PostSubject: Re: Plastic Brake Pad Shims   Plastic Brake Pad Shims I_icon_minitimeThu Apr 29, 2021 12:09 pm
Well I think I've answered my own question....mostly.
The rear pads without the plastic shims leave the clips from the metal shims protruding beyond the backing plate. These will scrape the disc once the pad wear goes beyond the clip.
Here's the pad without the plastic shim:
Plastic Brake Pad Shims Oem_re11
Here's the pad with the plastic shim:
Plastic Brake Pad Shims Oem_re13
Here's the front pad which doesn't need the shim in any case:
Plastic Brake Pad Shims Oem_fr11
Have I solved this mystery?
Whatever the case, I've put the plastic shims on the rear pads. Test ride tomorrow. Question
Number of posts : 1935
PostSubject: Re: Plastic Brake Pad Shims   Plastic Brake Pad Shims I_icon_minitimeThu Apr 29, 2021 1:17 pm
Perhaps the plastic pads were a enkiering move to cover up a mistrake Embarassed
Number of posts : 580
PostSubject: Re: Plastic Brake Pad Shims   Plastic Brake Pad Shims I_icon_minitimeThu Apr 29, 2021 3:17 pm
IMO the plastic shim is a heat insulator and it should go on piston side, but not outside of metal shim ?, your rear placement/deduction looks correct, IAC I'll take a look at my front/rear calipers (that I believe is still undisturbed from oem) when I get home in a few hours and report back, WKYP.
PostSubject: Re: Plastic Brake Pad Shims   Plastic Brake Pad Shims I_icon_minitimeThu Apr 29, 2021 3:30 pm
I suspect that oldwingguy might be right in terms of a Honda 'afterthought' on the rear. As for the front shim, putting it on the piston side seems to make sense.
Looking forward to your findings zrx212. cat
PostSubject: Re: Plastic Brake Pad Shims   Plastic Brake Pad Shims I_icon_minitimeThu Apr 29, 2021 5:35 pm
Ok, it's done, on my oem installation.
Rear, plastic shims on both sides against back of pad and then metal shim.
Front plastic shim on outside pad only(caliper piston side) and then metal shims on both sides.
The thing most people don't do when installing new brake pads is break them in properly(yes I know the peanut gallery is rolling their eyes ??) but here it is.
https://www.partzilla.com/blog/breaking-in-motorcycle-brake-pads-tips
PostSubject: Re: Plastic Brake Pad Shims   Plastic Brake Pad Shims I_icon_minitimeFri Apr 30, 2021 5:46 am
"Alas my dear Watson, the riddle of Mr Honda's legacy is solved".
Thanks for that zrx212. I'm off to the garage to re-install my new pads and then carry out the bedding in process as per your link.
I hope this thread will provide a useful tip for our members. Hoorah!
» Who has ever had to have valve shims changed?
» Hand Brake or Parking Brake
» Plastic handlebar covers
» Plastic Fading
