The changed engine sound I_icon_minitimeby john grinsel Yesterday at 4:14 pm
» Rear wheel valve stem
The changed engine sound I_icon_minitimeby JohnyC Yesterday at 11:53 am
The changed engine sound I_icon_minitimeby COMick Fri Nov 22, 2024 6:13 pm
The changed engine sound I_icon_minitimeby xwelder Fri Nov 22, 2024 12:31 pm
The changed engine sound I_icon_minitimeby sonuvabug Thu Nov 21, 2024 4:17 pm
The changed engine sound I_icon_minitimeby JohnyC Wed Nov 20, 2024 10:04 am
The changed engine sound I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
The changed engine sound I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
The changed engine sound I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
The changed engine sound I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Biologist
Biologist
Number of posts : 19
Registration date : 2010-09-27
The changed engine sound Empty
PostSubject: The changed engine sound   The changed engine sound I_icon_minitimeWed Sep 29, 2010 5:05 pm
I' ve just changed the belt in my SW, so during the ride the sound of the engine is different comparing with this before service. Is that normal?
Hammy
Hammy
Number of posts : 362
PostSubject: Re: The changed engine sound   The changed engine sound I_icon_minitimeWed Sep 29, 2010 6:37 pm
I don't think my belt change made the SW sound any different? Is it when you are just starting the bike from a stop and you hear a squeaking sound?
PostSubject: Re: The changed engine sound   The changed engine sound I_icon_minitimeWed Sep 29, 2010 10:52 pm
Can you be a little more specific about the noise change. What are you hearing / not hearing now that was going on before? At what RPM?
Hammy doesn't notice any noise difference because he never travels at less than 60 mph and at that velocity whatever noises are going on are well behind him Wink
Biologist
Biologist
PostSubject: Re: The changed engine sound   The changed engine sound I_icon_minitimeThu Sep 30, 2010 7:26 am
It sounds like a whistle and appears when I reach the velocity of about 60km/h (I dont know: 40-45 miles?).
Number of posts : 1995
PostSubject: Re: The changed engine sound   The changed engine sound I_icon_minitimeThu Sep 30, 2010 7:39 am
You could have an air leak of some sort that may not be engine related. It could be related to eliminate your helmet/visor. You may try to raise the visor when the noise appears or turn your head. If the noise goes away...
You may have air entry holes in your body work that allows a venturi to form and the whistle will follow.
Biologist
Biologist
PostSubject: Re: The changed engine sound   The changed engine sound I_icon_minitimeThu Sep 30, 2010 8:24 am
Probably it's not related to the engine itself but I tried to eliminate the "external sources" of that noise. I have got one more idea : I' ve bought my scoot beeing used by some people before and It's probably not so ideal I would like it to be. I think - any micro-damages in plastics may cause such a sound?
PostSubject: Re: The changed engine sound   The changed engine sound I_icon_minitimeThu Sep 30, 2010 12:33 pm
Biologist,
Does the noise continue and / or change pitch at speeds above 60kph?
Chinasaur
Number of posts : 74
Registration date : 2010-08-26
PostSubject: Re: The changed engine sound   The changed engine sound I_icon_minitimeThu Sep 30, 2010 4:17 pm
I'd have to agree with Biologist that the bike sounded different after my honey's '03 had it's combined 12/16K service, w/ belt change. The engine "whine" sounded sooo much better and the "note" was deeper and smoother.
Since it was after a service, unless you see oil or some other fluid leaking onto the ground, I'd just appreciate it and move on. Any bike always sounds better after a service.
Biologist
Biologist
PostSubject: Re: The changed engine sound   The changed engine sound I_icon_minitimeThu Sep 30, 2010 5:05 pm
(cit) Does the noise continue and / or change pitch at speeds above 60kph?
Unfortunately yes - up to 100 kph - I didn't ride faster beacuse I'm still learning to use it Smile
» Who has ever had to have valve shims changed?
» Does This Sound Ok?
» Changed the belt today
» Coolant antifreeze changed!
» Final drive oil changed.
