Best fix for plastic crack ? I_icon_minitimeby zrx212 Yesterday at 4:40 pm
Best fix for plastic crack ? I_icon_minitimeby Meldrew Yesterday at 4:37 pm
Best fix for plastic crack ? I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Best fix for plastic crack ? I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Best fix for plastic crack ? I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Best fix for plastic crack ? I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Best fix for plastic crack ? I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
Best fix for plastic crack ? I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
Best fix for plastic crack ? I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
Best fix for plastic crack ? I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
3 posters
cjuzda
Number of posts : 133
Registration date : 2011-05-16
Best fix for plastic crack ? Empty
PostSubject: ABS and Fibreglass worked well   Best fix for plastic crack ? I_icon_minitimeTue Jul 26, 2011 3:37 pm
Tried the ABS cement solution you suggested and it seems to do a really nice job. Thanks!
cjuzda
PostSubject: Re: Best fix for plastic crack ?   Best fix for plastic crack ? I_icon_minitimeSat Jul 23, 2011 8:56 pm
Thanks guys I'll give it a try
Hammy wrote:
I've had excellent success repairing cracks & broken mounting tabs using ABS plumbing cement (Not PVC cement) and fiberglass drywall tape.
You're going to have to clean off the dirt & stuff from the underside of the crack first. Then smear a layer of ABS cement around the crack and apply a layer of the fiberglass tape. Allow it to set up for about 20 minutes and then apply another layer of ABS and Tape. The whole mess will cure in 24 hours, but it does initially set in a much shorter time.
ABS Plumbing Cement can be difficult to locate in some areas because of state or local prohibitions against ABS material used for plumbing. I got a small can of the stuff from Lowe's but I had to find it in New Jersey, as none was available in Delaware, Penna or NY. You might also check with an RV shop as RV use ABS in the drain systems.
You can also use nail polish remover as it is 100% acetone --the working ingredient in ABS cement. The ABS cement is thick & gooey and also contains ground up ABS plastic. While acetone is very liquid so you've got to be careful it doesn't get on the painted side of the tupperware.
AFAIK the main ingredients in a Plastex Kit are acetone and ground abs plastic.
You can also do a google search for methylene chloride acrylic cement.
I can attest to the success of using Tim's technique as he's fixed many a cracked piece of plastic on my Silverwing that way.
Hammy
Hammy
Number of posts : 362
PostSubject: Re: Best fix for plastic crack ?   Best fix for plastic crack ? I_icon_minitimeFri Jul 22, 2011 2:30 pm
cjuzda
PostSubject: Re: Best fix for plastic crack ?   Best fix for plastic crack ? I_icon_minitimeFri Jul 22, 2011 12:07 pm
Thanks John, the location of the crack is so highly visible that I wouldn't think that using screws and metal would be a good solution. The plastic in the front fender is also super thin.
Underside plastic on left side of my SilverWing developed crack, two pieces of soft metal that said BMW on them (from Junk box) Drilled small pilot holes in plastic, used stainless self tapping screws.
No glue necessary and repair looked pretty good and most important lasted.
cjuzda
PostSubject: Re: Best fix for plastic crack ?   Best fix for plastic crack ? I_icon_minitimeFri Jul 22, 2011 9:39 am
Thanks - great info. the crack is so tight, I might try just applying the ABS cement to the underside without the fiberglass tape. I never thought of that - I've done some plumbing with ABS cement and I know it sort of "melts" the plastic so maybe it will melt the crack together
PostSubject: Re: Best fix for plastic crack ?   Best fix for plastic crack ? I_icon_minitimeThu Jul 21, 2011 10:17 pm
cjuzda
PostSubject: Best fix for plastic crack ?   Best fix for plastic crack ? I_icon_minitimeThu Jul 21, 2011 7:52 pm
I noticed a vertical crack right in the middle of the the front fender. It's about 3 inches long, starting from the leading edge and is hardly noticable , I though it was a scratch but if you push on it, it separates. Is there a good glue or plastic weld that would be best to fix this with. I'd guess it would have to be pretty strong to resist flexing
Thanks
» Givi AF214 hairline 'crack'?
» Crack in lower valence panel
» Problems with aluminum belt casing(crack)
» Crack Developing on my Silverwing's Body under running board
» Plastic handlebar covers
Honda Silver Wing Scooter Forum :: Honda Silver Wing :: Maintenance, Tips and Hints :: Tupperware Repair-
