| Crack Developing on my Silverwing's Body under running board | |
+12Darkeswinger Dimond honda_silver DennisB tinman tarmacburner2 john grinsel RArch Waspie tankyuong model28a SilverwingInIdaho 16 posters |
SilverwingInIdaho Maxi-Scooter Rider
Number of posts : 155 Points : 5008 Registration date : 2011-08-23
| Subject: Crack Developing on my Silverwing's Body under running board Sun Jul 29, 2012 11:45 pm | |
| I just noticed a crack on the underside of the running board on the left side. I need to arrest the progress before it spread. I have no idea how it came about. The bike is a 2003 and I've never dropped it or anything. Is this a job for a body shop or a motorcycle dealer? Mike |
Number of posts : 2085 Age : 71 Location : St.Pete.FL. Points : 7523 Registration date : 2010-02-03
| Subject: Re: Crack Developing on my Silverwing's Body under running board Mon Jul 30, 2012 12:51 am | |
| Do it yourself. You can get a new panel and if you have a service manual it is easy to do. If I remember the panel cost around $135.00. |
tankyuong Silver Wing Rider
Number of posts : 475 Age : 49 Location : Missouri Points : 6263 Registration date : 2009-07-12
| Subject: Re: Crack Developing on my Silverwing's Body under running board Mon Jul 30, 2012 12:53 am | |
| get some steel epoxy and attach to the other side of crack and touchup paint |
| Subject: Re: Crack Developing on my Silverwing's Body under running board Mon Jul 30, 2012 2:19 am | |
| Who do I contact to get a new panel?
Mike |
Number of posts : 2392 Age : 72 Location : Portland, UK Points : 8113 Registration date : 2009-07-26
| Subject: Re: Crack Developing on my Silverwing's Body under running board Mon Jul 30, 2012 4:42 am | |
| So have I, it's been there since the bike was six months old. Hasn't got worse, I suggest you simply leave it unless it REALLY annoys you.
The Wing must have some sort of stress issue at that point as most Wings' I have seen in the flesh have a slight crack there. |
RArch Silver Wing Expert
Number of posts : 613 Age : 57 Location : West London, UK Points : 5379 Registration date : 2011-11-07
| Subject: Re: Crack Developing on my Silverwing's Body under running board Mon Jul 30, 2012 4:47 am | |
| - SilverwingInIdaho wrote:
- I need to arrest the progress before it spread.
Drill a hole right at the end of the crack or just in front of it, that will stop it travelling ant further. Then you can go about fixing it, people say use an ABS cement to glue the panel. Some filler and paint will make it look good again. |
| Subject: Re: Crack Developing on my Silverwing's Body under running board Mon Jul 30, 2012 4:48 am | |
| Mine is a 2003, I bought it used no crack. Why does one then develope after all those years.... |
| Subject: Re: Crack Developing on my Silverwing's Body under running board Mon Jul 30, 2012 4:54 am | |
Drill a hole right at the end of the crack or just in front of it, that will stop it travelling ant further. That works. |
| Subject: Re: Crack Developing on my Silverwing's Body under running board Mon Jul 30, 2012 6:29 am | |
| Mine did that very early in its life, lower than picture shown.
I don't believe in glue, etc.
Had what I recall as BMW stick on wheel weight, a little less than 2 inches long---drilled holes in it, used short self tapping screws on the panel---put cracked plastic together so little line was showing, screwed on----Everything worked well and crack never got bigger or really showed much....at trade in time.
I think plastic used on SilverWing(ReFlex/Helix) is too brittle, kind of like BMW RT Fairings----would be better if soft, flexible, screw on. See/Remember early Honda step thru leg shields/fenders? |
Number of posts : 1099 Age : 70 Location : Cleveleys, Lancashire, England Points : 6499 Registration date : 2010-03-27
| Subject: Re: Crack Developing on my Silverwing's Body under running board Mon Jul 30, 2012 7:19 am | |
| It looks as if the panel has had a 'ding'. Probably didn't notice it at the time. Over a period of time the crack has got larger. Do you ride feet forward or flat down on the boards, or stand up on the boards? That will make the plastic flex, especially if there is a bit too much weight involved (I have that problem!)
Take the panel off and reinforce it. If it means having a couple of screws showing do the same on the other side.
Cheers,
Last edited by tarmacburner2 on Tue Jul 31, 2012 3:52 pm; edited 1 time in total (Reason for editing : typo) |
Number of posts : 1298 Age : 76 Location : Matheson, Ontario, Canada Points : 6095 Registration date : 2011-11-29
| Subject: Re: Crack Developing on my Silverwing's Body under running board Mon Jul 30, 2012 8:07 am | |
| Cut a piece of 2/14 copper wire , make 2 u shape bracket,and melt it in the back side with a soldering iron ,take a black tie rap and melt it in to build it up. It will not break there again. |
Number of posts : 2778 Age : 74 Location : NE Oklahoma Points : 9063 Registration date : 2008-12-28
| Subject: Re: Crack Developing on my Silverwing's Body under running board Mon Jul 30, 2012 8:29 am | |
Number of posts : 2453 Location : Georgetown, Tx Points : 8337 Registration date : 2008-12-23
| Subject: Re: Crack Developing on my Silverwing's Body under running board Mon Jul 30, 2012 12:33 pm | |
- I just noticed a crack on the underside of the running board on the left side.
Is this a job for a body shop or a motorcycle dealer? I would strongly suggest attaching strong clear tape to outside of the panel first before removing the panel ... keeping all the pieces together. If you do not you will find the pieces will crumble and fall apart in tiny tiny pieces very quickly ... then you may have to replace the panel. Once the inside is epoxied ( I epoxied my replacement piece both the the front and back section just for protection ), then you can removed the external clear tape |
| Subject: Re: Crack Developing on my Silverwing's Body under running board Mon Jul 30, 2012 2:56 pm | |
| Can anyone tell me the part name of the panel i want? I want to look into ordering a new one.
Mike |
| Subject: Re: Crack Developing on my Silverwing's Body under running board Mon Jul 30, 2012 3:01 pm | |
| I'd hazard a guess and call it the 'lower left panel'!!! |
| Subject: Re: Crack Developing on my Silverwing's Body under running board Mon Jul 30, 2012 3:13 pm | |
| Item #4 (make sure you have all the hardware that goes on this piece and transfer them to the new cover).
$39.24
http://www.powersportsplus.com/parts/search/Honda/Scooter/2003/FSC600D+AC/CENTER+COVER/parts.html |
| Subject: Re: Crack Developing on my Silverwing's Body under running board Mon Jul 30, 2012 5:44 pm | |
| Wow looks like I was $100 over. I guess my memory is not what it used to be. At $40 I would bye the new panel and have it fixed right. |
| Subject: Re: Crack Developing on my Silverwing's Body under running board Tue Jul 31, 2012 3:29 pm | |
| - DennisB wrote:
- Item #4 (make sure you have all the hardware that goes on this piece and transfer them to the new cover).
$39.24
http://www.powersportsplus.com/parts/search/Honda/Scooter/2003/FSC600D+AC/CENTER+COVER/parts.html How much of the covering has to come off to get the new piece on? Do you need to remove the plastic parts that house the gas tank intake for example? |
| Subject: Re: Crack Developing on my Silverwing's Body under running board Tue Jul 31, 2012 3:30 pm | |
$39.24
| Subject: Re: Crack Developing on my Silverwing's Body under running board Tue Jul 31, 2012 4:33 pm | |
| Brief Instructions, 1. place bike on centerstand. 2. remove left rubber foot mat. (pulls off) 3. put down sidestand. 4. remove screws (eight) that hold the bottom side cover in place. 5. remove bottom side cover from bike. easy as pie I will talk you through it, on the phone, if you need my help. |
Dimond Silver Wing Expert
Number of posts : 540 Age : 79 Location : San Francisco Bay Area Points : 5498 Registration date : 2011-08-07
| Subject: Re: Crack Developing on my Silverwing's Body under running board Wed Aug 01, 2012 5:17 am | |
| My 2003 has a crack on the left cover in excactly the same place - no crack on the right cover. Does the right cover ever develop this crack - or is it only found on the left cover? My SWing floorboard seems to vibrate much more on the LEFT than the RIGHT - have others found this to be the case? - honda_silver wrote:
- I epoxied my replacement piece both the the 'front and back section' just for protection
It seems as if it may be a good preventative, counter, preemptive measure to remove our left cover (if it is not cracked) and reinforce the back. Do you or anyone agree? I assume the 'front section' you refer to is where the originator poster had his crack - but exactly where is the 'back section' that you are referring to and have you (or others) had cracks in this section? Honda-Silver's comment brings up a good topic/question. Are there spots on the SWing that are prone to breakage which may be circumvented by reinforcement as a preventative measure? And if so, what/where? It seems as if it is a reasonable counter measure to reinforce sections prone to breakage NOW rather than wait for the problem to develop - at which time it is much more costly/troublesome to fix. I am guessing that most of the tabs can not be reinforced due to clearance issues; however, there are sections where clearance is not an issue. What do you think?
Darkeswinger Maxi-Scooter Rider
Number of posts : 115 Location : Southwest Ohio Points : 5377 Registration date : 2010-06-11
| Subject: Re: Crack Developing on my Silverwing's Body under running board Wed Aug 01, 2012 8:36 am | |
| What I want to know is why the 2004 left lower panel is @ $70.00, when the 2003 is $39.00. Must be real silver in the paint... Mine was cracked when I bought it, and I repainted it. Enough road dirt has accumulated such that it is hard to discern from the original. |
| Subject: Re: Crack Developing on my Silverwing's Body under running board Thu Aug 02, 2012 3:02 pm | |
| Thanks DennisB! I got the part ordered and I think I can handle the install. I've had the rubber foot guard off before for cleaning.
I would never imagine this would be such a simple fix.
Do I need to worry about epoxy warping the plastic when I add it to make the panel stronger? |
| Subject: Re: Crack Developing on my Silverwing's Body under running board Thu Aug 02, 2012 3:51 pm | |
| No warping. I had to replace both lower covers on my used 2006. Both were busted up pretty badly when I got the bike in. I reinforced the new left cover before install with epoxy.
Tech tip: use some very coarse sand paper and remove any Honda paint overspray on inside of the new panel where the epoxy will be installed. This adds to the bond. |
shendy40 Scooter Rider
Number of posts : 20 Age : 58 Location : UK maidenhead Points : 4528 Registration date : 2012-06-30
| Subject: Re: Crack Developing on my Silverwing's Body under running board Thu Aug 02, 2012 4:01 pm | |
| - DennisB wrote:
- No warping. I had to replace both lower covers on my used 2006. Both were busted up pretty badly when I got the bike in. I reinforced the new left cover before install with epoxy.
Tech tip: use some very coarse sand paper and remove any Honda paint overspray on inside of the new panel where the epoxy will be installed. This adds to the bond. Hi My wing only 2 months old and now reading all this about cracking lower left panels has me worried. But looking at it today do you think it's strange that it seems only the left one has has this problem. Could it be where people stand on this to mount the bike when it's on the center stand , as we all seemed to mount from the left. Weight on this spot will push the screw fixing down onto this lower panel and I think will weaken it slowly. What do we all think ? Shendy |
| Subject: Re: Crack Developing on my Silverwing's Body under running board Thu Aug 02, 2012 5:37 pm | |
| Hi Shendy40, I think it's one of the Silverwing's, and there are not that many, design flaws. It's not a dangerous thing...it's just Honda could have done better on this cover. It's not that hard to fix yourself. |
| Subject: Re: Crack Developing on my Silverwing's Body under running board Fri Aug 03, 2012 5:22 am | |
| Hmmmm seems to me the bike's weight is on the left side every time you use the kick stand. Could it be related? |
| Subject: Re: Crack Developing on my Silverwing's Body under running board Sat Aug 18, 2012 8:03 pm | |
| I got my panal in a few days ago. Looking at it I see that the crack developes right where one of the screws go'es in. So it's a natural stress point. And there is new construction going on down town and I bet the day I went through that it probably did the trick. It was like 30 yards of off road riding. Gravel, wet and bumps like when the graders cut out a new road in the country.
Now that I got it I need to apply the JB-Weld steel reinforced epoxy.
I plan to add it on thick! Are you guys sure it will not warp the plastic? I used JB-weld on a Star Wars Stormtrooper costume build once only on one part that kept coming off and it warped it a little bit.
I think it was ABS plastic and thinner this this silverwing panal.
Mike |
| Subject: Re: Crack Developing on my Silverwing's Body under running board Sun Aug 19, 2012 2:37 am | |
Mike Why not experiment with the old panel when you remove it! If it does warp the plastic try something else. |
| Subject: Re: Crack Developing on my Silverwing's Body under running board Sun Aug 19, 2012 3:20 am | |
| Thought about it but since I need the scooter for errands I had to risk it. It's setting now and no warping. I put JB weld and then added some plastic mesh from the peaches bought at the store and then added more over that. See about install Sunday. |
| Subject: Re: Crack Developing on my Silverwing's Body under running board Sun Aug 19, 2012 4:54 am | |
| That's an interesting point - the crack starting at the screw-hole. I wonder: has the panel been off before and the screw over-tightened when refitted, preventing any slight movement/flexing?
Just a thought. |
| Subject: Re: Crack Developing on my Silverwing's Body under running board Sun Aug 19, 2012 6:57 am | |
| Check if there is some stress cracks on the frame. How many kl on the Swing? |
| Subject: Re: Crack Developing on my Silverwing's Body under running board Sun Aug 19, 2012 4:22 pm | |
| Mine has 12,000 miles on it. I was thinking not to put the crew in tight but then it might fall out.
| Subject: Found a mystery Bolt inside while changing the panal out Sun Aug 19, 2012 7:42 pm | |
| Check this out guys. I don't see any spot for this bolt I found inside. See all the rocks on the ground? I found those and the bolt. I put the bolt back as found for the photo. Anyone know the most likely spot for it? I really don'rt want to have to take off the right side to look. Fear the other side will not survive the dismantle. Edit: Here is the photo, |
| Subject: Re: Crack Developing on my Silverwing's Body under running board Mon Aug 20, 2012 2:01 am | |
| By the way here is the glue job. I should have put some on the top side right around the steel square washer thing but did not think about it. |
| Subject: Re: Crack Developing on my Silverwing's Body under running board Mon Aug 20, 2012 7:53 am | |
| Save and repair the old piece. Good for a spar . |
Number of posts : 2658 Age : 81 Location : Medford, Oregon Points : 8363 Registration date : 2009-07-17
| Subject: Re: Crack Developing on my Silverwing's Body under running board Thu Nov 08, 2012 11:44 pm | |
| I used to have a shop where I bought old GL1100s, refurbished and sold them. I did a lot of plastic repair with plain old black gooey ABS cement. The stuff that comes from the hardware store where black ABS pipe is sold. Not the newer two part stuff just the cheap ABS cement in the round can with a dauber under the screw on cap. The plastic in these machines is ABS so ABS cement will give a very strong bond, better than epoxy or most others. I've experimented with putting a daub of ABS cement, JB Weld, and a couple other glues and then trying to pry them off the substrate with a chisel. The ABS gave the best bond since it's solvent sinks into the surface and really makes a chemical weld. You can also make ABS filler putty by sanding or grinding a piece of ABS pipe and mix it with the cement. Good for building up missing parts of plastic such as tabs or pins. For larger cracks I put down a layer of cement then lay a small piece of fiberglass cloth in the cement. Once that hardens a coat or two of cement to build up a strong repair does the job. It is important not to build up a thick layer of ABS cement because it will skin over and keep the inside soft for a lengthy cure. Several thin coats are the way to go. If you need a replacement panel in the US try MOTOGRID on line. I bought a rear quarter panel for my previous SW from them. It was the right side above the muff. Price was $90 and came in the right color for that bike that had been damaged by the previous owner. |
Number of posts : 4416 Age : 81 Location : damn near Philadelphia, PA Points : 10713 Registration date : 2009-06-12
| Subject: Odd bolt in side skirt Fri Nov 09, 2012 7:17 pm | |
| Just now noticed your Aug 20 post & picture. Sorry for the late response, but my best guess is that the bolt is for the handle bar clamp. I don't recall anything else that size on the SW. If you haven't already done so, take off the handle bar cowling and check the handle bar clamps. You should have 4. Tim - SilverwingInIdaho wrote:
- Check this out guys. I don't see any spot for this bolt I found inside. See all the rocks on the ground? I found those and the bolt. I put the bolt back as found for the photo.
