DenGraham Scooter Rider
Number of posts : 64 Age : 77 Location : The Gardens RV Village, Crossville TN Points : 5825 Registration date : 2008-12-23
| Subject: Silver Wing Maintenance Info Thu Dec 25, 2008 12:34 pm | |
| I assembled most of this information of another site (and owe Seronac from Orem, Utah the credit for assembly the data) but I thought it was very useful. Let me know if you cannot open this link:
http://www.4shared.com/file/77639850/10dc658/Silver_Wing_Info.html
>> Dennis |
| Subject: Silver Wing Info Sun Jan 04, 2009 2:02 am | |
| I am reposting this so see if I can get the info into a text file instead of a spreadsheet:
Oil SG 10W-40 (NOT energy conserving or castor oil)Capacity 2.1/2.3 qt (change with filter) Oil Filter Honda 15410-MCJ-003, KN204, Walmart ST7317, Purolator Pure One PL14610 Tires Front (29 psi) 120/80-14M/C 58S Bridgestone Hoop B03, IRC SS530F Rear (36 psi) 150/70-13M/C 64S Bridgestone Hoop B02 IRC SS530R Spark Plugs NGK CR8EH-9 or DENSO U24FER9 Fuses 30A 15A 10A Engine Type 582cc liquid-cooled four-stroke parallel-twin Bore and Stroke 72mm x 71.5mm Compression Ratio 10.2:1 Valve Train DOHC; four valves per cylinder Carburetion PGM-FI with automatic enricher circuit Ignition Computer-controlled fully transistorized with electronic advance Transmission Transmission: Automatic V-Matic belt drive Suspension Front 41mm hydraulic fork; 4.7 inches travel Rear Swingarm with dual hydraulic shocks with five-position spring , , preload adjustability; 4.7 inches travel Brakes Front Single 256mm disc with CBS three-piston caliper Rear Single 240mm disc with CBS twin-piston caliper Tires Front 120/80-14 Rear 150/70-13 Wheelbase 62.8 inches Seat Height 29.1 inches Overall dimensions Length 89.6 inches Width 30.3 inches Height 56.3 inches Dry Weight 501 pounds Curb weight 540 pounds Max Weight Capacity 366 pounds Fuel 86 octane or higher Tank Capacity 4.23 gallons, including 0.9 gallon reserve K & N Air Filter HA-6002 K& N Oil Filter KN-204 Purolator Pure One PL14610 Headlight 12v 55w x2 Size H7 or Sylvania Silverstar H7ST BASIC MAINTENANCE SCHEDULE 600 Miles Oil and filter. Inspect Engine Idle Speed 4,000 Miles Clean belt case, air cleaner, and crankcase breather. 8,000 Miles Replace spark plugs, oil and filter. Clean belt case, air cleaner, crankcase breather, and oil strainer screen. 12,000 Miles Replace air cleaner. Clean belt case and crankcase breather. Replace brake fluid (or at 2 years). 16,000 Miles Replace spark plugs, oil and filter, and drive belt. Clean belt case, air cleaner, and crankcase breather. Special Maintenance Notes: Change Oil and Filter every 12 months Replace brake fluid and final drive oil every 2 years Inspect drive belt every 12,000 miles
Number of posts : 2598 Age : 65 Location : Bay Area, Ca Points : 8663 Registration date : 2008-12-19
| Subject: Re: Silver Wing Maintenance Info Sun Jan 04, 2009 12:22 pm | |
| Dennis,
Thanks for posting the specs. As I was reading through it I noticed I need to clean my air filter, K&N, it looks likes its overdue. Also, what kind of mirror extensions do you have? I either need those or the mirrors for the Reflex. Thanks. |
| Subject: Re: Silver Wing Maintenance Info Tue Jan 13, 2009 9:23 pm | |
| Jeff, I don't know how I missed your post but here is the site to buy the mirror extenders. I'm very happy with them: http://www.cjen.com/pages/kaw/zrx/mirext/mirext.html
I know you now want pictures, a review, a graph showing speed before change, and after....etc |
