Fork leak- what do I need? I_icon_minitimeby JohnyC Today at 5:39 am
Fork leak- what do I need? I_icon_minitimeby JohnyC Yesterday at 10:04 am
Fork leak- what do I need? I_icon_minitimeby JohnyC Tue Nov 19, 2024 4:42 am
Fork leak- what do I need? I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Fork leak- what do I need? I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Fork leak- what do I need? I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Fork leak- what do I need? I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Fork leak- what do I need? I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Fork leak- what do I need? I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Fork leak- what do I need? I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
kyouteki
toolboxjesse
toolboxjesse
toolboxjesse
Number of posts : 330
Fork leak- what do I need? Empty
PostSubject: Fork leak- what do I need?   Fork leak- what do I need? I_icon_minitimeTue Nov 08, 2011 10:56 am
I just noticed a build-up of oil on my right fork and assume it's leaking. (2003 with 22k miles). I am considering installing Progressive springs. What are the wear parts I would need to replace (aside from the seal of course).
Thanks,
Jesse
kyouteki
kyouteki
Number of posts : 20
Registration date : 2011-08-10
PostSubject: Re: Fork leak- what do I need?   Fork leak- what do I need? I_icon_minitimeTue Nov 08, 2011 11:20 am
I believe all you need is the seals, the springs, and fork oil.
http://www.samuelmcconnell.com
Number of posts : 1288
PostSubject: Re: Fork leak- what do I need?   Fork leak- what do I need? I_icon_minitimeTue Nov 08, 2011 12:53 pm
Jessie... the springs kit comes with 20wt fork oil.
joncallihan
Number of posts : 1025
PostSubject: Re: Fork leak- what do I need?   Fork leak- what do I need? I_icon_minitimeTue Nov 08, 2011 1:20 pm
Read this thread first, it will save a lot of grief.
https://www.silverwing600.com/t2047-fork-tube-socket-size
:flower:
http://www.joncallihan.com
toolboxjesse
toolboxjesse
PostSubject: Re: Fork leak- what do I need?   Fork leak- what do I need? I_icon_minitimeTue Nov 08, 2011 2:11 pm
Thanks I read it- I have rebuilt shocks before so didn't learn much I didn't already know. I really just want to order the wear parts before I tear the shocks apart.
PostSubject: Re: Fork leak- what do I need?   Fork leak- what do I need? I_icon_minitimeTue Nov 08, 2011 4:48 pm
If you use an electric impact tool on those 22 MM fork tube caps (even though they are only torqued at ~17 lbs) you can have a buddy hold on to the fork sliders with gloves. That'll save you the risk of pinching the tubes if you use a vise.
I used a ~24 inch piece of PVC pipe with a saw split about 2/3rds of the way down the length so that it would just fit the o.d. of the fork slider tube to drive the new fork seals and dust seal into place.
If you are switching to Hyper Pro springs it's probably not too wise to use the impact took replacing the fork tube caps though. You do need a lot of downward pressure to compress the new springs, and the impact tool will encourage cross threading the cap into the fork tube sliders.
Then you'll find yourself stuck on that legendary American tributary without the proper propellant Sad
Number of posts : 2387
PostSubject: Re: Fork leak- what do I need?   Fork leak- what do I need? I_icon_minitimeTue Nov 08, 2011 5:49 pm
x
BlackFly
BlackFly
Number of posts : 151
Registration date : 2010-11-20
PostSubject: Re: Fork leak- what do I need?   Fork leak- what do I need? I_icon_minitimeWed Nov 09, 2011 6:47 am
You also need the dustcaps, not only the seals.
toolboxjesse
toolboxjesse
PostSubject: Re: Fork leak- what do I need?   Fork leak- what do I need? I_icon_minitimeWed Nov 09, 2011 6:54 am
Thanks everyone!
» Engine oil leak
» Engine Oil Leak - I need to get busy
» Rubber Grommetts Oil Leak Repair Question
» Major oil leak !
» Engine Oil Leak
