| Subject: Changing the clutch and pillow springs on a Dr. Pulley HiT clutch Fri Nov 11, 2011 11:28 am | |
| Subject: Re: Changing the clutch and pillow springs on a Dr. Pulley HiT clutch Fri Nov 11, 2011 5:21 pm | |
| I use a Harbor Freight Brake Spring / Headlight Spring hook to first remove the Clutch Springs on my HiT Clutch --then swing the clutch shoes out of the way and either use a short, thin screwdriver to lever-off the Pillow Springs or continue on using that spring hook tool. The screw driver seems actually more effective on the Pillow Springs though.
http://www.harborfreight.com/spring-hook-95757.html |
