 adjusting rear shocks I_icon_minitimeby zrx212 Yesterday at 4:40 pm
 adjusting rear shocks I_icon_minitimeby Meldrew Yesterday at 4:37 pm
 adjusting rear shocks I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
 adjusting rear shocks I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
 adjusting rear shocks I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
 adjusting rear shocks I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
 adjusting rear shocks I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
 adjusting rear shocks I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
 adjusting rear shocks I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
 adjusting rear shocks I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
Boris1
roadrunner
DarthJ
toolboxjesse
tinman
Dale
eddy
JeffR_
redeye
jeff fisher
19 posters
jeff fisher
Number of posts : 2
Registration date : 2011-11-23
 adjusting rear shocks Empty
PostSubject: adjusting rear shocks    adjusting rear shocks I_icon_minitimeFri Nov 25, 2011 7:10 pm
Where can I purchase a wrench to adjust the rear shocks?What #should they be adjusted to?Most times my wife is with me so our combined weight is about 280 pounds.We are always on pretty good roads.
 adjusting rear shocks 510-80
PostSubject: Re: adjusting rear shocks    adjusting rear shocks I_icon_minitimeFri Nov 25, 2011 7:54 pm
The tools most people need to adjust rear shocks are extremely expensive, but usually last a lifetime. They are called "hands". Seriously, you can probably adjust the shocks by hand. Put the bike on centerstand and you can turn them to the setting you want. Just make sure they are the same for both sides
redeye
Number of posts : 163
Registration date : 2010-10-13
PostSubject: Re: adjusting rear shocks    adjusting rear shocks I_icon_minitimeFri Nov 25, 2011 8:19 pm
A spanner, or spanner wrench, should be available at just about any dealership. It will likely cost more there than elsewhere, and you can find them through on-line retailers such as Amazon.com.
JeffR_
JeffR_
Number of posts : 1103
PostSubject: Re: adjusting rear shocks    adjusting rear shocks I_icon_minitimeFri Nov 25, 2011 10:31 pm
Jeff,
I have a 2007 and just use my hand when I adjust mine. Put your bike on the center stand and maybe wear a glove. I think I have read that the older SWings may need a spanner but just try your hand first. I just keep mine on 5 all the time and it seems to work good for me.
eddy
Number of posts : 187
PostSubject: Re: adjusting rear shocks    adjusting rear shocks I_icon_minitimeSat Nov 26, 2011 2:53 am
And also WD40 spray helps a lot.
No need to bey a wrench, i think.
http://edho@operamail.com
Number of posts : 3313
PostSubject: Re: adjusting rear shocks    adjusting rear shocks I_icon_minitimeSat Nov 26, 2011 7:35 am
Hand, leather gloves, WD-40. But doesn't the standard tool kit have a wrench just for the job?
jeff fisher
Number of posts : 2
PostSubject: from jeff fisher about shock adjusting    adjusting rear shocks I_icon_minitimeSat Nov 26, 2011 11:56 am
Thanks for all of the replys.I feel kind of dumb by not trying my hands to begin with.
Dale
Number of posts : 55
Registration date : 2010-10-07
PostSubject: Re: adjusting rear shocks    adjusting rear shocks I_icon_minitimeSat Nov 26, 2011 12:19 pm
I recommend gloves and being careful, as there is a possible pinch factor.
tinman
Number of posts : 1298
PostSubject: Re: adjusting rear shocks    adjusting rear shocks I_icon_minitimeTue Dec 06, 2011 9:29 am
I use a rigid small pipe strap to remove my oil filter it might work for that or wrap a strap around it then with a screw driver turn to the position that you need. It works for me.
toolboxjesse
toolboxjesse
Number of posts : 330
PostSubject: Re: adjusting rear shocks    adjusting rear shocks I_icon_minitimeTue Dec 06, 2011 9:41 am
My 2003 includes a spanner wrench in the tool kit (it's kind of a c-shaped bar of metal ) and that is the specific tool you need for this job. I weigh about 245 with all of my riding gear and I like the highest setting for a sporty ride(I guess it's 5). Basically it's the top setting before the spring resets to the softest setting (1).
jesse
Number of posts : 2392
PostSubject: Re: adjusting rear shocks    adjusting rear shocks I_icon_minitimeTue Dec 06, 2011 12:12 pm
jesse
Sorry if I appear to step on your toes here Jesse, not intended. But I read your comment as if the setting run 1 to 5 then back to 1 again in a continuous loop.
Caution fellow riders this is not the case. If you rotate the stainless steel base beyond setting 5 it will 'step' off the runner so to speak and you will have a more difficult job getting it back to as it was.
It is simple enough to reset if you do over step the hole, (setting 5). Centre stand and two hands now or the tool of course, to re-sit the adjuster correctly.
Apologies again Jesse I didn't want anyone to do as I did and have the thing unseat itself and possible injure their hands doing so.
DarthJ
Number of posts : 195
Registration date : 2011-09-27
PostSubject: Re: adjusting rear shocks    adjusting rear shocks I_icon_minitimeTue Dec 06, 2011 12:13 pm
Jesse, you actually have a tool kit? Honda seems to think a screwdriver works for everything now.
toolboxjesse
toolboxjesse
PostSubject: Re: adjusting rear shocks    adjusting rear shocks I_icon_minitimeTue Dec 06, 2011 12:29 pm
Yes I do, have you looked under your seat where the manual is you might have one too! :-)
DarthJ
PostSubject: Re: adjusting rear shocks    adjusting rear shocks I_icon_minitimeTue Dec 06, 2011 6:24 pm
LOL! All I got was a tool bag, foam and screwdriver.
Number of posts : 2387
PostSubject: Re: adjusting rear shocks    adjusting rear shocks I_icon_minitimeTue Dec 06, 2011 7:58 pm
x
roadrunner
roadrunner
Number of posts : 231
Registration date : 2010-12-12
PostSubject: Re: adjusting rear shocks    adjusting rear shocks I_icon_minitimeTue Dec 06, 2011 10:06 pm
Vodka, OJ, and milk of magnesia -- a Phillips screwdriver.
Number of posts : 2621
PostSubject: Re: adjusting rear shocks    adjusting rear shocks I_icon_minitimeWed May 30, 2012 8:16 am
Ditto the foam and screwdriver! That is all the 2012 comes with also. Seems weird for a MSRP of $9270.? My wife just bought a Honda Metropolitan to putt around on it it came with NO tools...
Thanks for the advice above on shock adjustment, will try it later today :-)
Boris1
Number of posts : 3
Registration date : 2013-05-06
PostSubject: Re: adjusting rear shocks    adjusting rear shocks I_icon_minitimeTue May 28, 2013 9:34 am
JeffR_ wrote:
Jeff,
Got my SW 600 2011 without tool kit. Just adjusted "use my hand".
Thank you, Jeff, for the advice.
JeffR_
JeffR_
PostSubject: Re: adjusting rear shocks    adjusting rear shocks I_icon_minitimeTue May 28, 2013 11:59 am
Boris,
Your welcome. I didn't get a tool either and I remembers that I was able to do this with my Reflex and just gave it a try and it worked.
Boris1
Number of posts : 3
PostSubject: Re: adjusting rear shocks    adjusting rear shocks I_icon_minitimeTue May 28, 2013 6:55 pm
Jeff, if you know how to replace spark plug with "use my hand", please, let me know)))
Good luck and thanks again
adventure boy
adventure boy
Registration date : 2013-05-12
PostSubject: Re: adjusting rear shocks    adjusting rear shocks I_icon_minitimeWed May 29, 2013 7:08 am
I just changed my tyres using the extensive Honda tool kit, I had to utilise a hammer and angle grinder from the shed to get them off then lots of duck tape to re assemble it all
Looks a bit funky but still works lol
RArch
RArch
Number of posts : 613
PostSubject: Re: adjusting rear shocks    adjusting rear shocks I_icon_minitimeWed May 29, 2013 8:00 am
Duck Tape!! Is this the new dark side?
tongue
http://www.rcmodeltalk.co.uk
Boris1
Number of posts : 3
PostSubject: Re: adjusting rear shocks    adjusting rear shocks I_icon_minitimeWed May 29, 2013 10:58 am
Ad.boy, hope one day you'll show me, I'm in Purley, Surrey .
Drink Vodka?
bikerboy
Number of posts : 405
PostSubject: Re: adjusting rear shocks    adjusting rear shocks I_icon_minitimeWed May 29, 2013 11:14 am
My 2011 had a reasonable toolkit with it but I wouldn't like to use it to change the tyres !!!
tinman
PostSubject: Re: adjusting rear shocks    adjusting rear shocks I_icon_minitimeWed May 29, 2013 11:22 am
If any one is capable of changing a tire using the swing toll kit and replace a tire with a hammer ,a grinder and duct tape ,make a video so can learn this new method. affraid
gizmoguy
Number of posts : 21
Registration date : 2013-06-23
PostSubject: Re: adjusting rear shocks    adjusting rear shocks I_icon_minitimeMon Jun 24, 2013 12:56 pm
Sounds like the next step is to see if a silver wing will 'blend'
toolboxjesse
toolboxjesse
PostSubject: Re: adjusting rear shocks    adjusting rear shocks I_icon_minitimeMon Jun 24, 2013 2:08 pm
BTW tool looks kinda like this:
http://www.motorcycle-superstore.com/14/71/995/44719/ITEM/BikeMaster-Shock-Spanner-Wrench.aspx
or
http://www.motorcycle-superstore.com/14/71/995/5006/ITEM/Motion-Pro-Shock-Wrench.aspx?SiteID=Google_PLA995&WT.mc_ID=10012&esvt=0-GOUSC&esvadt=9-0-3886819-1&esvaid=30548&kw={keyword}&gclid=COPp3qqk_bcCFWrl7AodHSMA8w
I'm using the honda tool that came with my tool kit, but one of these might do just as well.
Jesse in Atlanta
» Rear shock settings
» Tool for adjusting Shocks
» rear shocks help needed
» YSS Rear Shocks
» rear shocks
