- drewscrew13 wrote:
- I'm trying to install the TB19 on my silverwing. I using jeff picture guide. I followed everything to a tee but when I got ready to drill the two holes to secure the backrest the holes were securing the plate the holds
my E52 Monokey trunk.
I have both Givi E-52 and TB-19.
You only drill the four holes for the Givi E-52 which are premarked underneath the aluminum wing.
The Givi SR-19 is mounted first to the aluminum wing. You can lightly bolt together the two rear holes to hold in place.
I forget if the longer bolts came with the SR-19 or the TB-19. Do not use the same length bolts on front two holes ... use the longer bolts. The TB-19 sits on top of SR-19 plate further away from the aluminum wing.
If you are only installing the TB-19, you only drill the two front (close to the U portion aluminum wing) ... same holes as the SR-19.
