Headstock bearings I_icon_minitimeby MikeO Yesterday at 6:23 pm
Headstock bearings I_icon_minitimeby POCAHONTAS Yesterday at 6:05 pm
Headstock bearings I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Headstock bearings I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Headstock bearings I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Headstock bearings I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
Headstock bearings I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
Headstock bearings I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
Headstock bearings I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
Headstock bearings I_icon_minitimeby kbcmdba Mon Nov 04, 2024 7:56 pm
 Headstock bearings
3 posters
steveR
steveR
Number of posts : 218
Registration date : 2011-03-23
Headstock bearings Empty
PostSubject: Headstock bearings   Headstock bearings I_icon_minitimeFri Feb 17, 2012 3:34 pm
Just had the required annual MOT test on my swing, all well as i anticipated, but I did have an "advisory" on a notchy headrace bearing. All Hondas seem to suffer from undergreasing in this area!
Anyone else noticed this issue or had to swap the bearings or done a regrease?
I am not going to worry, as the steering is fine, hell the rubbish front forks are far more of a problem to the handling! Smile
Number of posts : 3313
PostSubject: Re: Headstock bearings   Headstock bearings I_icon_minitimeFri Feb 17, 2012 4:53 pm
Notch in Japanese Steering head bearing, long a problem---especially if there are free balls and cone-----at least temp fix and sometimes long term--- loosen everything up a little, including pinch bolts on top of steering crown, front axle a tad too, back off stem nut and then cone nut a little until notch goes away------shot of WD40 at top and bottom can give hardened grease new life. Then of course tighten everything, probably leaving front axle stuff to last until you have moved fork up and down a few times.
Now....and of course if the only way you can get the notch out is to have the bearing way loose.....check with bike on centerstand, fork legs in hand pulling back and forth....free play felt, re-adjust....and hope for best.
From pure safety and riding standpoint....steering head bearings too tight or notched.......very difficult to ride at super slow speeds for skilled rider....the unskilled may not notice as they have enough trouble anyway until they have built up the miles.
PostSubject: Re: Headstock bearings   Headstock bearings I_icon_minitimeFri Feb 17, 2012 10:43 pm
OMG! Mr. Grinsel. Do you have any idea how much anxiety & worrying your otherwise informative post has just caused Mr. Dimond?
Jeez, talk about unintended consequences and collateral damage I do hope you are up to answering his new stream of inquiries on this one.
steveR
steveR
PostSubject: Re: Headstock bearings   Headstock bearings I_icon_minitimeSat Feb 18, 2012 4:17 am
Cheers John, some damned useful tips in there, especially the WD40 one! Not come across that before Smile I tend to use a squirt of light chain/bearing lube (not bike chain lube!) for such tasks in the past. I know i need to tweak the front forks a tad as the bars are not quite true after I had the forks out last year to swap the oil, so I can see a mornings worth of little jobs coming up, with oil changes etc as well.
Love the final para!!
Headstock bearings
» fitting taper roller bearings to headstock and adjustment
» Front wheel bearings.
» front bearings?
» Allballs steering bearings
» Front Wheel Bearings
