Unknown sound I_icon_minitimeby sonuvabug Today at 12:10 pm
Unknown sound I_icon_minitimeby GHM-PM Today at 8:06 am
Unknown sound I_icon_minitimeby sonuvabug Yesterday at 4:17 pm
Unknown sound I_icon_minitimeby JohnyC Wed Nov 20, 2024 10:04 am
Unknown sound I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Unknown sound I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Unknown sound I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Unknown sound I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Unknown sound I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Unknown sound I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
 Unknown sound
tarmacburner2
micbusathens
tinman
rcarrillojr
rcarrillojr
Number of posts : 25
Registration date : 2012-08-19
Unknown sound Empty
PostSubject: Unknown sound   Unknown sound I_icon_minitimeFri Aug 24, 2012 8:52 pm
Hi, everyone. I am new to riding and my Silverwing is my first bike. I have loved almost every minute of riding it.
I know it's difficult to diagnose something without actually seeing it in person, so I'll try to be descriptive. When I am slowing down and I turn right into a parking space (5-10mph appx.), I can hear this purring sound around my front wheel or maybe even the steering stem. Either way, it is in the front, it only happens (or I can only hear it) when I'm turning right slowly, and it makes a "crrrrrrrrrrr" sound (roll the r).
Has anyone dealt with this in the past? I would appreciate your help. By the way, it's a 2007 SW with 8,400 miles. I've dropped it on its right side after turning over a puddle of algae and water. Maybe that affected it.
Thanks!
tinman
Number of posts : 1298
Unknown sound Empty
PostSubject: Re: Unknown sound   Unknown sound I_icon_minitimeFri Aug 24, 2012 9:19 pm
I had a sound like that coming from the glove box. It ended up being a box of tick tacks vibrating . The Swing makes many different sounds when slowing down from the clutch slowing you down,causing vibration coming from the front.Could be a broken tab when you fell,tire cupping.s Some of the things you learn to live with.Time will tell you if it needs fixing.
Unknown sound 510-80
Unknown sound Empty
PostSubject: Re: Unknown sound   Unknown sound I_icon_minitimeFri Aug 24, 2012 11:06 pm
Check all the sidepanels and tabs. Maybe something came loose.
micbusathens
micbusathens
Number of posts : 199
Unknown sound Empty
PostSubject: Re: Unknown sound   Unknown sound I_icon_minitimeSat Aug 25, 2012 12:12 am
Try to apply front brake only(right lever)when you hear that sound.If it stops then
could be rattling from the brake pads
tarmacburner2
tarmacburner2
Number of posts : 1099
Unknown sound Empty
PostSubject: Re: Unknown sound   Unknown sound I_icon_minitimeSat Aug 25, 2012 6:57 am
Using the front brake at slow speed and turning is a recipe for disaster.
Cheers,
micbusathens
micbusathens
Unknown sound Empty
PostSubject: Re: Unknown sound   Unknown sound I_icon_minitimeSat Aug 25, 2012 6:52 pm
For new bicycle riders that don't understand my point .....yes.They can also avoid rides on windy days.:-)
Number of posts : 3837
Unknown sound Empty
PostSubject: Re: Unknown sound   Unknown sound I_icon_minitimeSun Aug 26, 2012 6:04 am
My Silverwing emits a slight rumble from the front wheel (probably) in turns.
I think it's a characteristic of my bike and maybe others.
AFAIC it's just one of those things.....like the wires rattling in the fairing when I ride into Bruges over the cobbles.
rcarrillojr
Unknown sound Empty
PostSubject: Re: Unknown sound   Unknown sound I_icon_minitimeSun Aug 26, 2012 11:29 am
It's not a rumble, it's a purring sound as if some plastic were being rubbed against rubber. It only happens when I'm slowing down and turning right. It's not the brakes, as I've tried turning with and without them and it makes the noise both times.
Is it possible that when I'm turning, some part is coming in contact with a loose piece of plastic and causing it to vibrate?
tinman
Unknown sound Empty
PostSubject: Re: Unknown sound   Unknown sound I_icon_minitimeSun Aug 26, 2012 3:16 pm
Sound travels from the road to all the plastic bits in front of you . As you turn the sound can be more pronounce , the texture of the pavement produce different sounds.The more miles you put on your Swing,the more it will feel normal. Thats the way it is .The only solution is to Jack up the paint ,and drive a motorcycle with no plastic peaces on.Just drive it like you stole it,This beast will drive you nuts or the force will take you to the DS :lol!: frustrated
surlybiker58
surlybiker58
Number of posts : 350
Registration date : 2011-12-11
Unknown sound Empty
PostSubject: Re: Unknown sound   Unknown sound I_icon_minitimeSun Aug 26, 2012 6:24 pm
Are you sure it's not the sound of the cooling fan kicking in ?
buddy19520
buddy19520
Number of posts : 378
Unknown sound Empty
PostSubject: Re: Unknown sound   Unknown sound I_icon_minitimeTue Aug 28, 2012 3:32 pm
When you turn, more weight transfers to one fork leg allowing it to dive a bit. This can be enough to cause the rotor to rub on the brake pads. As one poster suggested, try LIGHTLY applying your front brake when making this turn. Not enough to slow the bike down, just enough to cause the pads to connect with the rotor. If the sound goes away, you have probably found the culprit.
If it bothers you enough, try using earplugs!
Number of posts : 4218
Unknown sound Empty
PostSubject: Re: Unknown sound   Unknown sound I_icon_minitimeTue Aug 28, 2012 3:53 pm
Wearing earplugs is always a good idea to prevent hearing damage. I can't be the only old git on here that suffers from tinnitus caused by the many years of riding without them. Crying or Very sad
Unknown sound
» Unknown part number
» Does This Sound Ok?
» LETS GET READY TO RUMBLE
» Sound System
» Strange sound or not?
