| synthetic oil | |
scooterboyz Scooter Rider
Number of posts : 25 Age : 55 Location : new haven, ct Points : 4447 Registration date : 2012-10-24
| Subject: synthetic oil Mon Nov 12, 2012 9:35 pm | |
| considering AMSOIL. Engine has 30k. are there additves FOR HIGHER HIGHER MILEAGE ENGINES and/or filter types recommended by HONDA. PROS AND CONS WELCOME. |
Number of posts : 1099 Age : 70 Location : Cleveleys, Lancashire, England Points : 6536 Registration date : 2010-03-27
| Subject: Re: synthetic oil Tue Nov 13, 2012 5:20 am | |
| Only my opinion but semi synthetic is more than adequate for any engine that is 'run in'
Cheers, |
Number of posts : 1298 Age : 76 Location : Matheson, Ontario, Canada Points : 6132 Registration date : 2011-11-29
| Subject: Re: synthetic oil Tue Nov 13, 2012 8:18 am | |
| I use the synthetic oil that Walmart has on sale at the time,and replace at Honda recommended time ,use Wick oil filter ,the longer one.I clean the filter in Varsol ,and replace every second oil change. Honda makes a bullet proof engine and last for 100K miles minimum. |
rollsroyce250 Scooter Rider
Number of posts : 73 Location : Florida Points : 4614 Registration date : 2012-06-21
| Subject: Re: synthetic oil Tue Nov 13, 2012 10:17 am | |
| - tinman wrote:
- use Wick oil filter ,the longer one.I clean the filter in Varsol ,and replace every second oil change.
You clean a spin on oil filter in solvent and replace it every second oil change? You Canucks sure have some crazy ideas on normal maintenance. |
alloo Scooter Rider
Number of posts : 12 Location : Denver, CO Points : 4578 Registration date : 2012-05-25
| Subject: Re: synthetic oil Tue Nov 13, 2012 10:28 am | |
| I've used Royal Purple or Amsoil in the past. Smooth performance. Less wear. |
| Subject: Re: synthetic oil Tue Nov 13, 2012 11:26 am | |
| I change the oil every 4 to 6 weeks all my riding on unpopulated HW,no pollution ,all clean air .After 10 k kl my oil is still clean , no dirt or metal peaces on screen. 30 k kl in 5 month a year riding,7 months hibernation every year. n Not the same as riding smog all the time. |
| Subject: Re: synthetic oil Tue Nov 13, 2012 11:41 am | |
| I assume you meant to say you clean the SCREEN, not filter, in varsol and replace the FILTER, not the screen, every second oil change. Your post made no sense when you said you clean the FILTER in varsol.
Also, you will never see dirt or metal pieces on the screen. The purpose of the screen is to prevent anything being sucked UP into the oil pump. That way if there were any foreign or loose engine parts in the sump they would not jam the oil pump and lead to complete loss of lubrication. |
| Subject: Re: synthetic oil Tue Nov 13, 2012 12:47 pm | |
| My owners manual recommend that the oil is to be change every 12k kl or 8400 K miles, I change the oil at 6 k kl and filter at 12 k kl recommended interval. Others on this forum some do there oil change and filter at a shorter interval, and my opinion is that a wast of time. Not that the filter needs cleaning at 6 k kl . I have 2 k kl since my last oil change and new oil and filter will be done and cylinder fogging for the winter. |
| Subject: Re: synthetic oil Tue Nov 13, 2012 4:00 pm | |
| - tinman wrote:
- My owners manual recommend that the oil is to be change every 12k kl or 8400 K miles,
8400 K miles = 8 400 000 miles. You're a funny guy. |
| Subject: Re: synthetic oil Tue Nov 13, 2012 4:11 pm | |
| We don't use miles ,the computer did a misprint . :lol!: It could worst I could have said Suzuki Bergman. That is when I get a good response . |
| synthetic oil | |
