Givi Windshield Install Question I_icon_minitimeby sonuvabug Today at 4:19 pm
Givi Windshield Install Question I_icon_minitimeby sonuvabug Today at 4:17 pm
Givi Windshield Install Question I_icon_minitimeby sonuvabug Today at 4:06 pm
Givi Windshield Install Question I_icon_minitimeby JohnyC Yesterday at 10:04 am
Givi Windshield Install Question I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Givi Windshield Install Question I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Givi Windshield Install Question I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Givi Windshield Install Question I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Givi Windshield Install Question I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Givi Windshield Install Question I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
Givi Windshield Install Question Empty
PostSubject: Givi Windshield Install Question   Givi Windshield Install Question I_icon_minitimeThu Jun 04, 2009 6:37 am
I will be receiving my windshield today. About the 4 screws that must be removed I can see the two that are just above the headlight that look like they are holding the plastic molding that holds the windshield in place. I just want to confirm that the other two scres are those on the riders side of the windshield at each end of the "dashboard" where the stock windshield meets the dashboard. To me those don't look like they would have anything to do with replacing the windshield, but I don't see any other screws so they must be the ones.
Can anyone confirm this for me. Thanks.
Number of posts : 1995
PostSubject: Re: Givi Windshield Install Question   Givi Windshield Install Question I_icon_minitimeThu Jun 04, 2009 7:49 am
Jay600,
The two screws on the dashboard side - these are located in the small triangular projections on either side of the windscreen above the two outermost dashboard vents. These two screws are machine screws as opposed to the two screws above the headlight which are self tapping screws.
Take care when removing the windscreen garnish; it is removed by sliding it forward. After removing the screws, insert your thumbs into the opening in the garnish and lift slightly up and pull the garnish forward. You may find it helpful to slide a stiff piece of plastic under the lower points of the garnish to facilitate the removal.
Number of posts : 1288
PostSubject: Windshield removal pictorial   Givi Windshield Install Question I_icon_minitimeThu Jun 04, 2009 8:16 am
Hey Jay... Jeffr has posted this very helpful pictorial. Look at it and see if it can help you. Good luck and be sure to thank Jeff if it helps.
https://www.silverwing600.com/silver-wing-accessories-modifications-f5/givi-windshield-installation-pictorial-t46.htm?highlight=replacing+windshield
If for some reason the link doesn't work for you, do a search for windshield removal and find the link from Jeff. Good luck again. Gary
PostSubject: Re: Givi Windshield Install Question   Givi Windshield Install Question I_icon_minitimeThu Jun 04, 2009 10:26 am
Thanks a lot for the pictures and reference. I was able to get them printed off. I'm really going to have to take a closer look for those upper set of screws. I must have been half(more like totally) asleep. From the pictorial I was definitely looking at the wrong screws.
Thanks agains for the reference.
mr fish
mr fish
Number of posts : 276
Registration date : 2009-03-23
PostSubject: Re: Givi Windshield Install Question   Givi Windshield Install Question I_icon_minitimeThu Jun 04, 2009 6:19 pm
Put my screen on today the pictorial was a great help so thank you jeffr
however my tip of the day is becareful if the screws are seized one of mine at the front rounded off so i went to drill it out and all it did was heat the screw and it melted the plastic doh Crying or Very sad
Number of posts : 2387
PostSubject: Re: Givi Windshield Install Question   Givi Windshield Install Question I_icon_minitimeSat May 29, 2010 7:50 pm
I put my GIVI on today. Again, thanks to Jeff for his excellent tutorials. I also passed on the install of the two white metal reinforcing brackets. I reason that since I don't drive crazy fast on the highway (maximum I go is 110 km/h, as that's the highest speed limit in the province and I don't want or need any speeding tickets) then the GIVI won't be unduly stressed. If I drove regularly at 130+ km/h into strong cross or headwinds, then I would have probably gone with the reinforcement.
Number of posts : 2598
PostSubject: Re: Givi Windshield Install Question   Givi Windshield Install Question I_icon_minitimeSat May 29, 2010 9:14 pm
Bigbird,
Glad it helped you out. I didn't put those brackets on either and I have been over 100 mph by GPS. I also cut mine down about an inch or so and it still keeps the wind off my head, and I"m 6' with a long torso. I wish I would have done a better job cuttint it though. The XL Clearview (with vent) I had flexed way too much which is why I bought the Givi. But only a few of us had that problem.
ridr44
Number of posts : 72
Registration date : 2010-06-04
PostSubject: Installed Givi Screen   Givi Windshield Install Question I_icon_minitimeFri Jun 04, 2010 7:17 am
Jeff, I now have my second SW 2002. I had installed my last givi without your instructions and I must highly compliment and thank you for the detailed posting. It was supremely easy. I want to know if you think there are any risks by not using their little brackets? You said you didn't use them and I followed you on this install...any risk at high speed??? Thanks so much dan
ridr44
PostSubject: Re: Givi Windshield Install Question   Givi Windshield Install Question I_icon_minitimeFri Jun 04, 2010 7:20 am
Also...the givi is a bit tall for me too...I dealt with it last sw around but do people cut them down on a regular basis? And how? Thanks agian dan
» How do you install a Givi Windshield?
» AF214 Givi windshield
» Givi AF214 Airflow Adjustable Windshield install on 2012 SW
» Kappa KAF214 Windshield Install
» Givi TB19 & SR19 Install
