| 02 Swing stalling mid range when WOT | |
WingMan02 Super Scooter Rider
Number of posts : 287 Location : Honolulu Points : 5020 Registration date : 2012-01-19
| Subject: 02 Swing stalling mid range when WOT Thu Jan 03, 2013 9:19 pm | |
| Lately, my 02 Swing stalls in the mid RPM range when I open the throttle fully. I just changed my Dr slider from 26gm to 24gm. I am also adding an oz of Berrymans's B12 cleaner to a gallon of gas. Can the battery be a cause? It seems to run WOT fine after about 2 miles. |
| Subject: Re: 02 Swing stalling mid range when WOT Thu Jan 03, 2013 10:01 pm | |
| How many miles on your Swing? |
| Subject: Re: 02 Swing stalling mid range when WOT Fri Jan 04, 2013 4:43 am | |
| Subject: Re: 02 Swing stalling mid range when WOT Fri Jan 04, 2013 5:45 am | |
| Have you replace your valve shims. The owners manual says to replace them about that time.Those that had engine cut out seams to be around the 80k kl range. Most Swing owners don't put that many miles on them.It could be some other problem that others could have a fix for you. Did you re start your Swing. |
| Subject: Re: 02 Swing stalling mid range when WOT Fri Jan 04, 2013 7:07 pm | |
| It starts and runs fine. I ride it everyday. Just lately, when I give it the gas (WOT), I notice a hesitation like it is starving for fuel. I was just wondering if the change from 28gm rollers, to 26gm sliders, to the now 24gm sliders may be too much rpm for the capacity of the fuel pump, or could it be the battery. I purchased the bike 12 months ago and do not know when the battery was replaced. The feeling of hesitation happened yesterday after riding about a mile. After it hesitated twice, I could not get it to hesitate again. Did not try it today. |
| Subject: Re: 02 Swing stalling mid range when WOT Fri Jan 04, 2013 9:26 pm | |
| BY increasing the rpm there could have cause a stutter the way the valves operate on acceleration ,you might go on U tub or talk to a mechanic that might shed some light . Keep riding your wing and see where it take you.Fuel filter might need changing. |
| Subject: Re: 02 Swing stalling mid range when WOT Sat Jan 05, 2013 10:44 pm | |
| Check your spark plugs
Try using a fuel cleaner. It sounds similar to what I noticed ... I used Amsoil PI ( http://www.amsoil.com/shop/by-product/fuel-additives/gasoline/p-i-performance-improver-gasoline-additive ) which worked. Now I use it periodically to avoid the hesitations. |
| Subject: Re: 02 Swing stalling mid range when WOT Mon Jan 07, 2013 5:39 am | |
| For this Brit. What is WOT? |
| Subject: Re: 02 Swing stalling mid range when WOT Mon Jan 07, 2013 5:54 am | |
| - Waspie wrote:
- For this Brit. What is WOT?
It's obviously not Wanking On Toilet is it! |
| Subject: Re: 02 Swing stalling mid range when WOT Mon Jan 07, 2013 6:07 am | |
| I only got as far as; wide open throttle waste of time wine on table |
Silverwing28681 Scooter Rider
Number of posts : 94 Location : Taylorsville, NC Points : 4584 Registration date : 2012-08-16
| Subject: Re: 02 Swing stalling mid range when WOT Tue Jan 08, 2013 6:16 pm | |
| Subject: Re: 02 Swing stalling mid range when WOT Wed Jan 09, 2013 6:22 pm | |
| UPDATE!! Must have been rubbish stuck in the injectors. I am not able to reproduce the problem. WOT stands for Wide Open Throttle. Thanks all for the input. I have been using carb cleaners. |
