| ABS vs Non-ABS | |
+7Dimond GHM-PM honda_silver rodenbach Nowun Silverwing28681 XLS 11 posters |
XLS Scooter Rider
Number of posts : 6 Location : South TX Points : 4328 Registration date : 2012-12-31
| Subject: ABS vs Non-ABS Sun Jan 06, 2013 3:06 pm | |
| Newbie question:
Is there a substantial difference on braking performance, safety etc...?
I'm looking at two SW's that are for sale, one has it the other doesn't.
Hopefully the members can share thoughts and experiences.
Thanks! |
Silverwing28681 Scooter Rider
Number of posts : 94 Location : Taylorsville, NC Points : 4565 Registration date : 2012-08-16
| Subject: Re: ABS vs Non-ABS Sun Jan 06, 2013 3:37 pm | |
| How much is the price difference ? If it is not to much I would get the ABS, If they are about the same with the miles and condition
Nowun Super Scooter Rider
Number of posts : 288 Age : 71 Location : Hampshire, England Points : 4695 Registration date : 2012-10-13
| Subject: Re: ABS vs Non-ABS Sun Jan 06, 2013 3:54 pm | |
| The only thing ABS does is stop the wheels from locking when braking heavily. There is no increase in stopping power. If the road is wet, icy, oily, gravely etc, it is easier to lock the wheels when braking. ABS will momentarily release the brake and allow the wheel to keep turning before re-applying it.
It's a bonus if you can afford it - like SW28681 said.
We used to do it manually (without the aid of electronics) in the old days - it was called cadence braking. |
Number of posts : 321 Age : 68 Location : Belgium Points : 4828 Registration date : 2012-08-30
| Subject: Re: ABS vs Non-ABS Sun Jan 06, 2013 4:43 pm | |
| ABS is the reason I bought a 600 SW. Prior, I had a test ride on the 400cc version and liked the scoot a lot, but beeing an old geezer that already broke two vertebrae, I decided this little extra safety feature was more than welcome.
I.m.h.o. ABS should be mandatory on all two-wheelers: unlike a car where you can release the brakes once you start skidding, motorbikes tend to hit the deck before you are able to react. |
Number of posts : 2453 Location : Georgetown, Tx Points : 8348 Registration date : 2008-12-23
| Subject: Re: ABS vs Non-ABS Sun Jan 06, 2013 6:44 pm | |
| - XLS wrote:
- Is there a substantial difference on braking performance, safety etc...?
Quit a number of times the ABS pulsed when I did not expect it and it was my only warning. For example my wife and I were riding together, we were coming to a "Y" intersection where you either go straight or slow angle right turn which we were going to take at speed. It was a very hot day with no moisture with no detectable road surface problems, but when I applied some brake pressure the ABS started pulsing non-stop. I decided to switch to stopping straight. It took me even longer to stop ( even past stop sign ). When I put my foot down the rocks just slide away ... It was very tricky getting a footing. After I was stopped I found a long black streak for the entire length that I braked ... it was like braking on marbles ( which I would not recommend ). The was no warning sign or anything which may have per-warned me. The ABS saved me and my wife and I consider it worth any cost. I would not want to have any motorcycle without ABS ( just like my cars ).
Number of posts : 2616 Age : 72 Location : Bullhead City, AZ Points : 7480 Registration date : 2012-05-17
| Subject: Re: ABS vs Non-ABS Sun Jan 06, 2013 7:59 pm | |
| I also agree go with ABS if you can swing (pun intended) it. It uses nothing UNLESS you need it and you never know when that might be, see the post above. It was a selling point for me on my Swing; that and the fuel injection!!! |
Dimond Silver Wing Expert
Number of posts : 540 Age : 79 Location : San Francisco Bay Area Points : 5509 Registration date : 2011-08-07
| Subject: Re: ABS vs Non-ABS Mon Jan 07, 2013 12:06 pm | |
| - XLS wrote:
- Newbie question:
Mother Honda only sells (now) the SWing with ABS. I got rid of my non-ABS SWing to get one with ABS - now I apply the brakes HARD to scrub off speed (when going straight and as appropriate) rather than under-applying my brakes as I often did in the past with non-ABS (as I had great fear of going down due to inappropriate braking, i.e., low side or high side crash). For new SWing riders, it is even more important to have ABS brakes; however, ABS is not a cure-all for braking as you need to know the when, how, where, and why of braking (and practice it) and not think that ABS is going to be your sole savior. It is a bit harder (in my state) to find ABS - but not that much more in money than non-ABS - but it is worth the wait. If you can't find an ABS model - then go for what is available and trade up when the opportunity presents itself. |
Number of posts : 3309 Age : 85 Points : 9435 Registration date : 2009-08-18
| Subject: Re: ABS vs Non-ABS Mon Jan 07, 2013 5:43 pm | |
| ABS----wet/slippery/heavy traffic, etc can save your bacon---Great substitue for low skill level. But you have to learn to use it! Soon to be mandatory in EU countries.
Ride in variety of conditions very useful. great aide in keeping bike upright.Drop PLASTIC SCOOTER and can be very expensive. |
Number of posts : 2940 Age : 75 Location : Winnsboro, Texas, U.S.A. Points : 8534 Registration date : 2010-02-17
| Subject: Re: ABS vs Non-ABS Thu Jan 10, 2013 2:13 pm | |
| An ABS equipped bike would probably have better re-sale value. |
Number of posts : 2658 Age : 81 Location : Medford, Oregon Points : 8374 Registration date : 2009-07-17
| Subject: Re: ABS vs Non-ABS Fri Jan 11, 2013 1:13 am | |
| I had ABS on my GL1800 Goldwing and loved it for operating on gravel roads. Takes the worry out of stopping in a hurry on gravel and sandy dirt roads. While it's true that a skilled rider can do better without ABS there are times when even the best rider doesn't have much time to react. Rounding a curve and finding a deer in front of you makes ABS pay off big time. I don't have it on my SW but would have liked it. The only downside is it does add a good bit of complication to the brake system. |
DarthJ Maxi-Scooter Rider
Number of posts : 195 Age : 50 Location : Hell Paso Points : 5001 Registration date : 2011-09-27
| Subject: Re: ABS vs Non-ABS Fri Jan 11, 2013 12:32 pm | |
| - rodenbach wrote:
- I.m.h.o. ABS should be mandatory on all two-wheelers: unlike a car where you can release the brakes once you start skidding, motorbikes tend to hit the deck before you are able to react.
That's why I'm going with a Victory when I can afford a bike payment again. The Cross Country, Cross Country Tour and Vision all have ABS standard and are MUCH less expensive than an ABS -equipped Goldwing. |
| ABS vs Non-ABS | |
