mbcal27 Scooter Rider
Number of posts : 3 Location : Berkeley Points : 4323 Registration date : 2013-01-21
| Subject: newbie from CA Mon Jan 21, 2013 4:57 pm | |
| Hello All,
Just bought an 05 Swing that I just hauled up on an truck to UC Berkeley from San Diego to use for school. Made it all 500 miles just fine but when I went to back it down on a metal ramp from the carrier, it bottom out and severed a coolant hose draining pretty much all the coolant. It cut where a small hose meets a larger hose right next to the oil filter. I've been trying to see which hoses these are on parts schematics but can't quite sort it out, any help? |
RArch Silver Wing Expert
| Subject: Re: newbie from CA Mon Jan 21, 2013 5:46 pm | |
| A photo would help us to id the pipe. |
DarthJ Maxi-Scooter Rider
Number of posts : 195 Age : 50 Location : Hell Paso Points : 5020 Registration date : 2011-09-27
| Subject: Re: newbie from CA Mon Jan 21, 2013 5:55 pm | |
| Kinda curious how bottoming out would cause the hose to sever. Post a good pic of the area and the gurus here may be of assistance. |
| Subject: Re: newbie from CA Mon Jan 21, 2013 6:31 pm | |
| It was bottomed out on the corner of the ramp and a lot of the scooter's weight was on this hose. My buddy proceeded to keep yanking the scooter to get it free but it ended up severing the hose. I can't take a picture because it's at my buddy's but I drew an arrow in the attached image where it cut.... - Attachments
- (66 Kb) Downloaded 31 times
jmaslak Super Scooter Rider
Number of posts : 252 Location : Golden, CO, USA Points : 4805 Registration date : 2012-06-15
| Subject: Re: newbie from CA Mon Jan 21, 2013 7:44 pm | |
| Little hose, big hose, or tee fitting?
None are super expensive. Big hose is the most expensive at $30 or so. Others are less than $10.
The hose that wraps around the oil filter is going from the tee to the oil cooler. The big hose is the lower radiator hose. |
| Subject: Re: newbie from CA Mon Jan 21, 2013 10:37 pm | |
| From what I remember, the little hose that wrapped around the oil filter and was connected to the larger hose. That junction is where it severed. |
| Subject: Re: newbie from CA Tue Jan 22, 2013 12:34 pm | |
| I had a small cut on top of that hose that would only leak under pressure. Atrip to the local auto parts store for a short piece of hose and the problem was fixed. |
