Number of posts : 2392 Age : 72 Location : Portland, UK Points : 8124 Registration date : 2009-07-26
| Subject: Noise problem!!! Mon Mar 18, 2013 4:22 pm | |
| OK good people, thinking caps on time.
I have a noise eminating from around the front wheel when in motion.
It's a knocking/tapping sound. The noise dissapears when I squeeze the right brake lever, re-appears once the brake is released.
The wheel bearings were replaced less than 700 miles ago so I hope I can rule them out.
Anyone have any ideas? Thank you in advance. |
Number of posts : 1099 Age : 70 Location : Cleveleys, Lancashire, England Points : 6510 Registration date : 2010-03-27
| Subject: Re: Noise problem!!! Mon Mar 18, 2013 4:35 pm | |
| Possibly a slightly loose disc pad but more likely the caliper itself. From what you write when the brake is applied the noise goes away so to my way on thinking the slight increase in pressure on the pads is allowing the caliper to 'firm up'. Caliper not tightened up when wheel bearing replaced.
A belated Happy Birthday btw.
Cheers, |
Number of posts : 1298 Age : 76 Location : Matheson, Ontario, Canada Points : 6106 Registration date : 2011-11-29
| Subject: Re: Noise problem!!! Mon Mar 18, 2013 6:09 pm | |
| Try lifting the front wheel of the ground and spin by hand .Take a long screw driver and apply one end on the axle bolt and to your ear and see if there is any grinding going on. |
Number of posts : 199 Age : 63 Location : Athens Greece Points : 4819 Registration date : 2012-04-05
| Subject: Re: Noise problem!!! Tue Mar 19, 2013 12:42 am | |
