Honda requires urgent shipment of grease I_icon_minitimeby MikeO Thu Nov 14, 2024 6:23 pm
Honda requires urgent shipment of grease I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Honda requires urgent shipment of grease I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Honda requires urgent shipment of grease I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Honda requires urgent shipment of grease I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Honda requires urgent shipment of grease I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
Honda requires urgent shipment of grease I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
Honda requires urgent shipment of grease I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
Honda requires urgent shipment of grease I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
Honda requires urgent shipment of grease I_icon_minitimeby kbcmdba Mon Nov 04, 2024 7:56 pm
SCTLVR
bikerboy
tinman
RArch
Dave Weller
11 posters
Dave Weller
Number of posts : 85
Registration date : 2011-11-09
Honda requires urgent shipment of grease Empty
PostSubject: Honda requires urgent shipment of grease   Honda requires urgent shipment of grease I_icon_minitimeWed Apr 10, 2013 4:06 pm
My scooter is now a year old, so I decided to do a self service.
I've noted that it was put together 'dry'.
No sign of any grease on wheel spindles, brake shims or anything else, all the exhaust mounting bolts were dry.
Hopefully the next service will be easy, and my additional greasing/protection will keep the salt corrosion at bay.
RArch
RArch
Number of posts : 613
PostSubject: Re: Honda requires urgent shipment of grease   Honda requires urgent shipment of grease I_icon_minitimeWed Apr 10, 2013 5:00 pm
Yes, I can confirm the very same with mine and a friends. Recently we had new tyres fitted and removed the wheels ourselves everything that should have been greased needed some.
Doesn't it feel good that you know its all been done Smile
http://www.rcmodeltalk.co.uk
Number of posts : 1020
PostSubject: Re: Honda requires urgent shipment of grease   Honda requires urgent shipment of grease I_icon_minitimeWed Apr 10, 2013 5:15 pm
Hi All,
I've not been in the manual for quite some time now 'cuz I just haven't done any maintenance lately or needed to. Still, what maintenance I 'have' done required no "greasing". Are there many items (nuts, bolts, etc) that require greasing? Even if there are some, when you get the job done, there shouldn't be excess grease all over the parts. So, just because you didn't see any grease (or any other lubricant) doesn't mean it wasn't applied; only that someone (factory assemblers or a good mechanic) properly followed good (or required) maintenance procedures and cleaned up as necessary.
PostSubject: Re: Honda requires urgent shipment of grease   Honda requires urgent shipment of grease I_icon_minitimeWed Apr 10, 2013 5:50 pm
Just from memory I know you need to put a very a little grease on the spline of the axle, if it rusts you will have a heck of a time removing the rim.
RArch
RArch
PostSubject: Re: Honda requires urgent shipment of grease   Honda requires urgent shipment of grease I_icon_minitimeWed Apr 10, 2013 6:48 pm
Yeah, the axle and dust seals in the wheels (after cleaning) require some grease. The rear axle has a shallow 3mm grove which should be filled with grease.
When I fitted new brake pads, the backs and sliding points where lightly coated with copper grease. The pistons once cleaned with a toothbrush where also given a light coating which hopefully will make them easier to clean next time. I didn't touch the seals on the sliders but you should use red rubber grease on them as other greases may cause them to swell.
tinman
Number of posts : 1298
PostSubject: Re: Honda requires urgent shipment of grease   Honda requires urgent shipment of grease I_icon_minitimeWed Apr 10, 2013 8:04 pm
The clutch bell bearing gets dry and will squeal when dry.
bikerboy
Number of posts : 405
PostSubject: Re: Honda requires urgent shipment of grease   Honda requires urgent shipment of grease I_icon_minitimeThu Apr 11, 2013 6:00 am
When I had my rear wheel out I used some Rocol ASP moly compound left over from my ST1100 days on the splines. It's not mentioned in the manual but I don't think it will harm and might prevent problems. I always smear axles with grease befors replacing them.
Dave Weller
PostSubject: Re: Honda requires urgent shipment of grease   Honda requires urgent shipment of grease I_icon_minitimeThu Apr 11, 2013 6:59 am
I always have 3 pots of different grease to apply to anything that moves on the bike, a black moly grease is one of them left over from my Pan-European days, the first thing that usually seizes up on bikes is the centre stand shaft, I have grease spray cans for that.
I don't use copper slip grease on anything other than the brake parts and hot exhaust bolts, as it tends to dry and become hard over time.
I use LM (high melting point) grease for wheel bearings, at the time of a service, I force fresh grease past the seals, if nothing else it waterproofs them.
SCTLVR
Number of posts : 186
Registration date : 2012-06-27
PostSubject: Re: Honda requires urgent shipment of grease   Honda requires urgent shipment of grease I_icon_minitimeThu Apr 11, 2013 12:47 pm
Ditto, nighthawk250.
Assembly lube on fasteners makes future service much easier.
Don't forget to use a torque wrench and go by the Service Manual's spec's.
bikerboy
PostSubject: Re: Honda requires urgent shipment of grease   Honda requires urgent shipment of grease I_icon_minitimeThu Apr 11, 2013 2:48 pm
Please, what is assembly lube ? I was taught never to use a torque wrench on lubed components.
Dave Weller
PostSubject: Re: Honda requires urgent shipment of grease   Honda requires urgent shipment of grease I_icon_minitimeThu Apr 11, 2013 5:41 pm
You was taught well bikerboy, never use a torque wrench on lubed components, I only use a torque wrench, if I'm likely to strip a thread, eg sump plug thread, and do expensive damage.
Assembly lube= grease.
rollsroyce250
Number of posts : 73
Registration date : 2012-06-21
PostSubject: Re: Honda requires urgent shipment of grease   Honda requires urgent shipment of grease I_icon_minitimeThu Apr 11, 2013 6:44 pm
Assembly lube= heavy motor oil fortified with moly to reduce initial pressure damage. The moly coats the interfering surfaces so they don't gall or seize.
PostSubject: Re: Honda requires urgent shipment of grease   Honda requires urgent shipment of grease I_icon_minitimeThu Apr 11, 2013 7:21 pm
That's an interesting concept. Does it apply only to motorcycles? I'm asking out of curiosity only because as an aircraft engine technician, we had torque applications for both "dry" (unlubricated) and "wet" (lubricated) torque on nuts, bolts, etc, applied as dictated in the tech manual.
I had personally just never heard of it being inappropriate to apply torque wrenches to lubricated parts. So, how would you properly 'tighten' a lubricated fastener/assembly if there is no specification??
jmaslak
Number of posts : 252
PostSubject: Re: Honda requires urgent shipment of grease   Honda requires urgent shipment of grease I_icon_minitimeThu Apr 11, 2013 9:32 pm
The variator bolt must be lubricated and torqued with a torque wrench. Other bolts have dry specs listed. But lubing a bolt where that isn't necessary and torquing to dry specs will cause you to over torque it.
FWIW, I haven't seen any hard to remove bolts even on a six year old Swing.
bikerboy
PostSubject: Re: Honda requires urgent shipment of grease   Honda requires urgent shipment of grease I_icon_minitimeFri Apr 12, 2013 4:39 am
I've never had to torque anything that had a 'wet' specification but if that's what the book says I would have done it. Being an amateur I tend to go by the book altho' I used have a lot of prompting from my late father in law who serviced the Merlin engines in WW11 !!
tarmacburner2
tarmacburner2
Number of posts : 1099
PostSubject: Re: Honda requires urgent shipment of grease   Honda requires urgent shipment of grease I_icon_minitimeFri Apr 12, 2013 8:37 am
What all of them Question Did they give him a petrol ration or did he have to use a treader?
What a loveley sound that engine makes, especially when four of them are on a Lancaster.
Cheers,
Colin B
Colin B
Number of posts : 586
Registration date : 2013-03-20
PostSubject: Re: Honda requires urgent shipment of grease   Honda requires urgent shipment of grease I_icon_minitimeFri Apr 12, 2013 9:15 am
I once encountered a Rolls Royce (car) into which the owner had fitter a Merlin engine, under an extended bonnet. It sounded wonderful.
I've seen many a stretched limo, but none quite like that.
Rolls Royce disowned it! Evil or Very Mad
Dave Weller
PostSubject: Re: Honda requires urgent shipment of grease   Honda requires urgent shipment of grease I_icon_minitimeFri Apr 12, 2013 9:54 am
I know the car. Rolls objected to the radiator and flying lady IIRC,
Colin B
Colin B
PostSubject: Re: Honda requires urgent shipment of grease   Honda requires urgent shipment of grease I_icon_minitimeFri Apr 12, 2013 10:49 am
I think they saw it as a travesty and weren't prepared to support it, or acknowledge it as one of theirs.
How do you know of it?
I saw it when it was brought to the (late, lamented) Television Centre for inclusion on a programme.
SCTLVR
PostSubject: Re: Honda requires urgent shipment of grease   Honda requires urgent shipment of grease I_icon_minitimeFri Apr 12, 2013 11:12 am
Yes, assembly lube with moly and do torque the bolts, according to research and articles in Racecar Engineering and Race Tech. Without lubrication, actual torque can be well below the necessary stress required to securely bind threads together because of additional "drag" induced by oxidized threads.
To be certain that a fastener is properly tightened there is only one true method: bolt stretch with clean dry/lubed threads. Second choice with used threads is chase the threads with a tap, lube and torque. Lube also allows for easy future removal.
"Opinions" vary, of course, that's why they're called opinions. Even fastener experts are not in complete agreement on lubricating threads...
Dave Weller
PostSubject: Re: Honda requires urgent shipment of grease   Honda requires urgent shipment of grease I_icon_minitimeFri Apr 12, 2013 3:32 pm
Colin
http://en.wikipedia.org/wiki/Rolls-Royce_Merlin_alternative_uses
I used to drink in the Dukes Head nr. Epsom in the 60's, the editor of Custom Car Magazine was also a customer, who got a few of my mechanic friends in the motor trade, interested in custom cars, one of which was getting Beast on the road, They were always working on projects for the magazine and Santa Pod.
Colin B
Colin B
PostSubject: Re: Honda requires urgent shipment of grease   Honda requires urgent shipment of grease I_icon_minitimeFri Apr 12, 2013 5:11 pm
Probably the same one - how many could there be?
I saw it in the early 70's and it was presented as a genuine, modified, Roller. Apart from the stretch, it looked the business.
My ailing memory says it was brought in to appear on the "Record Breakers" programme, which fits with the link.
RArch
RArch
PostSubject: Re: Honda requires urgent shipment of grease   Honda requires urgent shipment of grease I_icon_minitimeFri Apr 12, 2013 6:43 pm
To get us back on topic this I'm sure needed some grease Wink
» Type of Grease for Driven Pulley Assy.
» Brake Caliper Grease
» Detrimental effects of Copper Grease
» Rear Wheel Spindle Grease?
» Repacking Driven Pulley Assembly Grease
