» Rear wheel valve stem
Fuel system problem I_icon_minitimeby Meldrew Today at 12:28 am
Fuel system problem I_icon_minitimeby Hop Yesterday at 7:04 pm
Fuel system problem I_icon_minitimeby COMick Fri Nov 22, 2024 6:13 pm
Fuel system problem I_icon_minitimeby xwelder Fri Nov 22, 2024 12:31 pm
Fuel system problem I_icon_minitimeby sonuvabug Thu Nov 21, 2024 4:17 pm
Fuel system problem I_icon_minitimeby JohnyC Wed Nov 20, 2024 10:04 am
Fuel system problem I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Fuel system problem I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Fuel system problem I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Fuel system problem I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
 Fuel system problem
realmccoy
Number of posts : 1
Registration date : 2013-05-30
Fuel system problem Empty
PostSubject: Fuel system problem   Fuel system problem I_icon_minitimeThu May 30, 2013 10:42 pm
Have a 2002 Silverwing . Removed fuel line from fuel rail seems to be an enough fuel coming from the tank when I turn the key on. When it starts it idles rough until I peck on fuel rail then it runs like new for 1 maybe 2 miles then starts to lose power gradually sounds like its just hitting on 1 cyclindar . Pull over to shoulder peck on fuel rail and runs like new again. Any kind of suggestions would be much appreciated.
soc714
Number of posts : 3
Registration date : 2013-05-31
PostSubject: Re: Fuel system problem   Fuel system problem I_icon_minitimeFri May 31, 2013 12:47 am
I use an ounce of fuel injection cleaner every other fill up or so.
wingmann
wingmann
Number of posts : 58
Registration date : 2010-08-22
PostSubject: Re: Fuel system problem   Fuel system problem I_icon_minitimeFri May 31, 2013 3:31 am
Maybe the fuel pressure regulator is bad .
PostSubject: Re: Fuel system problem   Fuel system problem I_icon_minitimeFri May 31, 2013 11:18 am
+1 on the fuel injector cleaner. Only I would add 1/2 a can to a full tank and the the other 1/2 of the can to the next tankful.
I would also get at fuel pressure regulator to have on hand. They are not all that expensive and an easy DIY change if needed.
stanly
Number of posts : 49
Registration date : 2013-04-05
PostSubject: Re: Fuel system problem   Fuel system problem I_icon_minitimeMon Jun 03, 2013 2:22 pm
u have same yr as mine, backtrack to see my symptoms, think general opinion was 10yrs old = about due.
Honda recommends the O-ring too
Fuel system problem
» Fuel tank removal (fuel pump replacement)
» fuel pump issue
» is it a misfire or fuel problem
» Fuel pump problem or what !
» Charging system
