rcarrillojr Scooter Rider
Number of posts : 25 Location : Bakersfield, CA Points : 4524 Registration date : 2012-08-19
| Subject: PGMFI Light - HELP!! Thu May 30, 2013 11:30 pm | |
| My 2007 Silverwing has 16,000 miles on it. I changed the spark plugs, oil, air filter, drive belt, and rear tire at 15,000 miles and my bike felt amazing right after.
As of late, I have noticed that the red PGMFI light (not the brake light) has been coming on randomly. Every time is turns on, my RPMs dropped drastically and my bike loses power. Then it will just rev back up. I look like a novice rider trying to shift gears on an automatic bike.
My bike will try to stay on and sometimes when I get to a stop, the RPM will drop below 1,500 RPM and the bike will try to turn off. I have to rev it to keep the RPM at around 2K-2.5K RPM.
What do I do? Does it sound like a fuel filter issue? I've treated the gas, but it doesn't do anything. |
soc714 Scooter Rider
Number of posts : 3 Location : Lafayette, Ind Points : 4196 Registration date : 2013-05-31
| Subject: Re: PGMFI Light - HELP!! Fri May 31, 2013 12:45 am | |
| Could be a fuel pump, fuel pump relay best get to the dealer before it leaves you stranded. |
