Final drive oil level check I_icon_minitimeby Meldrew Today at 8:01 am
» Rear wheel valve stem
Final drive oil level check I_icon_minitimeby GHM-PM Today at 6:43 am
Final drive oil level check I_icon_minitimeby COMick Fri Nov 22, 2024 6:13 pm
Final drive oil level check I_icon_minitimeby xwelder Fri Nov 22, 2024 12:31 pm
Final drive oil level check I_icon_minitimeby sonuvabug Thu Nov 21, 2024 4:17 pm
Final drive oil level check I_icon_minitimeby JohnyC Wed Nov 20, 2024 10:04 am
Final drive oil level check I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Final drive oil level check I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Final drive oil level check I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Final drive oil level check I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
3 posters
Number of posts : 757
Final drive oil level check Empty
PostSubject: Final drive oil level check   Final drive oil level check I_icon_minitimeMon Sep 23, 2013 1:07 pm
Hey guys, I changed the final drive oil a few days ago. I filled it till the oil began oozing out consistently from the hole. Is there any way to check that level again ?, is it necessary ?, and I don't want to contemplate the consequences of not having enough. I am just looking for some pointers, not having any issues, leaks or anything like that.
PostSubject: Re: Final drive oil level check   Final drive oil level check I_icon_minitimeMon Sep 23, 2013 1:14 pm
Okay, found the answer shortly after posting this.
RArch
RArch
Number of posts : 613
PostSubject: Re: Final drive oil level check   Final drive oil level check I_icon_minitimeMon Sep 23, 2013 1:54 pm
Oh, is it a secret?
Wink
http://www.rcmodeltalk.co.uk
PostSubject: Re: Final drive oil level check   Final drive oil level check I_icon_minitimeMon Sep 23, 2013 3:32 pm
Nope. You remove the filler bolt from the case. If oil doesn't flow out, you top it up. Bike has to be on the centrestand.
Dimond
Dimond
Number of posts : 540
PostSubject: Re: Final drive oil level check   Final drive oil level check I_icon_minitimeMon Sep 23, 2013 4:03 pm
Don't put too much oil in because if you overfill it then it takes quite some time for the excess to drain out.
» Engine oil level check.
» Final Drive Oil
» what oil for final drive ?
» Final face squeal
» Final oil Drive
