terrance1938 Scooter Rider
Number of posts : 7 Location : valdosta,ga. Points : 4098 Registration date : 2013-09-17
| Subject: handle bars net lined up with front tire Fri Oct 25, 2013 12:04 pm | |
| fell over in the grass(thank goodness)...75 years old,couldn't stop it from falling...no damage but handle bars doesn't line up with tire...not badly out of align,but annoying...how do I relign them....thanks |
Number of posts : 4415 Age : 81 Location : damn near Philadelphia, PA Points : 10747 Registration date : 2009-06-12
| Subject: Re: handle bars net lined up with front tire Fri Oct 25, 2013 4:34 pm | |
| Take the handle bar cowling off and check the handle bar mount. You can also loosen those mount bolts and adjust the handle bar position slightly. You can also check the handle bar mount-to-stem pinch bolt while there. If it's still not aligned then the bar is probably bent. HTH
| Subject: Re: handle bars net lined up with front tire Fri Oct 25, 2013 6:28 pm | |
| thanks...don't know what a pinch bolt is...but will eye ball everything and see if I can fix it.. |
