Lowest full on rpm/speed? I_icon_minitimeby Meldrew Today at 8:01 am
» Rear wheel valve stem
Lowest full on rpm/speed? I_icon_minitimeby GHM-PM Today at 6:43 am
Lowest full on rpm/speed? I_icon_minitimeby COMick Fri Nov 22, 2024 6:13 pm
Lowest full on rpm/speed? I_icon_minitimeby xwelder Fri Nov 22, 2024 12:31 pm
Lowest full on rpm/speed? I_icon_minitimeby sonuvabug Thu Nov 21, 2024 4:17 pm
Lowest full on rpm/speed? I_icon_minitimeby JohnyC Wed Nov 20, 2024 10:04 am
Lowest full on rpm/speed? I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Lowest full on rpm/speed? I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Lowest full on rpm/speed? I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Lowest full on rpm/speed? I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
3 posters
LDB
LDB
Number of posts : 157
Registration date : 2014-05-19
Lowest full on rpm/speed? Empty
PostSubject: Lowest full on rpm/speed?   Lowest full on rpm/speed? I_icon_minitimeMon Jul 14, 2014 11:58 am
Not sure how to ask so hopefully this will make sense. I know (or think so anyway) when you first open the throttle it's something like slipping the clutch on a non-CVT vehicle. At what point in either speed or rpm is it no longer slipping but fully engaged?
I presume it is better for the drivetrain to be fully engaged and not slipping? I presume the same goes for fuel mpg?
Number of posts : 2387
PostSubject: Re: Lowest full on rpm/speed?   Lowest full on rpm/speed? I_icon_minitimeMon Jul 14, 2014 2:37 pm
The Swing has a real clutch, in the rear driven assembly. It is a centrifugal clutch with 5 friction pads or shoes.  The clutch slips until the drive belt turns the clutch arms and shoes with enough centrifugal force to lock the whole clutch/driven assembly together. Springs are built into the clutch to disengage it when the rpm drops and to allow the clutch to lock up gently. Clutch slip depends on the rpm of the belt, the weight of the bike and its passengers, road and wind resistance, etc. With very light throttle and light load, the clutch locks at about 20 kph. With large throttle input and heavy load, the clutch may not lock until 50 - 80 kph. If the clutch is glazed or worn, it may not lock at all, and when you accelerate, the engine speeds up but the bike doesn't.
Number of posts : 3316
PostSubject: Re: Lowest full on rpm/speed?   Lowest full on rpm/speed? I_icon_minitimeTue Jul 15, 2014 7:01 am
With lots of rubber band/cvt drive scooter miles----I think SilverWing works great in the driveline dept.....as the engine is very flexible---mine works good from lockup to at least 150kph.
Fuel mileage....at least one part, depends on how heavy you are with throttle hand.
» Whats the lowest mpg you ever got?
» Lowest price yet for 2012?
» Whats the lowest temp you will ride in?
» Shinko 567/568 Tire Full Review
» Full or semi synthetic?
