| odometer question | |
+6tinman AZ_Rider exavid Meldrew Cosmic_Jumper themastermix 10 posters |
themastermix Scooter Rider
Number of posts : 9 Location : Lebanon Points : 5356 Registration date : 2010-04-11
| Subject: odometer question Tue Oct 14, 2014 6:44 pm | |
| hi all simple question can the odometer / total km on 2010 swing 600 be adjusted / tweaked the reasons i'm asking is because i sold my 2003 swing and i'm gonna buy a second hand / used 2010 swing , owner says it has 1500 km and he drives it very rarely but the outer condition of the bike says other wise and a friend of mine mentioned that he might have tweaked the odometer so the question is can it be done ? |
| Subject: Re: odometer question Tue Oct 14, 2014 7:37 pm | |
| Can't be tweaked. The entire meter control board could be replaced, in which case the new odo would start at zero. However the expense of replacing the board would far exceed the preceived value of a tweaked odo.
That said, he could have possibly replaced the original meter control with a lesser-mileage eBay item.
| Subject: Re: odometer question Tue Oct 14, 2014 8:00 pm | |
| Of course odometers can be tweaked or the 'mileage recalibrated'. The practice is called Clocking, and it's easier to do on a digital electronic odometer than a mechanical analogue one. If you don't believe me a quick Google Search on Clocking Odometers will tell you how it's done. |
| Subject: Re: odometer question Tue Oct 14, 2014 11:10 pm | |
| Oops! I stand corrected and enlightened. Thanks Meldrew.
Unless the seller is a genuine shyster it still looks like a PITA though.
| Subject: Re: odometer question Wed Oct 15, 2014 12:52 am | |
| With that few miles look at the brakes, the disks should be practically unmarked and the pads at full thickness. The tires should look like new as well with only 1500 kilometers on them. The odometer could have been fiddled but usually isn't worth it because it really doesn't affect the selling price much. Is this one in a normal price range for a '10 model? I'd consider what it was worth if pristine and adjust my offer downward depending on condition. |
AZ_Rider Scooter Rider
Number of posts : 2 Location : Nebraska Points : 4218 Registration date : 2013-05-08
| Subject: Re: odometer question Wed Nov 05, 2014 4:13 pm | |
| If you disconnect the rear wheel speed detector, the odometer will stop adding miles. It's very easy. Happened to me by accident when the wire broke. |
| Subject: Re: odometer question Wed Nov 05, 2014 6:31 pm | |
| Disconnecting the speed sensor will also blank out the speed that you are traveling. |
| Subject: Re: odometer question Wed Nov 05, 2014 6:39 pm | |
| If the entire clip is unplugged or all of the wires are cut that is correct. I had an odd combination get cut / shorted that allowed the speedo to work, but stopped the odometer and ABS. |
Mudnman Super Scooter Rider
Number of posts : 218 Location : Florida Points : 4206 Registration date : 2014-01-15
| Subject: Re: odometer question Wed Nov 05, 2014 7:02 pm | |
| Buehler why is the car in reverse,on blocks?Buehler ..Buehler |
red99ryder Scooter Rider
Number of posts : 9 Age : 64 Location : Jackson ms Points : 3686 Registration date : 2014-10-31
| Subject: Re: odometer question Wed Nov 05, 2014 11:01 pm | |
| I just bought a 2003 with 2000 miles on the clock , tread looked good on the tires but the date code was 2002 so they were original tires . Getting new ones put on Friday . Decided to try the Michelin Pilot Power Pure SC .
There areas that looked like it had more use like the floor boards , it was dropped so a few scratched on Tupperware .. but lots of areas looked brand new
red |
SuzySwing Scooter Rider
Number of posts : 18 Location : Atlanta, Georgia, USA Points : 3761 Registration date : 2014-08-29
| Subject: Suggestion to Red Sun Nov 09, 2014 2:47 pm | |
| Hello Red. I wonder if the brake fluids have been changed, I had mine changed recently when I got new tires and the braking has improved a lot.
Best wishes and hope you have fun on the Swing |
| Subject: Re: odometer question Sun Nov 09, 2014 3:23 pm | |
| Hi Suzy , Yes I would I need to flush the Break Fluid as well as replace the Brake lines in the future . The breaks seem to work really well right now so im gonna ride it awhile . The new tires made a big difference on how well it rode . The rubber was pretty hard on the old tires .
Red |
jmaslak Super Scooter Rider
Number of posts : 252 Location : Golden, CO, USA Points : 4810 Registration date : 2012-06-15
| Subject: Re: odometer question Sat Nov 22, 2014 11:08 am | |
| Late, I know, but in case someone else has this question... 1500km - it should have the original tires (look at the date code and brand) and the tires should pretty much look new. Likewise so should pretty much everything else on the bike look new. That will probably be enough to know if the clock was turned back.
