| Hi From Jackson Ms | |
red99ryder Scooter Rider
Number of posts : 9 Age : 63 Location : Jackson ms Points : 3622 Registration date : 2014-10-31
| Subject: Hi From Jackson Ms Sun Nov 02, 2014 10:33 am | |
| Hi Everyone , Just picked up a 2003 Swing last Thursday Only rode it about a 100 miles so far , but it seems like a sweet scoot .
I do have a question. It has a tall givi windshield on it and the handlebars hit it when turning lock to lock . Is that normal ? Its to tall anyway and has a crack where the PO must have dropped it so will probably replace with Givi air flow or the Madstad .
thanks everyone for posting there mods , this forum has helped a bunch already . Bought the dampner for the seat off amazon and found one of the factory second tunnel bags on ebay
Ted |
Number of posts : 2940 Age : 75 Location : Winnsboro, Texas, U.S.A. Points : 8494 Registration date : 2010-02-17
| Subject: Re: Hi From Jackson Ms Sun Nov 02, 2014 10:46 am | |
| Subject: Re: Hi From Jackson Ms Sun Nov 02, 2014 11:55 am | |
| hello & Welcome No it shouldn't touch under normal circumstances (mine doesn't), even if you change to an airflow you will still have the same problem as the deflectors that are being touched are the same profile on both screens. Undo the handlebar cover plastic,slacken the bolts on the handlebar clamps a little & pull the bars back a very small amount, nip the bolts then try turning lock to lock, adjust further as necessary, tighten the clamps & refit the plastic cover. My guess is that the handlebars moved slightly in the clamps when the previous owner dropped it & that movement is what cracked the screen. |
Number of posts : 2085 Age : 71 Location : St.Pete.FL. Points : 7494 Registration date : 2010-02-03
| Subject: Re: Hi From Jackson Ms Sun Nov 02, 2014 3:43 pm | |
| Subject: Re: Hi From Jackson Ms Sun Nov 02, 2014 5:12 pm | |
| Subject: Re: Hi From Jackson Ms Sun Nov 02, 2014 6:05 pm | |
| Thanks for the tip on the Handlebars , I will look a little closer on the adjustments now that I know its not really supposed to hit . maybe there will be some mirror extenders in my future even thos I can see pretty good they way they are now Red
| Subject: Re: Hi From Jackson Ms Sun Nov 02, 2014 11:15 pm | |
| I think mirror extenders are worth their weight in gold, well maybe not gold but copper at least. It's nice to see behind you instead of your shoulders. |
JeffR_ Site Admin
Number of posts : 1103 Age : 65 Location : Bay Area, Ca Points : 9011 Registration date : 2010-05-12
| Subject: Re: Hi From Jackson Ms Sun Nov 02, 2014 11:56 pm | |
| I did the same thing that Roger did and got mirror extenders. It is really one of the best cheap mods you can do to the Swing. |
Number of posts : 1995 Age : 78 Location : Princeton, MN Points : 6007 Registration date : 2014-02-13
| Subject: Re: Hi From Jackson Ms Mon Nov 03, 2014 8:05 am | |
| I also got a set of extenders and love them. I just catch the outside corners of the GIVI top box but my rear view is greatly enhanced. |
