engine oil I_icon_minitimeby xwelder Today at 9:06 am
engine oil I_icon_minitimeby GHM-PM Today at 8:06 am
engine oil I_icon_minitimeby sonuvabug Yesterday at 4:17 pm
engine oil I_icon_minitimeby JohnyC Wed Nov 20, 2024 10:04 am
engine oil I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
engine oil I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
engine oil I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
engine oil I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
engine oil I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
engine oil I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
 engine oil
Sidewinder Pilot
Stuart Walker
sandancroy5
8 posters
sandancroy5
sandancroy5
Number of posts : 35
Registration date : 2014-09-27
engine oil Empty
PostSubject: engine oil   engine oil I_icon_minitimeSun Mar 22, 2015 9:18 am
can any one advice me whether castrol power 1 4t 10w-40 is a suitable oil to use in my silverwing 600.i used to use silkolene super 4 10w-40 semi synthetic in my 400 burgman.thanks
Stuart Walker
Number of posts : 13
Registration date : 2013-03-25
engine oil Empty
PostSubject: Oil grades for use in FJS 600 Silverwing   engine oil I_icon_minitimeSun Mar 22, 2015 11:18 am
Hi there
The specified oil grade of 10w - 40 is to my knowledge the correct multigrade oil to use with this particular Honda engine, as it covers such a wide range of operating conditions.
It would be ideally suited to all year round UK use, based on the maritime climate in the UK.
It is the grade I have used for the past 4 years in my Silverwing - semi synthetics are an option, but considerably more expensive, but I prefer to do more frequent oil changes in preference myself.
You can also take a look at the Castrol website, which will give you more technical information if required.
Hope that will be of some help ?
Best wishes
SW
Sidewinder Pilot
Sidewinder Pilot
Number of posts : 200
Registration date : 2015-05-21
engine oil Empty
PostSubject: Re: engine oil   engine oil I_icon_minitimeSun May 24, 2015 11:09 am
A question about oil "type"...
I've always used moto-specific oil to protect my clutch, but since swing has no wet clutch can I use modern energy conserving ratings? The manual says no, but is that because Honda just cuts and pasts manual text for all models, or is there something I haven't considered?
Lately I've been using Rotella, it's MA rated.
Number of posts : 3314
engine oil Empty
PostSubject: Re: engine oil   engine oil I_icon_minitimeSun May 24, 2015 1:22 pm
oil is use what you want to waste you money on---in US WalMart house brand 10-40 has worked for at least 500,000 miles for me, including wet clutch both Honda and Kawasaki and Suzuki, too. I think Honda now specs 10-30 for Silverwing.
Ever heard of SilverWing engine blowup?? Often oil changes are important to me
Sidewinder Pilot
Sidewinder Pilot
engine oil Empty
PostSubject: Re: engine oil   engine oil I_icon_minitimeSun May 24, 2015 3:14 pm
Agreed with the Wally World oil, been using the stuff made for older cars... SG/SF I think? I know Honda wants you to use $8 a qt Honda Oil... Fat Chance! Without a wet clutch I should be able to use anything, correct?
SilverwingInIdaho
Number of posts : 155
Registration date : 2011-08-23
engine oil Empty
PostSubject: Re: engine oil   engine oil I_icon_minitimeSun Jun 21, 2015 9:37 pm
SO is it 10w 40 or 10w 30? I just bought 10w 40 and will need to return for exchange. My last oil change was 10w 40
engine oil 510-80
engine oil Empty
PostSubject: Re: engine oil   engine oil I_icon_minitimeSun Jun 21, 2015 10:51 pm
Owner's manual calls for 10W-30, unless average temperature is above 65-70ºF. Then 10W-40 is okay. If you used 10W-40 before and are happy with it, I would use the same. For normal riding, I don't think it would make much difference. Just my 2 cents worth and worth at least half that much.
NWSSC
NWSSC
Number of posts : 418
engine oil Empty
PostSubject: Engine oil   engine oil I_icon_minitimeSun Jun 21, 2015 10:56 pm
The 10/40 will work just fine. Honda recommends 10/40 oil for temperature ranges from 20 deg F to 100 F. Although Honda oil is OK
it is not necessary and to pricey.   Howard
AldusFran
Number of posts : 210
engine oil Empty
PostSubject: Re: engine oil   engine oil I_icon_minitimeFri Jun 26, 2015 5:09 pm
I'm using RotellaT 15-40 which in my book is a very durable oil. I've used it in trucks,cars,tractors and motorcycles with go success. If not available I go to Castrol 10-40. Forget about Honda oils or bike specific oils ($$$). Since it's so freaking hot here in Tucson the 40 end gives me a little security. Oil change every 3000 miles is the important point not the 8000 miles as recommended.
engine oil
» Silverwing engine change
» Silverwing Bulletproof engine
» Synthetic Engine Oil
» An insane engine, by one of our own
» New engine for my Swing
