wather pump help I_icon_minitimeby sonuvabug Today at 4:19 pm
wather pump help I_icon_minitimeby sonuvabug Today at 4:17 pm
wather pump help I_icon_minitimeby sonuvabug Today at 4:06 pm
wather pump help I_icon_minitimeby JohnyC Yesterday at 10:04 am
wather pump help I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
wather pump help I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
wather pump help I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
wather pump help I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
wather pump help I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
wather pump help I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
 wather pump help
2 posters
saninpwnzor
Number of posts : 9
Registration date : 2015-04-28
wather pump help Empty
PostSubject: wather pump help   wather pump help I_icon_minitimeThu May 14, 2015 5:31 pm
greeting
question for the forum users experienced course
I have a small problem with the water pump
I see that on the part of the machine precisely to invest a little out of liquids.
If you accidentally seals replaced, a little to help me
otherwise the temperature was ok so I do not doubt the correctness of the pump itself mean that a gasket
If there are pictures even better
thanks in advance
PostSubject: Re: wather pump help   wather pump help I_icon_minitimeFri May 15, 2015 12:34 am
I can't help you much on the Silverwing water pump but have done a good bit of work in the Goldwing 1100 and 1200 pumps. One important thing about coolant for these bikes is to make sure the anti-freeze contains NO silicates. A lot of coolant does have this additive which is designed to reduce corrosion in aluminum engine blocks. Unfortunately the stuff scours the waterpump and can damage the main seal. There should be a weep hole under the pump housing, if coolant is seeping out of that hole it's an indication of a bad main seal. The pumps are not designed to be repaired though I know some GW owners have done that but results aren't usually too good. If it's not leaking too rapidly you can just keep some mixed coolant in a bottle on the bike and add as needed but eventually the pump may need to be changed. Don't use any kind of chemical or powder stop leak stuff on the engine because it can cause more problems than a bad pump.
saninpwnzor
Number of posts : 9
PostSubject: Re: wather pump help   wather pump help I_icon_minitimeMon May 18, 2015 8:27 pm
thx for advice
wather pump help
» Gas would not pump!
» NO fuel pump, rats got into it!
» new seat pump
» Water Pump
» Water pump gasket
