wiring color codes I_icon_minitimeby sonuvabug Today at 4:19 pm
wiring color codes I_icon_minitimeby sonuvabug Today at 4:17 pm
wiring color codes I_icon_minitimeby sonuvabug Today at 4:06 pm
wiring color codes I_icon_minitimeby JohnyC Yesterday at 10:04 am
wiring color codes I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
wiring color codes I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
wiring color codes I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
wiring color codes I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
wiring color codes I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
wiring color codes I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
 wiring color codes
3 posters
barnstormer37
Number of posts : 27
Registration date : 2015-05-31
wiring color codes Empty
PostSubject: wiring color codes   wiring color codes I_icon_minitimeFri Jun 12, 2015 8:05 am
Need to connect ground/tail/stop/turn lights to auxilliary light system on a 2007 for a newly installed trunk. Need to know the color codes for these lamps. I can figure it out, but is there a resource that I can go to that provides this information?
Number of posts : 3837
PostSubject: Re: wiring color codes   wiring color codes I_icon_minitimeFri Jun 12, 2015 12:50 pm
I'm sure it's on here somewhere - if I recall correctly someone, possibly DenisB, posted it to make it easier when using his patent connector to install light bars and so on.
I'll have a look later.
PostSubject: Re: wiring color codes   wiring color codes I_icon_minitimeFri Jun 12, 2015 1:01 pm
Indianapolis?...Why aren't you hanging out with the AmeriVespa crowd this weekend. Should be lots of nices scoots to enjoy there --regrettably though most of them will be trailered in. There just arent a lot of gonzo Vespa riders here as there are in the UK & Europe.
A Factory Service Manual is the resource for Silverwing info. Ebay is your friend. All FSC600 models are pretty much the same. So you could get a FSM for a later year and it would serve for your 2007, just as a 2002 FSM would work.
G = ground; Lb = right turn; O = left turn; G/Y & Bl/Br are brake and running lights, but I dont know which is which.
barnstormer37
PostSubject: Re: wiring color codes   wiring color codes I_icon_minitimeFri Jun 12, 2015 1:56 pm
Tim,
Thanks---12V tester tells me G/Y is brake, I'm having trouble getting a reading off of the rest of them. Perseverance [i]will[i] prevail.
I hope those Vespa guys brought their rain suits!
PostSubject: Re: wiring color codes   wiring color codes I_icon_minitimeFri Jun 12, 2015 2:30 pm
This is what I noted down when I was fitting my Admore Light Bar:
Silver Wing Harness
Green (Ground)
Light Blue (Rt Signal)
Orange (Lt Signal)
Black/Brown (running lights)
Green/Yellow (brake lights)
I have the 'matches' to DenisB's colour-code, too.
barnstormer37
PostSubject: Re: wiring color codes   wiring color codes I_icon_minitimeFri Jun 12, 2015 4:48 pm
Mike,
Thanks, that's what I finally came up with too. Looks like my problem is going to be large hands and small work space. Of course I don't already have all the correct color primary wires to make the connection from scoot to new trunk lights. I will get 'er done.
PostSubject: Re: wiring color codes   wiring color codes I_icon_minitimeFri Jun 12, 2015 7:19 pm
There is a disconnect plug for the rear lights wire harness if you remove the left side body panel. It's a whole lot easier to access things at that location then trying to do things thru those cargo bin panels.
PostSubject: Re: wiring color codes   wiring color codes I_icon_minitimeSat Jun 13, 2015 4:42 am
Pleasure.
I should have said I have the 'matching' colour codes for Admore lights, which enabled me easily to wire in the Admore Light Bar to DenisB's connector.....which is the same code as the Silverwing, i.e. blue to blue and so on.
wiring color codes
» Silver Wing Colors
» Paint codes.
» Dashboard LED color mod
» Color vs Cleanliness
» 2004 S'wing Color Mystery
