Changing engine and final drive oil I_icon_minitimeby MikeO Yesterday at 6:23 pm
Changing engine and final drive oil I_icon_minitimeby POCAHONTAS Yesterday at 6:05 pm
Changing engine and final drive oil I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Changing engine and final drive oil I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Changing engine and final drive oil I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Changing engine and final drive oil I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
Changing engine and final drive oil I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
Changing engine and final drive oil I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
Changing engine and final drive oil I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
Changing engine and final drive oil I_icon_minitimeby kbcmdba Mon Nov 04, 2024 7:56 pm
NWSSC
moenaboulsi
moenaboulsi
Number of posts : 3
Registration date : 2015-08-01
Changing engine and final drive oil Empty
PostSubject: Changing engine and final drive oil   Changing engine and final drive oil I_icon_minitimeSat Aug 01, 2015 2:17 am
Hello silverwing community, I am a proud new owner of a 2006 silverwing abs blue with 4500 KM. I've had the bike for about a couple weeks and loving it so far. I've already learned so much about from you guys in this community.
I've decided to change the engine oil and the final drive oil(which I didn't know existed until coming in this forum) I know there's a lot of discussion on the type of oil to use in the final drive. I've decided to go with amsoil 10w30 in both. Can I go wrong with this combination? I have some royal purple max gear 75w90 gear oil left in the garage from my previous scooter that i wanted to use but didn't wanna go against the manufacturer. I was so anxious to see how the drive oil looks like after reading this forum so already drained it out and it's waiting to be filled back in. I just want a final confirmation from you guys. The previous owner said he just changed the oil in the engine and he put rotella t6. Looks clean but wanna change it anyway.
NWSSC
NWSSC
Number of posts : 418
PostSubject: Changing engine and final drive oil    Changing engine and final drive oil I_icon_minitimeSat Aug 01, 2015 7:28 am
Hello and welcome to the forum. My final answer is that you can not go wrong either way. I my self have used 75/90 gear oil in the final drive and have 56,000 miles on my 06 S/W. I think the consensus on engine oil is don't waste your money on synthetic oil. Howard
PostSubject: Re: Changing engine and final drive oil   Changing engine and final drive oil I_icon_minitimeSat Aug 01, 2015 9:24 am
Welcome to the forum. Thank you for introducing yourself.
I've moved this post to Introductions.
This is going to sound a bit nit-picky, but please feel free to continue this oil change conversation in other appropriate sections.
Changing engine and final drive oil 510-80
PostSubject: Re: Changing engine and final drive oil   Changing engine and final drive oil I_icon_minitimeSat Aug 01, 2015 12:09 pm
applause welcome applause Thanks for the introduction. It sounds as if you found a nice scooter that just needs riding. Your choice of oil sounds good to me.
Now get that oil changed and get some riding done. small moped small moped small moped
PostSubject: Re: Changing engine and final drive oil   Changing engine and final drive oil I_icon_minitimeSat Aug 01, 2015 6:12 pm
welcome moenaboulsi welcome to the best Silverwing forum on the web. Sounds like you found a good one. I would keep an eye on your tires for any signs of cracking or dry rot. The tires on your scooter are nine or ten years old if they are still the original ones. I have a 2007 with original tires I'm still riding on but most people don't trust tires older than five or six years. I inspect my tires regularly and if I found any signs age I'd replace them.
If you are looking forward to learning and plan on doing your own maintenance you'll find you can do anything you need or want with the service manual and help from this forum.
I add the paragraph below for most new members because there's a lot of information in the links and may save you some work.
Here are some links(3 below in blue)that will help you learn a lot about your Silverwing. If you can't find what you need in the links below the search on this forum works good, and if you still need help just ask and someone will do what they can to answer your questions.
Maintenance, Tips and Hints
Maintenance "Pictorials"
Accessories-Modifications
moenaboulsi
Number of posts : 3
PostSubject: Re: Changing engine and final drive oil   Changing engine and final drive oil I_icon_minitimeSat Aug 01, 2015 8:53 pm
Thanks brother I really appreciate your sound advice. I actually noticed today when changing the oil because my eye was close to the side of the tires, I noticed they were starting to crack a bit. So I am surely going to look into changing them. The service manual is pretty helpful, I ended up getting it with the bike. Thanks again
moenaboulsi
Number of posts : 3
PostSubject: Re: Changing engine and final drive oil   Changing engine and final drive oil I_icon_minitimeSat Aug 01, 2015 8:56 pm
I did notice today though when I put the oil and then a couple hours later I wanted to go for a ride, when idling the bike was idling between 500 and 1000rpm and felt like it wanted to stop. It did that for a few minutes and went away. I am guessing it's the oil transitioning in. I only changed the final drive oil today.
NWSSC
NWSSC
PostSubject: Changing engine and final drive oil   Changing engine and final drive oil I_icon_minitimeSat Aug 01, 2015 9:37 pm
I would not be to concerned about engine idle until you run a couple of tanks of fuel through your S/W, unless it becomes major problem. And stay away from Ethanol. Howard
DaveR
Number of posts : 440
PostSubject: Re: Changing engine and final drive oil   Changing engine and final drive oil I_icon_minitimeSat Aug 01, 2015 10:52 pm
I use Honda 10-40 in both engine and final drive. 2005 with 52000 smiles on it.
Number of posts : 2621
PostSubject: Re: Changing engine and final drive oil   Changing engine and final drive oil I_icon_minitimeSun Aug 02, 2015 8:19 am
ditto except I don't use Honda oil.
» Changing the Final Drive Oil Pictorial
» Changing the drive belt
» Final oil Drive
» FINAL DRIVE OVERFLOW
» Final Drive Oil
