» Rear wheel valve stem
Dead Ignition I_icon_minitimeby GHM-PM Today at 6:43 am
Dead Ignition I_icon_minitimeby GHM-PM Today at 6:40 am
Dead Ignition I_icon_minitimeby COMick Fri Nov 22, 2024 6:13 pm
Dead Ignition I_icon_minitimeby xwelder Fri Nov 22, 2024 12:31 pm
Dead Ignition I_icon_minitimeby sonuvabug Thu Nov 21, 2024 4:17 pm
Dead Ignition I_icon_minitimeby JohnyC Wed Nov 20, 2024 10:04 am
Dead Ignition I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Dead Ignition I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Dead Ignition I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Dead Ignition I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
 Dead Ignition
roboclock
Number of posts : 7
Registration date : 2015-05-17
Dead Ignition Empty
PostSubject: Dead Ignition   Dead Ignition I_icon_minitimeSun Sep 06, 2015 5:26 pm
2003 SW. Insert key and turn, and the Ignition is dead, nothing happens, no lights on dash. Battery is charged. Worked fine a few days ago.
I suspect a ingintion switch is bad. Any one have any tips in replacing the switch?
Dead Ignition Empty
PostSubject: Re: Dead Ignition   Dead Ignition I_icon_minitimeSun Sep 06, 2015 6:14 pm
I moved your post from 'Tips On Using This Forum' to 'Silverwing Topics'.
Have you checked the 30-amp main fuse?
NWSSC
NWSSC
Number of posts : 418
Dead Ignition Empty
PostSubject: Dead Ignition    Dead Ignition I_icon_minitimeSun Sep 06, 2015 9:10 pm
Roboclock
It is like going to the doctor.We need to here a little more information before surgery.You say the battery is charged. Did you have a another problem and decided the battery needed charging.
Was there a possibility of reversing the cables when you hooked up the charger and blew a fuse as suggested? Where there any other concerns before this episode? Let us know. Howard
Dead Ignition Empty
PostSubject: Re: Dead Ignition   Dead Ignition I_icon_minitimeSun Sep 06, 2015 9:22 pm
You need to remove the left rear side panel and replace the main fuse. When you look at the main fuse on the starter relay you will probably see a good fuse. You need to pull the rubber to see the fuse block and I think you will find it is blown. Hopefully the spare fuse is good then use it and remember to replace it.
roboclock
Number of posts : 7
Dead Ignition Empty
PostSubject: Re: Dead Ignition   Dead Ignition I_icon_minitimeMon Sep 07, 2015 8:05 am
Okay, I'll try and check the main fuse today.
I'll keep you posted.
BTW: I did open up around the Key enough to check wire. I have 12.5 volts in the red wire going to the key when off. When I turn the key on, I get 4.5 volt on all three wires, WiERD.. even the Red one.
roboclock
Number of posts : 7
Dead Ignition Empty
PostSubject: Re: Dead Ignition   Dead Ignition I_icon_minitimeMon Sep 07, 2015 8:52 am
Not the main fuse as I suspected, since I had 12 volts at the key.
Can I pull the wires off the bottom of the key barrel. And then can I hot wire to see if the bike starts.
There are 3 wires, Red (power) blue/orange, black/red. Can I jump the red to the other two wires? Or just one or the other.
A wiring diagram would help if anyone can email me one.
Rob
Dead Ignition Empty
PostSubject: Re: Dead Ignition   Dead Ignition I_icon_minitimeMon Sep 07, 2015 3:18 pm
To do a basic switch bypass link the R & R/Bl together, but remember that you still need the ignition key to be within 2" of the switch for the immobiliser circuit to de-activate.
Red is live feed from battery
Red/Black is feed for ignition componants
Blue/Orange is the feed for the radiator cooling fan
roboclock
Number of posts : 7
Dead Ignition Empty
PostSubject: Re: Dead Ignition   Dead Ignition I_icon_minitimeMon Sep 07, 2015 6:49 pm
Thanks, That's good to know.
It appears that even though the battery reads 12.45 volts, the battery is no good. I decided to try a jump, and the bike started. I have never had a bad battery that has read good voltage. Hopefully there is not some strange issue else where.
So I will order a new Battery,
Thanks for all the help
NWSSC
NWSSC
Dead Ignition Empty
PostSubject: Dead Ignition   Dead Ignition I_icon_minitimeMon Sep 07, 2015 11:16 pm
It is not uncomin to have a 12.0 V battery with 12.0V and not be able to start a vehicle.The battery power is through the amps.Honda would be the place to take the battery and have them peform a load test.In the automotive industry the batteries have a much larger amperage capacity and there device would not do the Honda battery justice.A 12.0 Volt battery has to be under a load and have x number of amps at a preset voltage, depending on the seize of the battery.Honda or a decent bike shop will have this load testing device. Howard
Dead Ignition
» Low or dead battery?
» dead battery
» Dead battery
» Under seat bulb replacement with LED
» Dead battery ???
