| Houston, we have a problem. | |
CnR Scooter Rider
Number of posts : 36 Age : 53 Location : West Central Ohio Points : 3861 Registration date : 2014-06-27
| Subject: Houston, we have a problem. Thu Mar 17, 2016 11:42 pm | |
| If you've been watching my other posts, I decided to change to Dr pulley 26 gram sliders, and change my belt. With your help, all went well. I got everything changed, I was super excited. Torqued the variation nut (with a torque wrench I might add), and was so excited! Turned the key, and something went wrong......
I left the (insert most obscene explicit here) variator tool on the variator. So basically, I tried cranking the engine with the variator tool installed to prevent the variator from turning when I was tightening the variator nut.
I feel about 3 inches tall. Scooter will not DO ANYTHING when I turn the key. No warning lights on the dash, NOTHING. I was on top of the world, saving money doing this myself and f*cked it up.
What is wrong? What do I do now? |
NWSSC Silver Wing Rider
Number of posts : 418 Age : 87 Location : Mt Prospect IL 30 miles west of Chicago Points : 5842 Registration date : 2010-03-03
| Subject: Houston, we have a problem. Fri Mar 18, 2016 3:55 am | |
| I take it the variator tool prevented the engine from making a complete revolution and the engine did not start up. I would think this has nothing to do with the dash lights coming on.If the engine is not turning over now and you have no dash lights I would think it may be a coincidence and you have a bad connection at the battery or it may need charging. As they say keep it simple. Let us know. Howard |
Cookie Super Scooter Rider
Number of posts : 233 Location : Essex UK Points : 5039 Registration date : 2011-10-03
| Subject: Re: Houston, we have a problem. Fri Mar 18, 2016 6:47 am | |
| Trying to start the engine with it effectively locked could have simply blown a fuse somewhere. Have a look at them - they're easy to get at. Don't forget the main fuse which lives under the left hand rear panel and is the only awkward one to get at. If nothing is working at all then the main fuse would be my top suspect. Don't worry just yet - it's probably something simple. |
CnR Scooter Rider
| Subject: Re: Houston, we have a problem. Fri Mar 18, 2016 10:14 am | |
| Loose battery cable.
Started fine after I tightened the battery cables.
Thanks everyone! |
Tommo Scooter Rider
Number of posts : 94 Age : 78 Location : Kidderminster UK Points : 3453 Registration date : 2015-10-01
| Subject: Re: Houston, we have a problem. Fri Mar 18, 2016 10:59 am | |
| Bet your pleased that's all it was. My favorite trick is losing stuff!! |
Number of posts : 2940 Age : 75 Location : Winnsboro, Texas, U.S.A. Points : 8551 Registration date : 2010-02-17
| Subject: Re: Houston, we have a problem. Fri Mar 18, 2016 12:16 pm | |
Number of posts : 1999 Age : 78 Location : Princeton, MN Points : 6068 Registration date : 2014-02-13
| Subject: Re: Houston, we have a problem. Fri Mar 18, 2016 3:04 pm | |
| - Tommo wrote:
- Bet your pleased that's all it was.
My favorite trick is losing stuff!! And, my favorite trick is putting a tool down and going back to get it. It's not where I left it but after about 5 minutes or so when I go back it's right where I left it. Maybe it just didn't register in my brain the first time OR being almost 70 years old the brain is finally snapping and not working anymore. It's the same way while sitting here at my desk. I go into the kitchen to get something and can't remember what the heck I went out there for. Come back here and retrace my thoughts and steps and get what it was I wanted in the first place. I keep repeating it to myself on the way, "Get a cup of coffee. Get a cup of coffee"... Then I have my coffee and all is good again. :lol!: |
Winger61 Silver Wing Rider
Number of posts : 452 Age : 75 Location : Louth, Lincolnshire, UK Points : 5627 Registration date : 2010-10-15
| Subject: Re: Houston, we have a problem. Fri Mar 18, 2016 3:33 pm | |
| - Dale N. wrote:
It's the same way while sitting here at my desk. I go into the kitchen to get something and can't remember what the heck I went out there for. Come back here and retrace my thoughts and steps and get what it was I wanted in the first place. Sounds to me you're a bit like this guy! (Me too! ) https://www.youtube.com/results?search_query=golf+brooks+senior+moments When I 'lose' things, senior management usually say "I bet someone's put it right where you left it"! Why are they always right?? |
Tommo Scooter Rider
| Subject: Re: Houston, we have a problem. Fri Mar 18, 2016 3:58 pm | |
| Dale, I can relate to everything you have said, but isn't it so frustrating. The other thing that happens to me a lot, is when I come to a road junction to pull out on to a main road, the whole world goes by before I can pull out. ggggggggggggggr |
| Subject: Re: Houston, we have a problem. Fri Mar 18, 2016 4:16 pm | |
| Yes Winger, Senior moments and brain farts!
Tommo that road is usually deserted most of the day too. Just not when you or I want to use it. |
Number of posts : 693 Age : 67 Location : Loveland, Colorado Points : 6446 Registration date : 2009-01-23
| Subject: Re: Houston, we have a problem. Fri Mar 18, 2016 5:32 pm | |
| So now that it is running how do you like the 26g sliders?? |
CnR Scooter Rider
| Subject: Re: Houston, we have a problem. Fri Mar 18, 2016 5:58 pm | |
| - The Scootist wrote:
- So now that it is running how do you like the 26g sliders??
I honestly havnt rode it yet. It's still a tad chilly here. Suppose to warm up next week though. I will let you know! |
