Locked up motor / Looking for 2 S'Wings I_icon_minitimeby sonuvabug Yesterday at 4:19 pm
Locked up motor / Looking for 2 S'Wings I_icon_minitimeby sonuvabug Yesterday at 4:17 pm
Locked up motor / Looking for 2 S'Wings I_icon_minitimeby sonuvabug Yesterday at 4:06 pm
Locked up motor / Looking for 2 S'Wings I_icon_minitimeby JohnyC Wed Nov 20, 2024 10:04 am
Locked up motor / Looking for 2 S'Wings I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Locked up motor / Looking for 2 S'Wings I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Locked up motor / Looking for 2 S'Wings I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Locked up motor / Looking for 2 S'Wings I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Locked up motor / Looking for 2 S'Wings I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Locked up motor / Looking for 2 S'Wings I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
Gustafa
cliffyk
docjones
docjones
Number of posts : 52
Registration date : 2011-10-12
Locked up motor / Looking for 2 S'Wings Empty
PostSubject: Locked up motor   Locked up motor / Looking for 2 S'Wings I_icon_minitimeMon Jul 25, 2016 9:04 pm
What is the easiest way to determine if the motor is locked or seized up? Starter motor won't turn it over. Can I get to the flywheel fairly easily to see if it will turn? Getting to the belt side looks like it could take some time if one was in a hurry.
PostSubject: Re: Locked up motor / Looking for 2 S'Wings   Locked up motor / Looking for 2 S'Wings I_icon_minitimeMon Jul 25, 2016 10:24 pm
Remove the spark plugs then take off the belt case and try to turn the variator bolt (17mm). The variator is directly bolted to the crankshaft. The flywheel is considerably more difficult to access.
ADDENDUM: If the variator wont turn with the spark plugs removed the next step would be to remove the Starter Motor. If the Starter has jammed the works locking up the flywheel then removing it should allow the variator should turn freely.
cliffyk
cliffyk
Number of posts : 182
PostSubject: Re: Locked up motor / Looking for 2 S'Wings   Locked up motor / Looking for 2 S'Wings I_icon_minitimeMon Jul 25, 2016 10:35 pm
Only the front plastic CVT cover has to come off to get at the crank bolt, however the passenger foot peg bracket must be removed first--5 to 10 minutes tops...
Gustafa
Gustafa
Number of posts : 218
Registration date : 2015-10-10
PostSubject: Re: Locked up motor / Looking for 2 S'Wings   Locked up motor / Looking for 2 S'Wings I_icon_minitimeTue Jul 26, 2016 10:12 am
I hope youre not frozen up, just a starter or plug fail, best of luck!
Number of posts : 3314
PostSubject: Re: Locked up motor / Looking for 2 S'Wings   Locked up motor / Looking for 2 S'Wings I_icon_minitimeTue Jul 26, 2016 10:51 am
How about weak/old battery?
docjones
PostSubject: Re: Locked up motor / Looking for 2 S'Wings   Locked up motor / Looking for 2 S'Wings I_icon_minitimeTue Jul 26, 2016 11:29 am
Thanks you guys. This info will help a lot.
Number of posts : 921
PostSubject: Re: Locked up motor / Looking for 2 S'Wings   Locked up motor / Looking for 2 S'Wings I_icon_minitimeTue Jul 26, 2016 1:15 pm
Don't assume the worst. Do as advised First Battery. Then checks. Why do you think seized motor? was it running okay before?
docjones
PostSubject: Re: Locked up motor / Looking for 2 S'Wings   Locked up motor / Looking for 2 S'Wings I_icon_minitimeTue Jul 26, 2016 5:50 pm
I don't know yet. The previous owner said he was riding along and it just quit. Won't start or even turn over with a brand new battery. Just feeling out my options before I pull the trigger on this new to me Swing.
tinman
Number of posts : 1298
PostSubject: Re: Locked up motor / Looking for 2 S'Wings   Locked up motor / Looking for 2 S'Wings I_icon_minitimeTue Jul 26, 2016 7:10 pm
Remove the drive clutch cover off put a socket on the drive face bolt and see if there is rotation ,if so motor not seized .If motor is seized find another motor on E bay.
PostSubject: Re: Locked up motor / Looking for 2 S'Wings   Locked up motor / Looking for 2 S'Wings I_icon_minitimeTue Jul 26, 2016 9:41 pm
Could possibly be that it's nothing more than that the drive belt shredded and jammed up the transmission --a very rare occurrence, but it has happened. Again, you'd have to remove the belt case to determine that. The belt is not that expensive and it's a pretty easy DIY job. However I sure wouldn't buy it without knowing exactly what the problem is.
As Tinman said, you can find engines on eBay so you'd need to factor that expense (+ shipping) as well as the expense of a Honda dealer's labor to disassemble the scoot to R & R the engine.
It's your game; no one is going to buy it as it is, so go with an extremely low bid. The sellers alternative is to salvage it (for maybe $500) or fix it.
Number of posts : 1935
PostSubject: Locked up motor / Looking for 2 S'Wings   Locked up motor / Looking for 2 S'Wings I_icon_minitimeWed Jul 27, 2016 7:33 am
Anyone check the oil? just a thought, how many miles on the bike? any maint. records?
Modernman1953
Number of posts : 379
PostSubject: Re: Locked up motor / Looking for 2 S'Wings   Locked up motor / Looking for 2 S'Wings I_icon_minitimeThu Jul 28, 2016 5:00 pm
I bought a 06 Silverwing with 7500 miles on it, all of the tupperware off the bike for $900. When they are not running, they don't bring much value. I reassembled the bike and it is really not worth more than $2500.
So, what is a seriously broken one worth?
By the way, I do have a spare bottom half of a motor. If you need a starter, I have one.
Kennylxix
Number of posts : 156
Registration date : 2016-11-05
PostSubject: Re: Locked up motor / Looking for 2 S'Wings   Locked up motor / Looking for 2 S'Wings I_icon_minitimeThu Nov 10, 2016 6:06 pm
I just finished a motor swap on mine newly acquired wing. If the motor is bad I suggest just swapping the whole thing. I got mine locally(ish) for 325. It has 6000 miles on it and came with the Trans and everything. It's a pretty involved job but doesn't require and special tools and is doable by one person in a weekend.
» 2 SWings in my Garage :)
» How many Swings have you owned?
» Gasahol for Swings
» Couple of questions re: Swings
» Throttle Locks for Swings
