» Fun times ahead
Wider seat options? I_icon_minitimeby Loosemarbles Today at 3:49 pm
» Dashboard Square
Wider seat options? I_icon_minitimeby MikeO Today at 4:11 am
» Hello From MD
Wider seat options? I_icon_minitimeby GHM-PM Yesterday at 7:15 am
» LED Headlights
Wider seat options? I_icon_minitimeby landisr Mon Oct 28, 2024 11:35 pm
Wider seat options? I_icon_minitimeby DescendingRaven Mon Oct 28, 2024 5:15 pm
» Ignition Switch
Wider seat options? I_icon_minitimeby POCAHONTAS Sun Oct 27, 2024 9:07 pm
» Lift Without A Lift
Wider seat options? I_icon_minitimeby landisr Sat Oct 26, 2024 5:25 pm
Wider seat options? I_icon_minitimeby xwelder Sat Oct 26, 2024 3:18 pm
Wider seat options? I_icon_minitimeby xwelder Fri Oct 25, 2024 5:00 am
» Handlebar Holder Recall
Wider seat options? I_icon_minitimeby xwelder Thu Oct 24, 2024 9:12 am
 Wider seat options?
nyarlotep
nyarlotep
Number of posts : 6
Registration date : 2013-09-17
Wider seat options? Empty
PostSubject: Wider seat options?   Wider seat options? I_icon_minitimeWed Sep 14, 2016 1:28 am
I'm fat, with a wide a**. The stock Silverwing seat is a little narrow for me. I also feel like I'm going to slide off the front all the time. I'd love to make the seat more like the one on my ATV. Has anyone had custom mods done to widen the seat, or add a 'saddle horn'?
Number of posts : 1013
PostSubject: Re: Wider seat options?   Wider seat options? I_icon_minitimeWed Sep 14, 2016 1:44 am
nyarlotep,
Use the search option listed above and you will get 96 posts with "wider seat". My first Swing came with a Corbin after market seat. It was very wide. It seemed too hard for me (I don't have much built-in cushions and need a softer seat. I like the stock seat on my new Swing. It fits my small butt just fine with a lot soft foam.
Number of posts : 2008
PostSubject: Re: Wider seat options?   Wider seat options? I_icon_minitimeWed Sep 14, 2016 3:55 am
Keep in mind that a wider seat changes the geometry of where your legs are placed and how you put them down when you are stopped.
If you are tall, then you have more choices.
If you are short wider seats will interfere with leg placement comfort.
If you buy a corbin seat, they will custom make it to your specs, but same warnings apply.
Before you go adding a saddle horn, make sure you have the *ahem* "testicular fortitude" to be comfortable with that at a full stop with both feet down, and also in hard braking.
If you have to slide forward to be in a position to put your feet down (i.e. you are short), a horny saddle can be a painful one.
Dan
PostSubject: Re: Wider seat options?   Wider seat options? I_icon_minitimeThu Sep 15, 2016 3:25 am
The Corbin seat seemed to be more slippery than my current OEM seat. I would a!most always slide forward when braking. To be able to flat-foot at a stop, I had to slide forward where the seat narrows.
Number of posts : 3832
PostSubject: Re: Wider seat options?   Wider seat options? I_icon_minitimeThu Sep 15, 2016 4:02 pm
I recall someone inserting a tennis-ball under the cover in order to create a 'horn.
I remember nothing further about it.
PostSubject: Re: Wider seat options?   Wider seat options? I_icon_minitimeFri Sep 16, 2016 1:01 am
Why would one take their feet off the floorboards until the bike stops? You can't slide forwards if your feet are on the floorboards. I always keep my feet on the upward angled part of the boards. More or less press forward on them with my feet on rough ground, kinda wedge myself against the seat. Prevents bouncing up on the seat. Good substitute for gripping the fuel tank with your knees on a motorcycle.
My preferred method of coming to a stop on a bike or scooter is to stick my left leg out to the side a bit just before the bike comes to a stop. That will initiate a tilt to that side so there's no uncertain wobble as one stops. I never touch the ground with my foot unless the bike has come to a complete stop. Looks silly to paddle like a duck getting underway and stopping. Very squidlike.
PostSubject: Re: Wider seat options?   Wider seat options? I_icon_minitimeSat Sep 17, 2016 4:55 am
I also come to a stop with my left foot extended for the very same reason, but when waiting at a stop light, especially a long light, I will flat foot my two feet. On the Corbin, I would have to slide to the front of the seat to be able to place both feet on the ground. The Corbin seat is a lot wider than the OEM seat. For me, I like the OEM seat just fine. I don't need a touring seat because my trips at most is 110 miles unless loop my starting point. I guess I could just turn around and return the same way I came from.
tinman
Number of posts : 1298
PostSubject: Re: Wider seat options?   Wider seat options? I_icon_minitimeSat Sep 17, 2016 6:15 am
The first time with my swing ,while parking at a very slow speed ,I touch the front brakes and slid off the scoot. I cut out 1"of foam with a electric bread knife leaving the front of the seat pocket to keep from falling off.It works very wheel for me.
PostSubject: Re: Wider seat options?   Wider seat options? I_icon_minitimeSat Sep 17, 2016 3:53 pm
Tinman,
Was that the original OEM seat you modified?
PostSubject: Re: Wider seat options?   Wider seat options? I_icon_minitimeSat Sep 17, 2016 6:29 pm
Kinda begs the question, why were you using the front brake at low speed? Lot safer just to use the rear at low speed especially if you're maneuvering in tight areas. At least you just slipped forward and didn't drop the bike.
tinman
PostSubject: Re: Wider seat options?   Wider seat options? I_icon_minitimeSat Sep 17, 2016 11:11 pm
Yes I modified the stock seat , and as for locking the front brakes ,I think I touch  the front brakes it happen so fast less then 1 mph ,parking between 2 cars .The left lever controls the front and the rear brakes. All I do remember is dropping my swing in slow motion, no damage.
PostSubject: Re: Wider seat options?   Wider seat options? I_icon_minitimeMon Sep 19, 2016 12:04 am
The brakes are linked but the rear brake lever is biased heavily to the rear brake. The linkage isn't very strong unless you really put pressure on the lever. In normal slow turns and such the linkage isn't strong enough to dump the bike unless a person is in a sharp turn and really lays on the rear brake. That isn't the case with the front brake, it acts powerfully with a pretty light pressure on the front brake lever.
Take a look at the "Ride like a Pro" videos by Jerry Palladino. His slow speed maneuvering dragging he rear brake slightly to keep the bike upright really works.
Wider seat options?
» Handgrip Options
» Too Many Givi Options
» added wider floorpads
» Seat Modification: Car seat substitution
» Bag options for SW?
